Question about Hoover Washing Machines
How to replace motor brushes - Hoover Washing Machines
  • pam23 Nov 15, 2008
    Hi pedropony2,
    Thanks for your response. Have now replaced the motor brushes. Did not need to remove the motor. After removing the top cover, the motor and access to brushes was easy.
  • 135 Answers
Revove back plate & take belt off.Motor is held by 2 screws. unplug wiring block and earth wire then remove motor. on rear of motor are 2 plastic housings which hold brushes. make sure new ones sit correctly on armature then refit motor.
Posted on Nov 15, 2008
Bissell Proheat 1383 removing brush motor to replace it with a new one.
May be a burned out collector of the armaturebetween the brush holder and armature ballbearings are maybe poor change the motor , and replace allways 2 brushes if its possible because 1 fieldcoil stator of the motor should have a problem if 1 brush is shorter than the other brush there is a disbalans with 1 long and a short brush , in the early years 50 60 or the more expensive vaccuums like Kirby 600 W motors
it is useful to change brushes buit in 60% of the cases you lost the brushes again in 1 month .
Oct 29, 2015 | Vacuums
How to replace the carbon brushes please.
After procuring the correct replacement brushes simply unscrew the plastic cap securing the brush to the motor, remove the old brush, insert the new one and secure the cap to the motor. You will have to run the motor a while for the new brushes to seat properly so don't expect the motor to produce full power instantly.
Jul 15, 2015 | Kymco Maxi XL Mobility Scooter
What results happens when motor brushes are going bad
Based on your description you should purchase new motor brushes for both motors and replace them. This will be a short term improvement. You should block up the chair in the air and run in the brushes by taping the joystick forward and running the motors forward for 1 hour and in reverse 1/2 hour NO LOAD. This will seat the brushes on the armature, that is, get a curve on them. If your budget allows, prepare for motor gearbox replacement in the next year.
Jul 23, 2014 | Pride Jazzy Select Hd JSELECTHD
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
Motor on mod 51591 died, nedd replacement
The Mamco motor is WAY too much money.I bought brushes on E Bay and made them fit. #51591 takes 1/4 " square brushes.
Nov 28, 2009 | Toro Blowers Rake and Vac - Electric...
Hotpoint BHWM129. Cannot change brushes.
there are no brushes in that kind of motor
Aug 16, 2009 | Washing Machines
"CHANGING CARBON BRUSHES ON A DYSON VAC"
Solent Tools have a full range of Dyson brushes available. Tel 023 8057 8057. www.solenttools.co.uk
May 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Need to replace carbon brushes on Indesit Omega 1200
The brushes are located inside the motor. Remove rear panel of washer, remove drive belt, from motor and drum, unplug the motor, undo screws that secure motor, and remove motor.
At the opposite end to the motor pulley, you will find the brushes located, undo 2 screws that secure the brushes, remove and replace brushes.
I would also check the pump filter, which should be located behind a removable panel at bottom of washer, unscrew anti-clockwise, remove and clean.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Indesit W 123 Front Load Washer
Bosch wfr2460
hi Many universal motor malfunctions are caused by wearing down of the carbon brushes, the soft blocks of carbon that complete the electrical contact to the motor's commutator. When these brushes become worn, the motor will spark, and electrical contact may be incomplete.try this
Step 1: To sight-check the carbon brushes, remove the screws that hold the brushes and brush springs into the brush holders at the sides of the commutator. The screws will pop out of the screw holes; turn the motor over to tap out the brushes. The ends of the brushes should be curved to fit the commutator; if they're worn down, new brushes are needed.
Step 2: To check carbon brushes with a continuity tester, remove the motor lead wires from the circuit. Tag the wires as you disconnect them so that you'll be able to reconnect them properly. Hook the tester clip to one motor lead and touch the probe to the other lead; the tester should light or buzz. Slowly rotate the motor shaft, keeping the tester in position. If the tester doesn't light or buzz, or if it flickers or stutters when you turn the motor shaft, the brushes should be replaced. If the springs behind the brushes are damaged, they should be replaced as well.
Step 3: Replace worn carbon brushes and damaged springs with new ones made specifically for the motor. The model information (number and make) is stamped on a metal plate fastened to the motor, or embossed on the metal housing of the motor. If you can't find the model information, take the worn brushes and springs with you to an appliance-parts store to make sure you get the right kind. Insert the new springs and brushes in the brush holders, replace the brush assemblies, and secure the new brushes with the mounting screws that held the old brushes.
Sep 13, 2008 | Bosch Axxis+ WFR 2460 Front Load Washer
Bissell upright vac, brush on bottom does not rotate
The front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
May 21, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Washing Machines Logo
85 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
