Question about Tools & Hardware - Others
My nailer blows out air when I connect to the hose.
My nail gun blows out air by the trigger once I connect the air hose.
  • Anonymous Mar 23, 2014
    chn20103 nailer will not shoot nailes the gun blowes air out of it
    An expert whose answer gotĀ voted for 100 times.
  • 185 Answers
Have you been lubricating it regularly with nail gun oil. We use framing nailers every day at the commercial tree farm I work at and one of the operating instruction is to put 6 to 8 drops of oil in the air hose connection on the nailer before every use. I suspect the O ring on the piston is worn out/
Hope this helps Good luck Loringh PS Please leave a rating if appropriate Thks
Posted on Nov 16, 2008
  • Loringh
    Loringh Nov 16, 2008
    not sure if I sent this the 1st time
Keeps repeating itself
Most nailers have a two position setting on the trigger to allow for single fire or bump fire. If set on bump fire, the gun will work better when you bump fire the gun instead of placing the gun on the work then depress trigger. Bump fire works best when safety spring has good tension. Easy test. Make sure that the safety spring is in place (with air hose removed, contact foot should spring back quickly when pushed against work). With air connected, hold trigger and quickly bounce the gun against the work. If the gun does not fire when you bump, the trigger is most likely set to single fire. With trigger set to single fire, you must place the gun against the work, then depress trigger. If the gun shoots two nails while set to single fire, most likely worn trigger or worn out trigger valve. These parts are not expensive and are easy to replace. Good luck
Apr 12, 2013 | Dewalt D51321 3/4" 1 3/4" Heavy Duty Coil...
Nail gun will not shoot a nail
Check the safety trip make sure it is pushing back far enough. If it doesn't then it won't do anything. When it was fine just moments earlier.
Feb 05, 2013 | Dewalt D51822 Clipped Head 2Inch to...
Porter cable FR350 round head nailer type 2 fires when it is connected to air hose and won't fire afterward
Various nailers will fire on their own when connected to air if the orings have become hard or worn and internal trigger valve parts worn-out (mostly Dewalt and P/C). You could buy an oring kit or purchase trigger valve seperately. Replacing trigger valve and lubing the headvalve with white grease will most likely solve the problem. After repairing the gun, be sure to remove the nails from the mag after each use to prevent possible discharge of nail. Good luck
Oct 21, 2012 | Air Tools & Compressors
I have the 2 1/2 Hitachi for nailing siding. The nail gun had not been used for a couple of years, but now will only drive the nail half way in. Sounds like an air leak when driving the nail. I have...
Remove the nails and air supply. With side door open notice position of driver. Driver should be at top position with tip not visible. If driver is down and it moves within cylinder when you tilt nose up then down again, time to replace orings. If driver is down, it should extend past the nose about 1/4 inch (if driver is broken at the tip the end will look rough and nail will not drive in all the way). If driver extends past the nose more than 1/4 inch then lower bumper may be breaking up /cracked. Easy test for proper function. With nails removed and side door open, connect air to gun and dry fire gun against hard rubber or old coiled air-hose (with air connected and trigger depressed, no air should leak from trigger area, if air leaks when trigger is depressed, look for fault at trigger pin). Feeder should move back then forward in quick motion almost matching speed of driver and driver should not creep down between shots. No air should leak from nose of the gun (push nose against hard rubber and depress trigger and hold in this position, driver should stay down with very little or no air leaking out of nose, when you release trigger, driver will return). If air leaks out of nose while holding in this position, replace lower bumper. If a quantity of air leaks from valve in front of trigger, cylinder orings may need replacing or outer part of cylinder has fine scratches (remove scratches with 400 grit paper). Parts are available at Good lucki
Apr 16, 2011 | Nailers Hitachi Nv83a2 3 14" Coil Framing...
Bostitch RN46 will not fire nail, only releases air when trigger is held and firing tip is touched to surface of material. Any ideas on what is wrong?
Gun will not fire if air is leaking past orings in head /headvalve or safety /trigger is not pushing trigger pin all the way into trigger valve. Test: Remove trigger to expose trigger valve pin. Remove nails. Place nose of gun against thick rubber mat or coiled rubber hose to absorb blow of driver. Very quickly and deliberately press trigger pin all the way in. If gun fires, safety foo or trigger is not pushing trigger pin all the way in. Make adjustments or replace worn parts. If gun still does not fire, remove head and pull out headvalve. Apply lots of silicone paste lube on the orings and the surface of the head where orings make contact. Reinstall head and test as above. If the gun fires then orings were leaking. Replace orings and sand any scratches on body of cap with very fine sand paper. Parts are at Good luck
Mar 06, 2011 | Stanley Factory Reconditioned Bostitch...
My nail gun will not fire a nail. Do I need to oil it or something?
Hello, W/D here.
Here's a couple of things to do or check:
1. Put a couple of drops of a light oil in the nailer with the trigger depressed, and the gun disconnected from the hose. Set it to the side for now, with the air inlet facing up.
2. Check the compressor outlet pressures. The gauge nearest the tank is the air pressure on the tank. The gauge closest to to the hose is the tool supply pressure. Between the gauges id the regulator, where you can increase or decrease the pressure to the tool.
3. Check your required air pressure for your nailer, and make sure that your regulator is supplying at least that much to operate the nailer.
4. Connect the nailer to the hose, Spray the underside of the nailer head (the slide assembly where the nails are driven) and try to drive several nails into scrap wood.
5. If the nailer operates properly, all's well. If it still fails to operate, place a few more drops into the air inlet (while holding the trigger down) and wait a few minutes, then try the gun again.
There are other things that can be done, but oiling the nailer should get you going. BTW, you should oil the nailer before each use, and when you put it away.
Best regards, --W/D--
Jan 29, 2011 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
Nail gun doesn't shoot and air blowing out vent constant.
We used nail guns for years. I still own 6 guns, but they aren't used much anymore.
You have a 'blown head gasket.'
Or there is debris from the air hose that got lodged into the gun.
There is a head gasket and a trigger gasket.
Both can blow out any time from use, lack of oil, or they can stick open from debris.
You can take apart the head and clean it up and add oil to see if that solves problem.
You can order a gun re-build kit for your model and put in the parts yourself.
You can have a nail gun repair shop do the job.
Nail guns require gun oil.
If you don't use gun for a while, oil should be put into air hose opening and then left to run down into gun. More oil is better.
If you use 3-in-1 oil or some oil besides gun oil, then it will corrode the gaskets.
When storing air hose and guns, put tape over openings so they stay clean.
Before hooking air hose to a gun, you can also put a blower on hose and blow out the line first
Oct 21, 2010 | Dewalt Round Head Framing Nailer D51845
Can I change the pressure on the nail gun?
Hi there .
First check if the nail gun have a adjustment screw . Depending on the brand could be in the front where the nails comes out or by the trigger. Second check the compressor by the air hose connection you should have a regulator valve with a gauge and see if you getting the right air pressure .
Hope this help
Aug 29, 2009 | Air Tools & Compressors
Once trigger is depressed, air leaks and no nail is fired....
Sounds like the trigger o-ring is damaged, either because of not being oiled frequently, or the pneumatic tool has not been used for a while. O-rings will harden up if not used. Look for a place that sells fasteners, or nails and see if they can put a new o-ring in the trigger asm. for you. If you take the gun to a place where you purchase your nails, they should repair for little or no cost. it is an easy repair if you have the tools, parts, etc.
Feb 05, 2009 | Dewalt Round Head Framing Nailer D51845
Tools & Hardware - Others Logo
563 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
Tom Chichester
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
