Question about Brother DCP 115C All-In-One InkJet Printer
I put a hard paper in the printer then it will not come out
Wat will i do if i put hard paper in inside the printer then it will not come out.help me please...the printer instruct that theres is no paper inside i need to load the paper but it have a paper inside.
    Genius:
  • 1,913 Answers
Ok power off then remove cartridge and then refix it.
also put tray in excat osition.
Posted on Nov 15, 2008
I keep getting the "paper
Hello
Try to unplug the power all, and make hard reset. check inside the printer might have small paper inside and clean you printer.
thnaks
Jul 11, 2011 | HP PhotoSmart C4280 Laser Printer
Paper jam
Unplug the printer from power for ten minutes.
Remove cartridges and put them back, open all doors and close them back.
Oct 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Having a problem with prtinter it's not feeding right keep feeding from right side...tried putting one paperat a time but still not feeding right....PLEASE HELP...
Using high cotton paper causes cotton dust build up making it hard for the rubber rollers to grab the paper. Check inside for paper dust build up. If so, clean rollers with a window cleaner.
Another problem is saving too much money on paper. There are some very thin light weight papers which the printer rollers have a hard time gripping. Most printers do well with 22 lb paper. Otherwise you may need to put a piece of scotch tape under the roller so the machine can grab the thinner paper.
Also check your side paper alignment guide in the tray. As well as making sure your paper is sitting all the way back/down in the tray.
Apr 13, 2011 | HP PSC 1610 All-In-One InkJet Printer
My hp deskjet printer light is blinking wat to do
make sure there is no paper jam inside and all the catridegwes are proper and not dry.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 31, 2010 | HP Deskjet D1560 InkJet Printer
I have a paper jam i cannot reach. paper looks like it's rolled tightly inside
Hello, unfortunately it soound like a repair man job. Unless you can pull your printer apart yourself, I dont advise trying this unless you know how to. Once the paper has woung itself around the role it is hard to remove, sometime if you have a long pair of strong tweezers you can tear a strip of paper off lenghways. You can then put oour printer through the clean mode and as the machine turns the roler it will free the paper enough to get it out. I hope this is helpful.
Nov 03, 2009 | Lexmark X5650 All-in-One InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
EPSON LQ-680 DOT MATRIX PRINTER
problem with detector cable or detector sensor
Feb 24, 2009 | Epson LQ 680 Matrix Printer
HP 1210 All In One Printer
see this is the common problem i got so many query regarding this proplem ,you can easily solve this problem , when you placing the paper in paper tray be very carefull put very slowly inside when you feel a little bit of resistent stop it that mean paper is properly inside dont put so hard inside. bye
Aug 12, 2007 | HP PSC 1210 All-In-One InkJet Printer
Printing
see this is the common problem i got so many query regarding this proplem ,you can easily solve this problem , when you placing the paper in paper tray be very carefull put very slowly inside when you feel a little bit of resistent stop it that mean paper is properly inside dont put so hard inside . bye
Aug 17, 2006 | HP PSC 1210 All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
