Question about Curtis Trimline TID582 Corded Phone
Curtis Speaker Phone TID991
Hi I have just purchased this phone with Caller ID. In the set up, it asks for Special Service Number ( SSN ) What is it asking for?? My home number or? Thanks. I look forward to the answer to this as Telus didn't know. Diana
2 Suggested Answers
theswans
  • 7 Answers
SOURCE: Looking for instruction and set up manual for
Hi hope this helps you out
http://shop.retrevo.com/m/search/aproduct?c=1039&m=19449958&rt=pd
Posted on Jun 13, 2011
Need a caller ID that hooks up to land line phone line and shows on television screen.
Contact your phone service provider to setup caller ID and ask them if they do the TV service as well
the service provider has to enable caller ID before any plug in box will display the number there is a charge for the service depending on the package you have
Dec 11, 2016 | Lands Phones
Caller id is not working in my cordless phone. Instead of number of a caller, "Incoming Call" is showing. Please help me
Caller ID on landline phones relies on signals from the telephone service provider. Some companies charge extra if you wish to enable the service, others include it automatically, so you need to check with them first.
Even if you have caller ID enabled, callers can choose to withhold their number. Large companies which make lots of outgoing calls (especially cold callers) often have their service set to automatically withhold their number. In many countries, all other callers can choose to do so by prefixing all dialled numbers with a short code, e.g. in the UK it's 141. Mobile phone callers can usually alter a setting on their handset so that caller ID is withheld when making outgoing calls.
Sep 29, 2011 | Lands Phones
How do I make the phone ring/ Also how do I delete number's/
Activating Personal Ring
You can assign special ringer tones to anyone in your phonebook. When your phone gets a call, it looks up the Caller ID information in your phonebook. If you've assigned a personal ringer to that number, the phone uses it so you know who is calling. To turn the personal ringing on or off, follow these steps:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the PERSONAL RING submenu.
  2. Move the cursor to select ON or OFF.
  3. Press [Menu/Select]. You will hear a confirmation tone.
Selecting a Ring Tone (Handset only)
You may choose from four melodies or three tones for your phone's primary ring tone. Each handset can use a different ring tone or melody. The available ring tones are as listed:
  1. Press [Menu/Select]. Select the HANDSET SETUP menu, and then the RINGER TONES submenu.
  2. Move the cursor to select a ring tone. As each ring tone is highlighted, you will hear a sample.
  3. When you hear the tone you want to use, press [Menu/Select]. You will hear a confirmation tone.
Adjusting the Speaker Volume
Handset Speakerphone: You can choose from six volume levels for the handset speakerphone. To adjust the speaker volume while on a speakerphone call, press the UP Arrow button (to make it louder) or the Down Arrow button (to make it softer).
Base Speaker: You can choose from ten volume levels for the base speaker. To adjust the speaker volume while call screening or playing messages, press [volume +] (to make it louder) or [volume -] (to make it softer).
Adjusting the Audio Tone
If you aren't satisfied with the audio quality of your phone, you can adjust the Audio Tone of the earpiece while on a call. Your phone gives you three audio tone options: low, natural and high; the default setting, Natural Tone, is recommended for hearing aid users. Audio tone adjustments only apply to the earpiece, not the speakerphone.
To adjust the audio tone:
  1. While on a call, press [Menu/Select].
  2. Move the cursor to select AUDIO TONE, and then press [Menu/Select].
  3. Move the cursor to select desired option (HIGH TONE, NATURAL TONE, or LOW TONE), and then press [Menu/Select]. Selected option appears in the display for two seconds, and then the display returns to normal.
Deleting Phonebook Entries
You can delete a single phonebook entry at a time or all phonebook entries at once:
To delete a single phonebook entry:
  1. When the phone is in standby, press the phonebook key.
  2. Find the entry that you want to delete and press [Menu/Select].
  3. Select DELETE. DELETE ENTRY? appears in the display.
  4. Move the cursor to select YES.
  5. Press [Menu/Select]. You will hear a confirmation tone, and DELETED! appears in the display.
Deleting Caller ID Numbers
  1. To delete only one Caller ID number, press the Caller ID button when the phone is in standby, and then find the number you want to delete.
  2. Press [Menu/Select] and select DELETE ENTRY.
  3. When the phone asks you to confirm, select YES.
  1. To delete all the Caller ID numbers, press the Caller ID button when the phone is in standby, and then press [Menu/Select].
  2. When the phone asks you to confirm, select YES.
Note: When you delete a Caller ID number, you delete it permanently.
