Question about Whirlpool Duet GHW9150P Front Load Washer
Allergic to detergent for front loaders
I have tried multiple front loader compatible detergents and am allergic to all that I have tried. I break out from the clothes that have been washed with the detergents. Is there a danger to using regular liquid detergent in a Whirlpool Duet front loader?
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
I have had my Duet for three years.
Posted on Nov 15, 2008
Use Top Loader or Front Loader detergents Do you need to dissolve all powders or liquids before washing Can you alter spin time or speed
the use of liquid detergents is recommended over powders in washing machines as they do leave a mud build up over time in the bottom of the wash bowl
no they do have to be dissolved before use
spin speeds are set in the machine program and cannot be altered
spin time is set in the machine program and cannot be altered
use the recommended detergents for the machine because if you use top loader detergent in a front loader it will froth up excessively and cause problems for a front loader machine
the suitability of use for the detergent ( powder or liquid) is clearly marked on the labelling on the bottle or packet
Feb 24, 2015 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Best detergent to use that doesn't cause so much suds?
If you're using a front loader, ALWAYS use h.e detergent!! Standard detergent will very easily oversud a front loader.
May 26, 2012 | Maytag Washing Machines
Why do you have to use H.E. detergent in front load washers?
not as much suds as regular detergent and double the strenth,front load washers use less water than top loaders,if you use to much detergent the machine will keep filling and draining to try to get the suds out.also you should only be using 1/4 cup of H.E. detergent or you can damage the spider gear in the washer,you'll know if it breaks you'll hear the tub banging all around loudly when it's in final spin,the spider gear is made out of soft metal and the extra detergent eats at the metal
Apr 09, 2011 | LG Washing Machines
If someone uses wrong washing power and puts front loader washing power in a top loader can that do or cause any sort problems
That's no big deal. It won't harm a top load washer. Just try to use the proper stuff next time.
However, you should never use regular top load laundry detergent (non HE) in a front loading machine though, because that can quickly cause problems.
http://www.myefficientplanet.com/tag/too-much-foam-wrong-detergent-front-loader-washing-machine/
Good luck.
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Should suds be visible in top load washers during the wash cycle?
Not if your using the correct amount of HE detergent You have to start with the understanding that the tumble action of high-efficiency washers (i.e., front loaders) produce more suds than the agitator action in top loaders. Now most of people think, "Oooo, sudsy, that's good!" No, not good. Suds do nothing to clean your clothes and are actually an undesirable by-product of the detergent's chemical interaction with the water. The main job of detergents is to remove soils and stains. They do this by breaking down the surface tension of water, in effect, making water "wetter." The water is what actually does the cleaning by slipping in between the ca-ca and the fabric, separating them and suspending the ca-ca in solution.
Detergents are designed to freshen, remove odors, and brighten fabrics as they clean. Another key detergent function is to hold ca-ca, and any dyes from colored fabrics, suspended in the wash water so they aren't re-deposited back onto the cleaned clothes. Traditional detergents are designed to do this in high water volumes used by conventional, top-loading water hog washers.
If you think about it, using HE detergent in your front loader is really common sense. Because of the low-water wash and rinse cycles in HE washers, HE detergents must work differently from traditional laundry detergents in order to be effective.
Excess suds can cause the washer's pump to overheat causing premature failure of the pump. These excess suds also cause residue to build up inside the drum and hoses. After a while, your washer will start giving off a moldy funk and infecting your clothes with its faint, musky stink. Hope this Helps Good Luck
Oct 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is the proper soap detergent needed for front loader samsung washer and dryers?and where to purchase?
These types of washing machine require HE (high efficiency) detergent and it is available from most supermarkets, costco, wallmart and many other stores.
Just lokok for "HE" on the front.
Detergent brand names may vary but "HE" remains.
DO NOT use regular detergent as this can and does cause many issues on these washing machines some may even require an engineer to call and fix them.
These are by far one of the best washing machine types saving both energy and time for a much better clean.
Bob
Sep 13, 2010 | Samsung WF337AA Front Load Washer
Can you use regular detergent with front loader washers??
All manufactures suggest using a high efficiecy detergent. They are specially formulated to keep the suds level low and work well with the low water levels of a front loader. Boxes are marked with an HE on them letting you know they are for high effiency machines. Regular detergents were designed for washers that use many gallons of water.
Feb 03, 2010 | Kenmore Elite 45986 Front Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Detergent
Yes! any kind of liquid soap is ok for your front loader. HE soaps are just a little better in the front loaders so yes you can still use your liquid soap.
Feb 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
134 people viewed this question
Dan Webster
Dan Webster
Sal De
