Question about Nokia 6600
Bluetooth problem my phone is sending an unknown message to another phones.how can i stop this ?my phones bluetooth is in off possition
    President:
  • 1,257 Answers
Your mobile is infected with virus..Formatting is only the solution for you
Here is the link http://www.fixya.com/support/r546989-format_nokia_6600_mobile_phone
Posted on Nov 15, 2008
Cant pair device without passcode
Hi, to set up Bluetooth on your phone
1. Go to Menu, select Connect or Connections or Connectivity:
Note! If the above steps do not work, please consult the user manual.
2. Bluetooth - Select On to enable Bluetooth.
3. My telephone's visibility - Select Shown to all if you want your device to be found by other Bluetooth devices. If you select Hidden, your device cannot be found by other devices.
4. My Bluetooth name - Define a name for your device. After you have activated your Bluetooth service and changed My phone's visibility to Shown to all, your phone and this name can be seen by other Bluetooth device users.
Sending data via Bluetooth
If your phone supports the Bluetooth 1.1 specification or earlier, you can only have one Bluetooth connection running on your phone at any one time.
1. Select or open the file you wish to send. For example, to send a photo to another device, open the Gallery application.
2. Select the file you wish to send, then select Options > Send > via Bluetooth.
3. The phone starts to search for devices within range.
Devices using Bluetooth technology that are within range will appear on the display. You should see a device icon, the device's name, the device type, or a short name. (A paired device is one where a Bluetooth connection already exists between your phone and the other device.)
• To interrupt the search, press Stop. The device list freezes and you can start to form a connection to one of the devices already found.
If you have searched for devices earlier, a list of the devices that were found previously is shown first. To start a new search, select More devices. If you switch off the phone, the list of devices is cleared and the device search needs to be started again before sending data.
4. Scroll to the device you want to connect with and press Select. The item you are sending is copied to Outbox and the note Connecting is shown.
5. Pairing (if this is not required by the other device, proceed to step 6.)
• If the other device requires pairing before data can be transmitted, a tone sounds and you are asked to enter a passcode. • Create your own passcode (1-16 characters long, numeric) and agree with the owner of the other device to use the same code. This passcode is used only once and you do not have to memorise it. • After pairing, the device is saved to the Paired devices view.
6. When the connection has been successfully established, the note Sending data is shown. Data received via Bluetooth can be found in the Inbox folder in Messaging. Tip: Pairing is a means of authentication. The users of the devices using Bluetooth technology should agree together what the passcode is, and use the same passcode for both devices in order to pair them. Devices that do not have a user interface have a preset passcode.
Checking the status of the Bluetooth connection
• When the Bluetooth icon is shown in standby mode, Bluetooth is active.
• When the Bluetooth icon is blinking, your phone is trying to connect to the other device. • When the Bluetooth icon is shown continuously, the Bluetooth connection is active.
Receiving data via Bluetooth
When you receive data via Bluetooth, a message alert tone is played and you are asked if you want to accept the message. If you accept, the item is placed in the Inbox folder in Messaging.
Disconnecting Bluetooth
A Bluetooth connection is disconnected automatically after sending or receiving data.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
Hope that helped...
Thanks for using fixya...
Feb 07, 2011 | Cell Phones
IM TRYING TO SEND A SONG OF MY MERMORY CARD TO MY SIS AS A TXT MESSAGE HOW DO I DO THAT?
Transfer the song using bluetooth if both phones have bluetooth.
Otherwise, send a MMS (Multimedia Message) to the other phone, both phones need to support MMS to receive the message.
You can't send a song using a SMS Message (text message).
Nov 09, 2010 | Samsung Gravity SGH-T459 Cell Phone
HOW DO I TRANFER DATA FROM THE MESSAGING FOLDER IN A NOKIA N79 TO ANOTHER MOBILE USING BLUETOOTH CONNECTIVITY.
hello,you can not send it from the messaging folder except you save it to another folder then you will be able to send it through bluetooth.simply because every content in the message folder could only be sent through sms or saved to another foolder.kindly go to options you will definitely see save to folder or you create a folder and move it there for you to be able to send it through bluetooth.
wish you good luck,
take care.
Apr 23, 2010 | Cell Phones
Message sending failed unknown recipient error
ur reply number u wld been changed... call ur customer care and get ur original reply number and enter it in ur msg settins..
Apr 12, 2010 | Sony Ericsson K700i Cellular Phone
Can't send videos through messaging.
The only way you can get the proper settings of your phone to send mms contents is by contacting or calling the phone service provider and ask them for the activation and settings for your phone in sending mms content like videos or pictures. Bluetooth is available only is sending files on both bluetooth ready devices in a one place.
Dec 27, 2009 | LG Xenon GR500 Cell Phone
My phone is sending an unknown message to another phones.how can i stop this ?my phones bluetooth is in off possition i have nokia 6600 my phone sending unknown files to other devices if my bluetooth in...
by pressing Calling key and 3 and * and switch it on ur battery must be charged it will show formatting for 5 minutes and it is done. dont remember to vote my solution as fixya
Jun 03, 2009 | Nokia 6600
sir you have to go the settings>conectivity>bluetooth>visiblity turn off your visiblity if want to transfer file then you can on your visiblity
Jun 01, 2009 | Nokia 6600
Sending with Bluetooth
You'll have to pair the phone's together, turn the bluetooth on both phone's, search for unknown device's with one phone ti'll it find's the other phone, then pair them with a passwrod.
Apr 14, 2009 | Lands Phones
Bluetooth 5500
Hi. Theres no way to send any messages via bluetooth - formally.
You can send messages by writing it first on notebook and send it forward with bluetooth.
If you recieve any messages from another bluetooth handset they will go to same place as your SMS. In your inbox.
You can send pictures, music etc. by going in the gallery, selecting file what you want to send, and click send. It may ask do you want to send it by MMS, IR, bluetooth or something like that.
This is my favourite. Search super bluetooth hacker from Google and send it to your phone. It may came to your inbox. Install it, turn bluetooth on, cheat your friend that you will send him some cool clips and songs. Then your phone will ask password. You both enter same password (example 1111) and you may have access to his/her phone. >:)
If you want to any more help, connect me and I will help you.
Oh! By the way, I think you can download online instructions from Nokias website. Have a nice day - with bluetooth.
Sep 07, 2008 | Nokia 5500 Sport Cellular Phone
Nokia 6600 Logo
51 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
