Question about Initial IDM-1731 Portable DVD Player with Screen
I put in a DVD and it says NO DISC.
I put it in a DVD and it says NO DISC. I don`t know what`s wrong. The dvd's i used are all made in the U.S. So I don`t understand why it isn`t working. Someone help me ASAP. PLease.
  • 1 more comment
  • Anonymous Jan 27, 2008
    I put a DVD in and i bought the Portable DVD player on Ebay and no tpe of dics work...
  • dlhank Oct 24, 2008
    Everything works, except it does NOT recognize the disk. Poo.
    What do you want for such a cheap price, I guess. Never buy another one.
  • horaciso Jan 19, 2009
    my dvd will not read but it plays my audio cds
1st, I think the term 'Expert' is used too loosely here, at least for me. LOL. I just had the pleasure of fixing an IDM-1731 with a 'No Disc' error. It just so happens that calibrating the drive helped me out.
For any of you that feel like taking a risk & opening up your player, I urge caution when handling the optical lens. There are 2 pots located above the ribbon on the end that connects to the lens to the left. The 1 on left I touched to the right & that helped me out. I'm thinking that the vibration caused the player to get out of whack as time goes on.
After getting the player to work, I took measurements with my multimeter. The left pot measures 3.06 k ohms & the right measures .965 k ohms. I hope this helps others out as it did for me.
Posted on Nov 15, 2007
  • Robert M Dec 07, 2007
    I want to add that since components vary, your pots may need to be adjusted differently. In short though, your CDM-1731 could need calibration. My measurements might give you ballpark figures to start at & from there you have to play around.
SOURCE:
2 symptoms; don't know if they're related or not. For some time now, when trying to watch a movie on my small screen Coby Portable DVD player, it will play just fine for about half the movie, then...
I'm sorry that the DVD player is not playing discs are expected. Based on the information you have provided, it appears that the Lens head of the DVD player is dirty. I suggest that you use a lens cleaning disc to clean the lens head and it should resolve the issue.
Thanks for understanding.
Please let me know if the issue persists.
Nov 14, 2011 | Coby Televison & Video
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Just got an RCA TV from a friend. It is the 32 inch DVD combo. The DVD player isn't working. I can slide the DVD in and it will attempt to play it but it can't seem to read it. Does anyone know how to fix...
Now u put in a DVD movie disc into the DVD player slot.The DVD disc still register on the tv LCD screen,but just don't read the DVD disc?Yes.Tries websites like Amazon.com,Ebay.com to buy a DVD cleaning disc kit to used to clean the DVD laser eye of the DVD player slot,after this it should work.If tv still have the same result,than this tv problems DVD player slot can't be fix or worth fixing because the DVD player slot laser eye is bad or dead alredy.
Apr 24, 2011 | RCA L32HD32D 32 in. LCD HDTV
Will not record on blank dvd and rejects some saying disc error
In the past, when that occurred to me, I either had the wrong type of DVD disc or it called for a unused DVD disc to be put in. Be sure you are not using a CD disc.
Oct 29, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
Burned a movie on pc dvd player cant read disc
Most AVI files from the torrent network use codecs to compress the size of the file you are downloading, and most DVD players only support the basic DIVX codec. A way to get around this issue is to use Nero software on your PC to burn a Video DVD. Selecting this option will make the program decipher the data and write it to the dvd as a compatible format with your standard DVD player.
Jul 16, 2009 | Apex Digital AD-1110W DVD Player
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
May 03, 2009 | Spectroniq PD-1100 DVD Player
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Initial IDM-1731 Portable DVD Player with Screen Logo
153 people viewed this question
Top Initial Televison & Video Experts
Steve Allison
Steve Allison
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
