Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Tecumseh engine wont run right
I have a 1960's tecumseh 10hp engine that that back fires out the carb and it does run for a little bit but it dies after about 5 min it will not throttle up it just dies it has good compression and it does not smoke i have also checked the flywheel key it is not been sheared i am lost on this thing please help.
  • znj_akes Nov 16, 2008
    i bought it from a guy who said he used it up tell august then it started running funny i have rebuilt the carb and have set the mag gap to specs but for some reason it will just idel if i try to throttle it up it just dies
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 185 Answers
Znj_akes:
Has this engine been inactive for a long time?? If it has, mMaybe the carb is gummed up.
Any chance the position of the magneto has changed? A second thing you might check (especially considering this is a 1960's vintage) is the gap between the mag coil and the actual magnet is fouled with dirt/rust. That gap is usually about the thickness of a dollar bill.I have used fine sand paper in that gap to clean it,
Hope this might help Loringh
Posted on Nov 15, 2008
  • 3 Answers
Have you changed spark plug? When they backfire through carb. it usually means too lean( not enough fuel, partially cloged fuel line) or weak or out of time spark. joedog
Posted on Feb 26, 2009
Problem with Tecumseh oh160 carbeurator
NO ONE EVER PUTS ENOUGH INFO IN THEIR QUESTIONS!!!
...SO..I'LL GUESS: STARTS AND RUNS, THEN DIES...RIGHT?
TRY MY "ON THE MACHINE CARB FIX:
REMOVE AIR CLEANER TO ACCESS MOUTH OF CARB
SPRAY CARB CLEANER UNTIL YOU FILL FLOAT BOWL, AND IT STARTS TO RUN OUT OF CARB
LET SIT OVERNIGHT, DO IT AGAIN...WAIT A WHILE....THEN REMOVE SPARK PLUG, POUR A SMALL AMOUNT OF GAS INTO PLUG HOLE...REINSTALL PLUG...IT SHOULD FIRE UP AND START RUNNING RIGHT.
IT MAY TAKE A FEW TRIES! IF NOT REBUILD CARB, BECAUSE A FLOAT HAS PROBABLY SANK
Dec 18, 2013 | Garden
5 hp tecumseh no power
you need to remove carb for cleaning... if it has an adjustment on the bottom of carb try turning it SLOWLY in and out... also possibly a screw on the side under a black cap... might try it as well engine model number would help here
Dec 11, 2013 | Tecumseh 5hp Engine Snow King Mtd Blowers...
5.0hp tecumseh power sport wont start
you have to take the bowl off the carb and see if the Jets are clogged.
How long did it run before you shut it off?
Oct 04, 2012 | Garden
Bike stalls out when gets hot.done oil change ,coil, sparkplug,intake to carb boot, air filter, im outta ideas, cause it goes fine just dies when it heats up,but after it cools fires right up again enough...
i just got a buell 2001 blast had been stored for a while had little bit of bad gas so i cleand the carb out still would die so i askd a tech at harley he said 99% positive that it was the slow jet its a 3.95 part inside the carb take out the old slow jet and replace it with a new 1 cuz u cant clean it out good enough cuz its little pin holes i put new 1 in and it runs like a champ now the guy said no need to rebuild carb just new jet and ull probly be all good my bike would start idle for a min then die and the tech said if that jet is plugd bike wont hold a idle its the jet screw deep inside the carb pull the carb take the bowl off the bottem then ull see the jets hope it helps you out
Aug 18, 2011 | 2001 Buell Blast
Engine idles smoothly but at higher rpm it faulters and back fires out of exhaust and runs rough
back fires out of exhaust implies too much gas at high end. caused by : dirty air filter, carb setup wrong(high float), ignition trouble.
a miss from poor ignition on the next stroke can be too wet even when the carb is set too lean so rule out the ignition problem. rule out the air filter problem. clean carb.
Apr 29, 2011 | Tecumseh Garden
Hot muffler
You got a couple of geniuses answering your questions. When he says it is getting red hot, he means that it is glowing red. Hot air passing through the muffler from a normal running machine does not make it get red hot, mowerman. And there are more reasons then the 2 you list mrfixit. The likely problem is your jets in the carb. It sounds like it is running to rich. Play with the little screw on the carb a bit. I think you would have to turn it in a bit. Wish you luck.
Sep 21, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Tecumseh 17.5 hp ohv engine won't start
check valve clearance. if ok you going have change carb.sometimes i rebuild a carb everthing seam ok but carb wont work right so i have get a new carb and it works fine evertime
Jul 20, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I recentley bought a Craftsman 4.0 HP mower at a yard sale, tested it before taking home and it fired right up. It did run a little rough so I replaced the air filter & spark-plug. Once again it fired...
You need to disassemble the carburetor and spray the with carb. cleaner. Make sure all small debris is out. Ckeck any gaskets for signs of ware. If they look bad, replace them; your carb. could be sucking air if so. Also check the fuel filter to see if gas is flowing through it.
Jim
Jun 09, 2009 | Craftsman Woodstock Percussion Crcbm ...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
1,083 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
