Question about West Bend 82308 Stir Crazy® Popcorn Maker
Brown oily leak
After I pop corn oil leaks out the bottom of popper and makes a mess.
I use olive oil and/or canola oil to pop corn. Is the oil I use causing the problem or do I have a bad popper?
  • Ricklish Nov 20, 2008
    I also have this, but it isn't unusual. It's just a collection of some of the popping oils that have condensed on the inside cover where it usually runs down back into the heating tray. In this case, a small amount of the oils has slipped by the tray and into the heating chamber where it seeps out onto the counter...usually 3-5 drops during storage. We keep our popper resting on top of a paper towel. So, it's more of a nuisance than a problem.
    President:
  • 1,489 Answers
The oil is leaking around the stirring-arm-motor shaft -- it needs a new seal. It's not the oil you're using.
Posted on Apr 22, 2009
  • E equal IR Sep 04, 2012
    But West Bend Support does not carry this seal for liability reasons
    Problem Solver:
  • 7 Answers
This is caused by using too much oil. Cut back on oil and make sure you measure, dont just guess amount. follow the manufactures instructions.
Posted on Sep 24, 2009
The unit only pops half of the popcorn
The symptoms of only pops half the popcorn is a hard one to trouble shoot.
1.Check your popcorn, old popcorn dries out. As it loses moisture its ability to pop is reduced. Popcorn only lasts about 90 days after opening the air tight packaging.
2. If it is a oil popper, make sure the stirring rod is turning during the popping cycle. They sometimes can stir, but once the popping starts the pressure of the corn can stall a motor. This results in the first half popping, and the second half burning on the bottom.
3. Popper is too cold. This has symptoms of a long, long popping cycle, and half the corn popping the other half just turning brown. Some machines had adjustable thermostats inclosed, most home units do not. Letting it pre-heat longer does not help, the temperature is controlled by a thermo-stat.
Mar 07, 2013 | Kitchen Appliances - Others
I have an older version of JS55 strip shredder. I shredded some things that had glue on them. Now it jams a lot. Can I use olive oil on the shredder slots?
Remember that vegetable oils go rancid quickly; they're meant for eating and not industrial lubrication on a regular basis. The use vegetable oil trick is actually intended for people who use their shredders OFTEN, not OCCASIONALLY. I have a giant bottle of canola oil at the office for the big shredder, I use the branded oil at home. The amount of shredding most offices do is enough to warrant using vegetable oil since more than likely by the end of of a typical maintenance cycle, the oil is long gone from the blades and feeding mechanism.
Do not use olive oil, corn oil, cottonseed, peanut, palm, or ANY vegetable oil with an odor. Unless you want your shredder smelling like food, stay away from any vegetable oil with a distinct odor. Canola oil is the best substitute for branded oil. Also look for lower grade canola cooking oil, the ones you often find in thrift stores or 99 cent stores. It should look more "watery" than viscous.
Dec 31, 2010 | Royal JS55 (Strip-Cut) Shredder
How to pop corn in a westbean corn poper
put about 2 tablesppons oil into the popper. Put 2 or 3 kernals into the oil. Turn the popper ON. When the kernals pop,.the oil is hot enough. Add 1/2 to 3/4 cup corn and enjoy when its done.
Feb 04, 2010 | Walter Drake Old Fashion Popcorn Maker
As the microwave is on and the plate inside turns, we hear a creaking noise how can i fix this? wd40 or other?
do not use WD-40. use cooking oil instead (olive or corn, or canola, it doesn't matter)
Oct 21, 2009 | Microwave Ovens
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
NEED AN INSTRUCTION MANUAL FOR ''OLD FASHIONED MOVIE TIME POPCORN
The usual way to use a pop corn popper is to:
1st - add oil
2nd - add popcorn
3rd - add any seasoning (if using the pre-packaged "theater" popcorn mix).
DO NOT add butter into the popper, as it will burn quickly and make for some foul tasting pop corn.
You can always add butter and salt to taste AFTER the pop corn is done popping.
Hope you find this Very Helpful. Best regards!
Aug 18, 2009 | Kitchen Appliances - Others
Cuisinart popcorn popper directions
If you are using the Cuisinart pop corn poppper, don't use olive oil. Use vegetable oil. Two teaspoons is enough with 1/3 cup of premium kernels. That is it. Turn on the machine and wait til it stops popping. I LOVE my new pop corn popper. I will not do the hot air one again. I always had kernels flying all over my kitchen and popped popcorn everywhere, The Cuisinart popper is the best....
Apr 10, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Directions for presto carmel cormer model #0500001
I have the directions for this; send me your address and I'll mail you a copy or I could probably just I have a Presto Caramel Corn'r. These are the directions:
You need a large mixing spoon, wax paper and the following ingredients:
2 T cooking oil
¼ c popcorn
¼ c butter or margarine
½ c brown sugar
2 T light corn syrup
¼ t salt
1/8 t soda
Then follow these steps
1) Pour cooking oil and popcorn into the unit base. Place cover on base. Plug cord into base and then into wall outlet. The signal light will glow when unit is heating. When popping is completed, the signal light will go out indicating that the heat has shut off automatically. Unplug the cord from the wall outlet. Tip unit upside down so popped corn falls into cover. Set cover with popped corn aside. You may want to use a paper towel to remove excess oil and unpopped corn or hulls from the base before making caramel sauce. NOTE: I pop corn for all the batches I intend to make first then do the next steps because you don’t have to clean it each time to make a new batch.
2) To make caramel sauce, combine butter, brown sugar, corn syrup and salt in the base. Plug into wall outlet. Heat mixture stirring constantly until butter is melted and sugar is dissolved. Continue cooking, stirring occasionally for three minutes. Unplug cord from outlet and unit.
3) Place the mixing band on the base. Add baking soda and stir until mixture is evenly colored, light and foamy. Add popped corn, stirring to evenly coat with caramel sauce. Remove mixing band. Pour caramel coated corn onto wax paper and separate kernels. Let stand a few minutes before serving. Wash unit before popping more corn.
Aug 04, 2008 | Kitchen Appliances - Others
Popcorn
Cuisinart makes fresh, crunchy, homemade popcorn fast, easy¿.and healthy! The Cuisinart Popcorn Maker pops up to 10 cups of popcorn in under 5 minutes, and lets popcorn lovers decide just how much, and what kind, of popcorn, oil and flavoring to use. Popcorn pops right into a clear plastic bowl that flips to serve, and both bowl and poping plate go into the dishwasher.
Feb 18, 2008 | Kitchen Appliances - Others
West Bend 82308 Stir Crazy® Popcorn Maker Logo
327 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Jim Goldsmith
Jim Goldsmith
Irene Tulloch
Oloyede Monsuru
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