Deleting a Redial Record
If you want to delete a phone number from the handset's redial list, follow the steps below:
  1. When the phone is in standby, press [Redial/Pause].
  2. Use the UP Arrow button and the Down Arrow button to scroll through the redial list.
  3. When you find the redial number you want to delete, press [Menu/Select] and select DELETE ENTRY.
  4. When the phone asks you to confirm, select YES. The redial number is deleted.
Resetting the Voice Message Waiting Indicator
  1. When you receive a new voice mail message, the new message LED on the top of the handset flashes and VM appears in the handset display.
  2. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state.
  3. To reset, press and hold [find hs] on the base for five seconds.
  4. A beep sounds and the message alert tone is reset.
Mar 22, 2011 | Uniden DECT 2080-5 Quint Phone
Hi... I got the Vtech Cordless phone Dect 6.0 the caller id is not working. it just shows "Incoming call". I tried with Panasonic cordless to check if I have no problem with the service...
hi you need to programme the number into you caller id unit or extension.Also you need to confirm that caller i/d is envoked by your service provider. and ask them to test it .
Best regards
John
Mar 14, 2011 | Vtech DECT 6.0 Digital Cordless Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Caller ID display
might be the IP funtion is on. this is not available in the USA. press SET/SAVE, press Up to select "SET 4 AUTO IP", press SET/SAVE to select, press UP to change setting, press SET/SAVE to confirm. if you'd like a copy of my manual for the phone, email me at all8upinwv@yahoo.com and i will send a copy in 2 different formats so you'll be sure to be able to open at least one of them. hope i helped.
tammy
Apr 14, 2008 | Innovage Speaker/Caller ID* LCD Touch...
I looked up manual on internet and did not see this question in the manual. What function are you trying to set up?
Feb 02, 2008 | Lands Phones
Caller ID is not working in India.
For people who have purchased cordless phone in usa and caller id is not working they should purchase fsk to dtmf converter at any local phone shop and caller id will start working.
Here is the article on various frequency used by various countries for caller id.
Hope this will help you out.
Detailed Product Description
There are 3 major caller ID specifications in the world: DTMF, ETSI FSK and Bellcore FSK. When users buy a foreign telephone devices(such as cordless phone, fax machine or computer telephony interface), may encounter the problems of non-match for caller ID standard. This will cause the device unable to display the caller ID. EX220 can solve this problem easily. This product can receive all 3 kinds of caller ID format, and convert to FSK(Bellcore or ETSI selectable) to match foreign telephone's standard.
EX220 has a rechargeable battery inside the device, during idle status, it gets power from the telephone line and recharge the battery, so no need to use or replace battery. Just plug one end to telephone line, and the other to the telephone device.
For example, if you live in Netherlands, Saudi or India, the caller ID standard is DTMF. You purchased a cordless caller ID phone from US(which uses Bellcore FSK standard), or from Germany(which uses ETSI FSK standard). You won't be able to use the caller ID feature. In this case, just get one EX220 and connect it between the telephone line and the cordless phone, your cordless caller ID phone will display the caller's number immediately.
Remark:
1. Telephone sets for UK and Japan standard are not applicable.
2. In some countries, users must subscribe to Telecom for caller ID service
Feature List
Caller ID Format Conversion --- Convert 3 kinds of caller ID(DTMF, Bellcore FSK or ETSI FSK) to ETSI FSK or Bellcore FSK(selectable)
Date/Time Stamp --- The DTMF caller ID doesn't content date/time stamp. User can set up clock of EX201, so each call will be sent with actual date and time stamp
Area Code Setting --- User can set up the area code, so the dial back feature can easily applied
Rechargeable battery powered by line --- Just connect to the telephone line, the built-in rechargeable battery can get power from the telephone line, no need any external battery nor power supply
News
Now, Multi-Line caller ID converter is available.
Dec 09, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
Caller ID doesn`t talk
only thing i can think is the IP function might be on. ( and of course, u do have the caller id through the phone company activated, right,,,,just checkin) . this funtion is not available in the USA. to turn it off, press SET/SAVE, press UP to select SET 4 AUTO IP, press SET/SAVE to select, press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main screen. hope that helps.
tammy
Aug 29, 2007 | Innovage Speaker/Caller ID* LCD Touch...
Curtis Trimline TID582 Corded Phone Logo
101 people viewed this question
Top Curtis Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Curtis Lands Phone Expert? Answer questions, earn points and help others
