Question about Western Digital (WD3200JS) 320 GB Hard Drive
80 gb hdd could not be detected any how. i have tried every possible way. but could not succeed. i have imp data in it & i want to retireve. Please help
  • 55 Answers
first boot the pc and enter bios setup then see it shows the your hard disk if not then
plz check the jumper settings for proper way to attach the hard disk to pc. here is another way to operate your hard disk to use this hard disk only one data cable. another peripheral like cd rom and dvd you have to remove.
if you do all this then check it another pc and copy your data to another pc then you use the pen drive or external hdd to backup
thanks
ramesh
Posted on Nov 15, 2008
Cant be detected
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
Aug 19, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
I need to open my Toshiba Canvio portable disk.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
Aug 16, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
I have seagate 500 gb external HDD. Now when i m trying to connect it with my laptop it gives me error as "You need to format your disk before you can use it" . Please help me in my HDD i have...
Hello!
I suggest you to download Recuva. When you run it the first time a wizard will help you to setup everything you need to restore the lost data(if it`s recoverable).
Good luck
Mar 18, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My Iomega HDD 80 GB not detected and become noisy, so pls help
-it sounds like your external drive had a head crash. The noise is normally grinding noise.
-if your data on the drive is priceless, you may need to consult recovery experts like http://www.drivesaversdatarecovery.com/.
Dec 18, 2010 | Iomega HDD External Desktop (32660) 80 GB...
St3160827as seagate hdd is not detecting in bios , other new seagate hdd is working fine with the same connection(sata cable and power card) I have imp data in that hdd ,pls help me how to get data...
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
Bad Sector Failure
Simple thing is u hav to boot with XP cd
http://support.microsoft.com/kb/315265
do this procedure
May 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
HDD PROBLEM
Raj...
A few questions..
Is it external/internal drive
what kind of data connector does it have... USB, Wide ribbon cable or 6 pin sata
Has this drivbe got windows or linux on it, or is it just used for data.
Jul 30, 2008 | Toshiba MK8025GAS 80 GB Hard Drive
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Problem in Harddisk
Does it make any sounds like any of these?
Does it spin up at all?
Apr 29, 2008 | Samsung (SP0822N) 80 GB Hard Drive
Western Digital (WD3200JS) 320 GB Hard Drive Logo
94 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
