Question about Texas Instruments TI-83 Plus Calculator
Calculator Stuck My calculator is stuck on the same screen. The screen is a big jumble of letters, numbers, lines things that look like chinese characters, lines and dots. they are not in a straight line they are diagonal. The batteries are functional, they have been tested in other electronics and work fine. The calculator still turns on and off and you can still change the brightness/darkness. No button I push changes anything on the screen. Previously there was a blue line running across the screen when on that started to dissolve after a while but then came back on when I turned the calculator off then back on. I have no clue what the problem is. Please help.
Hi. I suspect your calculator BIOS is corrupted. Still looking for the download for that though. Do you have a USB link cable? If so, plug in your calc and check your device information. See if anything comes up.
Posted on Aug 16, 2007
E appear on screen, number keys not working.what should I do.
Customer Reviews: Canon MP11DX Printing Calculator
www.amazon.com/Canon...Calculator/.../B0006HWF...
Amazon.com, Inc.The keys (i.e., numbers) get stuck almost every time I use it. I have to actually wiggle the numbers so I can enter the next number. It's not the tape on the ribbon; ...
3 Using your calculator for fractions - The Open University
www.open.edu/...calculator/content-section...
United States Open UniversityMay 3, 2012 - Early Years ยท Working with Young People .... 11 Natural logarithms and powers of e on your calculator ... The figure shows the display on a calculator screen.... If your calculator is not in Math mode, repeat the steps of Activity 1. ... arrow keysto move between the boxes when inputting the mixed number.
[PDF]Canon MP270 series / MP250 series On-screen Manual
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
Can I reset ti 83 plus
Remove all four AAA batteries. Press and hold the ON key for at least fifteen seconds. Replace the batteries.
Sep 28, 2012 | Texas Instruments TI-83 Plus Calculator
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
I press certain letter keys and numbers appear, the number keys are fine just the letters, what is the fix for this error?
You have your numbers lock on, press the NumLk key and that should correct it. You will notice on you keyboard that there are small numbers on it below some of the letters, this is so you can use the keyboard has a 10 key number pad/ calculator etc. If pressing the NumLk key does not work, the key may be stuck or you have a bad keyboard
Oct 12, 2010 | Panasonic Toughbook CF-51 Notebook
Hi, My name is Ana and I'm still using my old TI-85 calculator for abt 13 yrs. The thing is last yr the screen started having the big black spot inside and covering almost entire scree. The calculator...
Hi
I fix all the TI calculators but i am in NY
its very hard to find parts for this model
it wil be better for you to buy a new
or used calculator in good condition
if you still want to fix the Calculator let me know
ecrdn@yahoo.com
Jack
Oct 11, 2010 | Texas Instruments TI-85 Calculator
When i turn on my ti-83 plus calculator, i have jumbled up things on the screen and i can only type half way on the calculator...when i put 2+3 it doesn't give me 5...when i press enter...it just goes down...
The Calculator need Os Update and Rom Reset and to clean the Ram
you need a Special cable and adaptor to fix this problem
if you want to fix this problem let me know
ecrdn@yahoo.com
Jack
Oct 11, 2010 | Texas Instruments TI-83 Plus Calculator
My TI-89 calculator turns on, but gets stuck on window editor
If you're willing to have all RAM cleared, try a hard reset.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Feb 20, 2010 | Texas Instruments TI-89 Calculator
Jumbled Numbers/Pixels
I had the same problem but i finally found the solution i held my calculator at gun point and told it to stop messing with me.
Nov 11, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
841 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
