ACER ASPIRE ONE KEYBOARD REPLACEMENT
I HAVE JUST PURCHASED AN ASPIRE ONE FROM CANADA. IT CURRENTLY HAS A CANADIAN/FRENCH KEYBOARD FITTED. I CAN SOURCE THE KEYBOARD - I JUST DONT KNOW HOW TO REPLACE IT. CAN ANYONE HELP PLEASE. THANKS!
  • 5 more comments
  • amandaN Nov 20, 2008
    Thanks very much Joe - your assistance is greatly appreciated!
  • martin14 Dec 15, 2008
    I have the same issue. Can anyone advise where can source a keyboard from? Also just been told by Acer Europe that it does not have an International Warranty despite retailer advising it was.
    Thank you Martin
  • Sharakin Dec 23, 2008
    Thanks for your tuturial Joed911. Your tutorial is the second one I've come across. Apparently there's an Aspire One keyboard that pops out automatically and mine doesn't. I've tried "peeling off" with a small screwdriver but I'm afraid I'm not using the right tool. Thanks! :D
  • Anonymous Apr 01, 2009
    Your answer gave me the courage to try and take the keyboard off my Acer 2920....but don't have screws under the pause and F2 keys so I'm guessing this isn't instructions for my model. Can anyone help me with taking my keyboard off?
  • shmulik332 May 07, 2009
    how to replace key bord on aspirone?
    i have the new one on hand
  • bdarling17 May 15, 2009
    I have pushed in/up the 3 levers and now they have disappeared. How can I get them to "pop" back?
  • b308659 Jun 11, 2013
    The keyboards are often difficult to get out, you need to pop all three catches and then a thin tool (eg credit card) can be used to ease up the top edge. On some models there are also catches on each side.
  • 4,338 Answers
To remove the Keyboard you'll need a flat head screw driver, there are 3 levers that holds the keyboard inplace. look closer they are above the following keys "Pause break" "F8" and "F2" (tips: remove the one in the middle "F8" first it makes life a lot easier) use the flat head screw driver and put the lever upward towards the screen and the key board should pop up
Start from the top and start peeling off the keyboard, there might be a little bit of tape sticking to the keyboard so becareful, watch out for the cable that is connecting the keyboard and the board, carefully remove the cable and the keyboard should come right off.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 18, 2008
Oh my god that was soooo helpful. I did what you said. I took a flat head screw driver and you have to pry it out. You push the tab and pry it out at the same time. My new americanized Aspire One, is working perfectly!!! Whew!!!
Posted on Jan 15, 2010
    Problem Solver:
  • 4 Answers
As noted above once the three catches are released you need to (gently) pry up the keyboard (try a credit card). Some models also have a tab on each side as well. Once the keyboard is loose you need to remove the attaching cable which is usually taped on the back of the key board. Note the cable connector is a clamp so you need flick up the front (black part) on the connector to release the cable. When reinstalling you need to be careful to align the cable in the connector before clamping it shut or the keyboard won't work. The connector for the touch pad is similar but a bit more difficult to manipulate.
Posted on Jun 11, 2013
2 Suggested Answers
mwalker02
  • 41 Answers
SOURCE: ACER ASPIRE ONE KEYBOARD REPLACEMENT
I have opened and worked on several laptops over the years. I can tell you that there are many things you have to remove sometimes (depending on the brand and design) in order to replace the keyboard. Unless your comfortable doing this I would suggest taking it to a computer repair shop. I'm sorry this is not really the answer you were looking for, but It can get complicated sometimes. You will enjoy your computer sooner and if a shop changes it for you, then they will have to warranty their work if something goes wrong. Could be to your benefit. Thanks!
Posted on Jun 02, 2009
HOW DO i SWITCH FROM CANADIAN FRENCH TO CANADIAN ENGLISH KEYBOARD
In the control panel there are regional and language settings. Try there.
Apr 02, 2011 | Acer Aspire One PC Notebook
Tip
Change your keyboard latout
<span> Windows 7 or Windows Vista <ol> <li>Click <span>Start </span>, type <span>intl.cpl</span> in the Start Search</b> box, and then press ENTER.</li> <li>On the Keyboards and Language</b> tab, click Change keyboards</b>.</li> <li>Click Add</b>.</li> <li>Expand the language that you want. For example, expand French (Canada).</li> <li>Expand Keyboard list</b>, click to select the Canadian French</b> check box, and then clickOK</b>.</li> <li>In the options</b>, click View Layout</b> to compare the layout with the actual keyboard.</li> <li>In the Default input language</b> list, click French (Canada) - Canadian French</b>, and then click OK</b> two times.</li> <li>In the Regional and Language Options</b> dialog box, click OK</b>. <b>Note</b> The Language</b> bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.</li> <li>Click the Language</b> bar, and then click FR French (Canada)</b>.</li></ol></span>
on May 02, 2011 | Computers & Internet
Aspire Notebook - Get green keyboard options. Eg, cannot get question mark
Try the "On-Screen Keyboard" and see if it has the same problem. If not then the key on the keyboard is bad.
Nov 01, 2010 | Acer NSK8458AN Keyboard
On acer laptop how to use the green keys?
On my acer aspire 5551 it works if you press the ALT Car Button on the right site and the green key
Jun 25, 2010 | Acer NSK8458AN Keyboard
Green function key locked on acer laptop
Hey, I've just been having this problem. Try pressing CTRL + SHIFT + FN all at the same time. I found out that I had to press them once to turn on the green keys, and then press them twice more to turn it off. I hope that works for you.
Feb 12, 2010 | Acer Aspire 4530-5889 Notebook PC
Cant get rid of bilingual characters on acer aspireone netbook
Check your regional settings in the controll pannel. Your keyboard is probably set for "Canadian French"
By default it should just be set to US.
Jan 16, 2010 | Acer Aspire One PC Notebook
Hello,I just bought a Acer Aspire One netbook and have a problem.
This Happnd to me too jus press the
left alt key and shift together and this toggles the input language to English and it will work 100%%%
Sep 26, 2009 | Acer Computers & Internet
Chose Canadin French instead of Canadian English by accident
Yes you are right: it is a one time option. You can however install other languages. You will switch from the Canadian French keyboard to the US or English Canadian keyboard by pressing Shift Alt. You will console yourself if I told you that I type mainly in French, but the physical keyboard is US and I cannot even use the Alt + Ascii code to put the accents where due, because the laptop does not have numeric pad.
Hope it helps.
Sep 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Jun 02, 2009 | Acer Aspire One AOA110-1113 Netbook
Logitech cordless desktop mx 3200 laser keyboard - french characters
Its not the keyboard fault but your operating system. I'm going to assume you live in Canada and when you had setup the computer for the first time you had selected Canada has country you live in instead of the United States (default) If you notice on your desktop or taskbar there will be a keyboard logo. Click it and select US 101 keyboard (United states). You get the french symbols because microsoft thinks because you live in Canada you must be french canadian.... stupid eh! They have it selected to mulitlingual Canadian. Select the US English as default and you shouldn't get those french symbols when you really want the shift or question mark key.
I live in Canada and I see looks of people who ask me the same question all the time.
Hope this helps!
Aug 20, 2008 | Logitech Computers & Internet
Computers & Internet Logo
15,679 people viewed this question
David Payne
David Payne
