Question about Refrigerators
Refrigerator has uneven temperature from top to bottom
Compressor seems fine, freezer seems fine but a bit frosty, refrigerator is colder at the bottom than at the top. I can only assume the fan has packed in but can't access it. The back of the unit is completely sealed so I went in through the interior. I got the plate loose with the vent holes in it, but it appears to have a wire connected to what looks like it might be a thermostat, taped to the rear. Any suggestions?
    Genius:
  • 1,122 Answers
If frost is building up in your freezer you have a defrost problem,is the freezer fan working?can you remove the freezer panel so you can check the defrost heat and defrost sensor?and last check the defrost timer in the frig. or on the front or back of frig.,let me know what you find-mike
Posted on Nov 15, 2008
Freezer working, refrigerator not
Hello Georgia Peterson - Do you hear anything running in the machine compartment and what type of airflow is the condenser fan providing (try removing the toe grille, located above the drain pain on the bottom right-hand side)? If you do not hear the compressor and unit is providing room temperature, it usually means that the unit has a faulty compressor or a sealed system leak. Also there is a vent towards the back of the freezer that circulates air from the freezer section to the fresh food section. If this vent is blocked by too many items in the freezer it will cause the unit to work harder making it colder in the freezer and keeps the air from flowing down to the refrigerated section. If you would, make sure that the vent is not blocked so that air can travel from the vent down to the refrigerated part. This will decrease the temperature in the freezer, allowing for ice cream to be pliable and the fresh food section to become colder. Should you find these suggestions unsuccessful I would recommend contacting a professional to move forward accurately.
Jan 13, 2013 | Frigidaire FRT21H8 Top Freezer...
Freezer and refrigerator are not very cold
if it is a cheap refrigerator the compressor may not be able to handle keeping both areas cold at the same time... try turning down the fridge temperature to see if the freezer then gets colder.
Jul 26, 2012 | Whirlpool Refrigerators
The refrigerator is getting warmer in the top & getting Frosty in the freezer..do not have a owners manuel ..the numbers inside show the setting by the number 3 has a * does the refrigerator get colder...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 04, 2011 | Refrigerators
Hi I have a FFa71 fridge freezer and the freezer is too warm, the high temperature light is on and the fridge seems to be getting frosty, I cant hear the fan any more.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 16, 2011 | Hotpoint Refrigerators
Refrigerator less than two months old. Freezer side fine refrigerator side stopped working altogether. All food ruined. Who should I contact. purchased from Home Depot.
This is a very common issue, If the freezer compartment is cold and making ice the
problem is simply airflow from the freezer into the refrigerated section.
Typically when one senses the refrigerator is warm they max out the settings
on both dials the thermostat with its 1-10 settings as well as off for the compressor.
This controls the compressor and temperature.
The additional setting or dial is for colder freezer or refrigerator as well , However
it simply opens or closes a flapper door between the freezer and refrigerator boxes.
When that dial or setting is maxed , it closes and makes the freezer colder, yet leaves the refrigerated section starved for sufficient airflow to maintain a cold box in the refrigerated section.
Just set the dial that does not turn the compressor off to the middle setting.
One can leave the thermostat that does control the compressor in the max setting , just not the colder freezer setting, If you notice colder isnt colder refrigerator, Its actually colder freezer, A common issue found on 25% of all refrigerator calls a simple setting adjustment.
Its easy to think that maxing out the settings makes for a colder refrigerator, it doesnt, it makes a colder freezer and warm rerigeration section.
If a freezer is making ice, theres nothing wrong with the unit other than airflow setting.
Add a comment
Dec 24, 2010 | Maytag Refrigerators
My GE TFX30PP is constantly running and doesn't turn off. The freezer is very cold but the frig side isn't cold enough. A repair guy put in a new "cold contol" sensor but it didn't help.
I would also clesan the condenser coils off.
Add a comment
Dec 24, 2010 | GE Profile Performance 29.8 cu. ft....
Refrigerator does seem like its working right
Your refrigerator compressor is either pumping or it is not. Set the refrigerator to low temperature, pull it out and listen for a while to see it the compressor is coming on. If it is coming on then there may be a freon leak or the internal coils may be iced up. If it is not coming on, then either there is no power to the coompressor, or the compressor itself is defective. Use a voltmeter at the compressor to check for voltage. There is also an add on device to start stuck compressors from your local HIVAC jobber store.
Jun 07, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
FREEZER TOO COLD - REFRIGERATOR TOO WARM
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 30, 2008 | KitchenAid KSRG25FK Side by Side...
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Refrigerators Logo
1,262 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
