Question about Yahoo Messenger
Downloading YM 9.0 it goes to 100% and never prompts completion
In the beginning it goes from 0% to 5% and the back to 0% then it goes to 1%, jumps to 10%, 2%-15% etc. then after about 15mins it will go directly to 100%. After hours of waiting it never completes but it continues to say 100% and is still rinning in the task manager window. I have dial up, and vista is the version of windows on the pc i have stopped anti virus software other programs that are unnessesary in the process tray, turned off screensavers deleted previous versions of the messenger. I have run out of ideas i tried the vista version of messenger it doesn't suit my need u can't go into chat rooms, so it doesn't work for us.ANY HELP PLEASE?
  • 10,515 Answers
Hey,
it might happen if you are trying to download yahoo messenger directly from yahoo.com.
You may use software sites to download yahoo messenger version 9 and more likely it would work n vista.
One of the link is :-
http://www.download.com/Yahoo-Messenger/3000-2150_4-10029188.html?tag=mncol&cdlPid=10888512
I hope it wl slve ur question.....
Posted on Nov 15, 2008
This is what my question says. some scientists estimate that there are 100 billion stars in the milky way galaxy.In standared form,100 billion is 100,000,000,000. write 100billion in exponential form.
1=10^0
10=10^1
100 (2 zeroes after the 1)=1x10^2
1000 (3 zeroes after the 1)=1x 0^3
1000 000 (one million) =1x10^6
1 billion =1 000 000 000 =1x10^9
100 billions =100x 1000 000 000=(1x10^2)x(1x10^9)=
1x(10^2)x(10^9)
Now use the power multiplication rule (a^n)x[a^m)=a^(m+n). Thus
1x(10^2)x(10^9)=1x10^(2+9)=1x10^(11)
100 billions =1x10^11=10^11.
Sep 10, 2013 | Computers & Internet
Contrast really dark but seems to improve after the tv has been on several hours
Hi:
You may have a problem with the inverters in the unit, they are responsible for lighting up the back panel. Check or have checked the power supply voltage to the inverters, should be around 18-24 volts DC. Also leaky capacitors on the power supply will cause this issue as well as leaky or puffy capacitors on the inverter.
Sep 08, 2011 | LG 32LG30 32 in. LCD HDTV
I have just installed the yahoo messenger, downloaded from yahoo website. Its YM 9. After installation as i'm clicking on shortcut to start messenger, each time following error...
Uninstall YM 9
Install Yahoo! Messenger 10 instead by this link:
http://rd.software.yahoo.com/msgr/10/msgr10us.exe
When prompted, save the .exe file to your desktop. Then double click the Yahoo! Messenger 10 file on your desktop to begin installation.
Please rate.
May 27, 2011 | Yahoo Messenger
Vuze indicates that a film is downloading, but stays at 0 % and doesn't actually download the desired film
How do you say that it indicates a film is downloading?
If you just see that something is getting downloaded, it may be downloading it's updates. It does that often. Just let it be for a while. It will complete the update, then ask you to install it. After you install it, it will ask for a restart and then your download should begin.
There might be some way to turn off the automatic update of the software under tools>options, but you will need to look on the web for that as I stopped using vuze a while back, since i switched to 'Tixati' which is much lighter and with better options of downloading a file with head/tail first and sequentially, so that, even a 1.3 GB movie file can be viewed for quality when just about 50 to 100 MBs has been downloaded.
Mar 05, 2011 | Computers & Internet
Use digits to complete the two different 6 - digit numbers each number has 7 units, 3 thousands, 9 hundred thousandss and 1 ten answer: _ _ _ _ _ _ _ _ _ _ _ _
Solve the following equation, for X between 0 and 9, inclusive,
and for Y between 0 and 9, inclusive:
7*1 + 1*10 + x* 100 + 3*1000 + y*10*1000 + 9* 100*1000
How many different answers are possible:
(a) none
(b) 10
(c) 20
(d) 99
(e) 100
(f) none of the above
Nov 29, 2009 | The Learning Company Achieve! Math &...
Not able to access our main voicemail on Vodavi Starplus STS
To access the System Administrator Mailbox:
1. Dial into voice mail: From any phone on system dial 150
2. When the system answers, dial [*] + [#] followed by the System Administrator Mailbox number: (# 0 0 )
The system will announce: “Mailbox 15-00”, which is the System Administrator Mailbox number.
3. When requested, enter the System Administrator password. Default = [9]+[#]+[56].
How to program greetings
1. Access the System Administrator Mailbox as described above. The System Administrator Mailbox Menu plays.
2. Press [1] to access system greetings. The system will prompt you for the greeting number
3. Enter the desired greeting number.
For example:
1 = Default Day greeting
2 = Default Night greeting
3 = Default Temporary greeting
4. You will be prompted with the following three choices:
Press [1] to Review.
Press [2] to Record. You will be prompted to record the greeting
When you finish recording, press [#] to save the recording.
You can then
Press [*] + [*] + [*] to exit the system completely
Jul 07, 2009 | Vodavi Starplus SP7314-08 Corded Phone
Yahoo messenger 9.0
did you uninstall the previous ym first before installing beta 9 of ym?
uninstall the old ym first then.
download a clean copy,
http://messenger.yahoo.com/win
before starting to install, try to disable momentarily your firewall.
seeif there are many memory resident in your computer that's consuming theresources of your computer. tune up utilities 2007 should do the trick
http://www.download.com/3150-2094_4-0.html?tag=404
Oct 12, 2008 | Computers & Internet
Yahoo Messenger will not load
I have a desktop computer and downloaded ym 9.0 for vista it loaded but will not pull up when i click on it it freezes.
Sep 26, 2008 | Yahoo Messenger
Software
Here is the link where you can download the drivers for your printer
EPSON
You will have to donload 2 driver, the printer driver and the TWain driver and epson scan utility for your operating sytem
Pls dont forget to rate solution, thanks!!
If you have issues still feel free to email me back
For scanner
Install
1. Go to www.epson.com/support
2. Under Welcome to Epson Support click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Select and download the most current Epson Scan driver for your operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it will be easy to find.
5. Once download is complete, close your internet browser. To install simply double-click the file you downloaded and follow the prompts.
6. Turn your unit on and reconnect it to the computer after the installation is complete. Windows should detect new Hardware and complete the installation automatically. (If a New Hardware Wizard appears, allow it to search automatically.)
7. Restart once installation is complete.
Once the computer has restarted you are ready to scan. We recommend starting with a test of Epson Scan itself. Simply go to Start, (All) Programs, Epson Scan and launch the Epson Scan utility. In File Save Settings you can select the location, prefix (name) and format the scan will be saved as. When ready click OK or Scan and the scanning process will begin.
Installation
2. Under DOWNLOADS AND SUPPORT click on ALL-IN-ONES and select FLATBED and then your Stylus model name. Under the Drivers & Downloads section select WINDOWS.
3. Download the most current driver for your printer and operating system.
4. Follow prompts through survey and license agreement and downloading will begin. When prompted, choose to SAVE this file; SAVE it to your desktop so it is easy to find.
6. Do not reconnect the unit until the point in the printer driver installation where you are prompted to check that the unit is on and connected to the computer. Installation should complete automatically.
May 01, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Yahoo Messenger Logo
95 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
