Question about Huffy Cycling
The chain wants to jump off while trying to change gears
I have a 24 inch huffy mountain bike 15 speed.
when you change gears the pedal skips and will throw the chain off the back deraillieur.
Is their a way to adjust the guide or will I have to replace it?
    Problem Solver:
  • 11 Answers
There are several things that could be wrong:
Shifter out of adjustment
Chain worn
Chain and gear(s) worn
Shifter out of adjustment:
Try adjusting the cable tension by turning the barrel (the part between the cable and the shifter). Count the number of turns and reset it to its original position if this doesn't solve it.
Chain worn:
Chains wear out. hold a ruler up to it, with one end centered on a pin. 12" away, another pin should like up very very very close to the 12" mark. If not, it's probably worn out and needs to be replaced. No way around it. Some say chains are good for 500 miles only. Your mileage may vary. (keep reading...)
Chain worn and gear(s) worn:
If the bike has been ridden witha worn chain for a while, it will make the gears in the back wear faster too, and a new chain alone will not work. If this is the case, you need a new chain and new gears in the back. Often, gears in the back are replaced all at once in a 'cassette'. You'll have to make sure your front gears aren't worn out too!
Posted on Nov 20, 2008
What is the replacement pedal bearing in a huffy mountain 24" bike?
at the Huffy quality level of pedals, you most likely won't be able to service the part, you can find a set of replacement pedals at your local bike shop starting at about $10 for the pair.
Apr 28, 2014 | Huffy Cycling
I have a Huffy bike with a 48cc motor on it. The chain hits my fenders and now keeps popping off
which chain is falling off. the one from the motor? if so check to make sure the sproket (ps i cant spell) and gear fom motor is lined up. on mine i remember having to flip the rear sproket. are you using the chain tenchiner pulley? i think the one that comes with the kit dosnt have a deep enough gruve. i got rid of it all together, and just made the chain fit with like 1.5 to 3 inches of play. ive seen people use the tenchiner from the rear shifting gear on a mountain bike. thats what i suggest. if its the chain from your pedals thats falling of the the guys from the bike shop are messing with you or the alined the wrong chain. or maybe you need to resize the chian they just got the wheel straight.
May 02, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
I am trying to fix a Huffy Blackwater bicycle (15 speed). The rear derailleur is missing. Can I use a 6 speed derailleur from a Next bike? Can I disable the indexing of the Huffy (Falcon) shifter? Thanks
You can use the 6 speed rear derailleur with no problems. The 5-spd shifter does not need to be disabled, as it will work just fine.
The shifter controls the rear derailleur, telling it how far to move. The rear derailluer just follows what is dictated, so there is no real difference mechanically between the 5spd and 6spd derailleurs, only in the shifter.
If you wanted to make the bike 6spd, you would have to change the shifter and gears along with the derailleur.
Dec 21, 2010 | Huffy Blackwater Men's 26-Inch Mountain...
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
Peddle just spin while bike riding bike it will not engage
The chain has come off. Refit it onto the cogs then you will have drive back.
Vote for me if this helps, thanks.
Jun 19, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Seems chain is loose. every 3 pedel in skips and recatches sprocket. could be trying to change gears but doesn't look like it is, think its just loose. huffy nightstalker 12 speed
Sometimes chains have stiff spots that cause them to skip. You can try checking the chain for stiff spots or just spray some lube on it and see if it loosens up. If you turn the bike upside down or put it such that you can let the back wheel spin freely, you can slowly turn the pedal and see if you can see the spot on the chain where it slips. If you find it, you can spray lube on the spot and work it back and forth until it's loose. Good luck and hope this works!
Mar 14, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Trying to reassemble rear wheel gear assembly for huffy mountain bike. i didn't take it apart and don't have a manual. someone else took it apart
This should help you:http://sheldonbrown.com/gearing/index.html. Also try here:http://www.parktool.com/repair/byregion.asp?catid=4 Hope these sites help. Good explanations and pictures.
Aug 29, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
Cycling Logo
407 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
