Question about Tomtom GO 700 GPS Receiver
Formatting a tomtom go 710
Hi, and thanks to anyone that can reply, my tomtom has develped a fault since an update from tomtom home - the fault is that every 5min or so it freezes then reboots. I've followed tomtoms advice of backing up and reformatting the drive, then copying the back up to my tomtom but the problem still exists.
This is my question.
Can i unistall tomtom home from my pc, then connect my tomtom and reformat the device/sd card with no back up, then disconnect my tomtom, go to tomtom download tomtom home, then connect my device and install the relevent software to make the device work and then install my purchased map? Then later install voices and poi's ect.
I'm basically asking can i start from scratch with just a tomtom formatted 710 and 2mb sd card and a pc.?
Any help welcome.Still need a solution for this problem?
  • mjgeen Nov 15, 2008
    i have the same problem, it seems to be on a loop, cant get past the legal notice, also when i tried to reinstall by software, it says its a 510 no 710
    Novelist:
  • 158 Answers
Hi, I probably cant answer all of your questions but I might help with some of them. You should be able to access your TomTom 710 without removing TomTom home software from your PC. It should be accesses as a drive through the USB connection in "my computer" on your PC. When a USB device is connected to your PC it appears as an external drive. Therefore you should be able to delete , load onto , or format the TomTom hard drive ( or with some other models the SD card ) as you would a normal drive . ( an example of this is where you might have a camer with SD memory card and relevant manufacturers software on your PC . you might connect your camera to the PC via USB and the camera software on your PC automaticly detects the camera for it to eb accesssed . However , the camera and it's SD card can also be accessed seperatly by going to "MY Compter" and it should also be visible there as an external UDB device / external drive ) . Now .. to another another question . If you do un-install TomTom home , I dont think it will also delete any backup of your TomTom , it will only delete TomTom Home software . ( the word "think" is mentioned because I have never tried this ). Besides that , you can choose in tomtom home , where you want any backups to reside , so you could save backups via TomTom home to a CD for istance. If you did that , then you would have the backup on a CD rather than your harddrive which means you could safely un-install TomTom home knowing that if it also removed any saved backup you would still have the CD with a backup on it. So , to summerise.... If it were me , I would make a backup of the TomTom by simply copying all the files on it by opening the TomTom up as a folder in "MY Computer" , simply drag any files and folders from the TomTom into a folder I have prepaired ( call it for instance "my tomtom backup" ) on my PC . Then I would format the TomTom drive then reinstall the backup and see what happens. If the TomTom still doesnt work properly , I would Format the tomtom again then use TomTom home to obtain all relivant files , then copy only the maps and .MAC files ( these are the authorisation files for the maps ) from my Backup to the TomTom manually ( not from tomtom home ). I would guess that would result in a working TomTom again ... Good luck.
Posted on Nov 16, 2008
2 Suggested Answers
  • 171 Answers
SOURCE: Tomtom Go 710 - help
The answer is Yes. I would make sure to have a backup on your PC. Uninstall TT home make sure you delet all of it. Reformat your card then install TT home. Connect your tt and let TT home reinstall your navcore. You may need to reconnect your tt a couple of times to get it updated to the newest navcore for your device. I believe it is 7.903. If you want to keep the older navcore just don't load the new one. Then install your maps as you normally would. I have just used this method to get the latest navcore for six 710's.
Hope this answers your question
Posted on May 03, 2009
How do i do a software update on my tomtom 710
Plug it into your pc go to tomtom home, the program will do the rest
May 31, 2012 | Tomtom GO 710 Car GPS Receiver
How do i update the software for my tomtom 710
Hi, plug your device to your pc, see if you have tomtom home installed, if not install it, then when installed just do a update....simple
May 31, 2012 | Tomtom Maps Software
TomTom Go910 does not restart after TomTomHome update version 2.6
i had a similar problem with my go 710, there is a new version of tomtom home to download now, try that first also i have vista on my pc and when i put my tt710 into the dock my computer asked me to scan the drive as there were problems, i did this and wehey bobs your uncle, good luck
Aug 04, 2009 | Tomtom ONE GPS Receiver
I lost the dock that connects to the computer
Your only option is to purchase another Home dock for your TomTom GO 510. The 510, 710, and 910 all use the same dock. The cheapest place to purchase a home dock is ebay. The answer to the second part of your question is no, you cannot purchase a usb cable to connect your TomTom GO 710 to your pc. The TomTom GO series uses a proprietary dock.
Jul 16, 2009 | Tomtom GO 510 Car GPS Receiver
Changing the battery tomtom go 710
wow go to the nearest tomtom store
Apr 10, 2009 | Tomtom GO 720 GPS Receiver
Nov 15, 2008 | Tomtom ONE GPS Receiver
How to update tomtom 710 uk maps
TomTom makes it really easy to update maps for any one of their devices. You can get the latest Tele Atlas maps from TomTom by heading over to their Map Store. Pick your device, pick your map, and download. While they aren't free, they're extremely accurate and affordable
Sep 15, 2008 | Tomtom Maps Software
GPS
I found a toll free number for TomTom, called and actually got a real person. My computer recognized the TomTom (TomTom home was version 7. something); my TomTom unit had software that was too old and it did not recognize the TomTom home. Catherine in tech support sent me a download to update the software and it worked. Thanks for getting back to me. I am attaching the link for anyone that needs to update software in their TomTom GO 300:
http://download.tomtom.com/sweet/navcore/navcore_7.162.8492.go-go300-go500.cab
Aug 27, 2008 | Tomtom GO 300 GPS Receiver
Tom tom go 710 for auto
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Sep 13, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
3,539 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
