Question about MagLite Camping, Backpacking & Hiking
My Mini mag AA worked until I took it apart to install an LED kit
Now it dosen't work at all. I put it back together and tried the old ***'y and it dosen't work either. I took the black module apart and cant seem to get it working again eith er with the LED or the Old parts re-assembled. It is driving me nuts.. Do I have to buy another new MiniMag or can I get a new module. I think I may have drpooed something small on the floor , I cant be sure but if my wife vaccumed the floor I may have lost something I know nothing about. Please help, I'm now sutck with an upgrade kit and an old minimag that won't work.
Thank You,
Joe Ciarlanto
  • 29 Answers
Start with a new mini-mag and put the upgrade in it. It will save you the frustration, especially not knowing for sure whether their is a missing part or not. Plus it will save the hassle.
GGBMDB
Posted on Dec 02, 2008
Blade assembly: My WAHL Peanut trimmer hit the floor and fell apart.. How do I reassemble the blade which has also detached.
if it broke apart when it hit the floor then you will have more problems than just putting the blades back on. those are fairly well put together so coming apart means they hit pretty hard. you wont ever get them to cut right even if they go back together. your gunna have to just buy new ones.
Aug 01, 2014 | Wahl Tid-bit Mini peanut Trimmer Clipper...
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
Water filter keeps popping out
Too high of pressure I the water supply. The lines may have frozen up. If you can I would defrost the freezer and leave the water on and try to cycle it through until you get good water flow. Then throw the filter back in and see how it gos. Good luck
Sep 09, 2012 | Frigidaire GLRS264ZA Side by Side...
My mag lite led xl100 will not turn on, have fresh batteries installed
take the bottom piece off, remove the last battery and put a coating of petroleum jelly on the threads of the tube. Then take the bottom piece and run it all the way in and back off and back in 2 or 3 times. Then put a little more petroleum jelly on the threads and put the battery back in and the bottom piece. This should do it.
Apr 10, 2011 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
I have an AA Mini Maglite and it quit working. I replaced the two batteries and lamp and still does not work. Any suggestions?
I have several of these flashlights and experienced the same problem. Here's my solution: take off the light end and you will see a black base where the bulb is inserted into. The black base rotates. If all else is functional (batteries, bulbs, etc.), when you rotate this black base, the light should come on. Moving the base back and forth several times seems to help also (it seems there must be some kind of contact problem). All that's left is replacing the light end.
Jun 18, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Ecofan only turns slowly
These fans can be rebuilt! Like many others, our fan died after being placed in the center of the stove top. I took the two halves of the fan body apart, and scraped the heat sink compound off either side of the power plate. I then applied CPU heat sink compound that can be found at any computer or electronics store liberally to either side, and put it back together. The fan spins like new, spread the word!
Nov 28, 2007 | Cfm 802 Ecofan Table
Camping, Backpacking & Hiking Logo
224 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
