Question about HP LaserJet 4 plus Printer
Printout blank Printer printing out blank when sent print jobs every morning, the toner cartridge is working. Please help.
  • 47 Answers
Hi Seng, Run a self test from the printers control panel. 1. Press the printer?s ON LINE button to take the printer offline. 2. Press the Control Panel MENU button until TEST MENU appears on the display. 3. Press ITEM until SELF TEST appears on the display. 4. Press ENTER. The Self-Test will print. 5. Press ON LINE to return the printer to the online state. If it prints than you have a software issue if not it's hardware. For Software Check the Density Settings. Make sure it's not set too light. Also try printing from another app, maybe you have a corrupt print job. If you have a hardware issue come back here and I'll help you sort through those. Let me know, Dude
Posted on Nov 26, 2006
My hp1012 is printing dark with shading on the pages and shadow or echos. Can something be replaced or fixed?
with this issue, you pretty much have to run a half way test unless you have the convieniance of another toner to try. basically, it's either going to br your toner or your fuser and a halfway test will determine this if you don't have another toner to try.
The Half-way Test
You will need to print a page and open the toner lid when you think the paper is underneath the toner cartridge. This will stop the printing so you can pull the toner cartridge out and look at the partially printed paper. It may take a few tries to time this test correctly so the paper stops under the toner but not completely into the fuser.
1. Print a test page from Tray 1, the "fold-down" Multi-Purpose tray on your printer.
2. Just as the test page completely disappears into the printer, open the toner lid door. The print job will stop, sensing an error.
3. Pull the toner cartridge out, and you will find the test page sitting directly underneath the toner.
4. Carefully remove the page by gently pulling the page upwards & free from the toner cavity. Careful! The toner has not yet been fused to the paper, so the print can be somewhat messy on your hands and may smudge easily.
Examine the printout.
1. If you do not see the print defect on your test page, that means the defect is being added later in the print process by the fuser. Fusers are the main component in a maintenance kit; click here to view our selection of maintenance kits for various LaserJet printers.
2. If the print defect is visible on this printout, that means the print defect is occurring before the fuser. Try replacing the toner cartridge (click here to view our selection of toner cartridges).
If you determine the print defect is occurring before the fuser, and swapping toners doesn’t fix the problem, there could be several things causing the problem. In the order of most likely to least likely: you could have two defective toner cartridges, the transfer roller might be faulty, the laser scanner could be dirty or defective, or the high voltage power supply could be bad. You might want to email or call since these scenarios are not as common.
Order Fuser Here!
Order Transfer Roller Here!
hope this helps and if so please mark FixYa!!
Jul 24, 2010 | HP LaserJet 1012 Printer
Replaced toner cartridge and now get printout of
try to reinstall the printer driver. then align the printer toners. then perform some test print.
Mar 08, 2010 | GCC Technologies Elite 12/600 Laser...
How can I get a printout of the number of copies printed on my 1320?
Suggest the following as you are not able to connect through the tool box
a. press Go (the green button) for five seconds when the printer is in the ready state.
this will print the configuration page and then the supplies status page for the current toner in the printer.
The Supplies Status page provides information about the print cartridge that is installed in the printer, the amount of toner left in the print cartridge, and the number of pages and print jobs that have been processed. The Supplies Status page automatically prints when a Configuration page is printed from the control panel.
hope that helps
Sep 25, 2009 | HP LaserJet 1320 Printer
Hi, i have a printer LX-300+ my printer have some problem when i sent a print job no printing at the page just blank paper printout u tell me whats the reason of blank printing head is ok but no key...
hmmmm your printer cable is defective or lose. of connection.. the printer cable can seen under the printer head... try to tighten is up.. if not your printer cable is defective....
Feb 03, 2009 | Office Equipment & Supplies
Problem with printing
CRU Fuse Error The toner cartridge is
not installed correctly.
Install the toner cartridge
correctly. See “Replacing the
Toner Cartridge” on page 8.4.
www.zinetic.o.uk
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP Laserjet 3050 blank print
Have you tried a new toner cartridge? Usually blank pages are due to a missing bias voltage to, or in the cartridge.
Aug 11, 2008 | HP LaserJet 3050 All-In-One Printer
Canon imageclass mf6550
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
Feb 06, 2008 | Ricoh Aficio 180 Laser Printer
Blank papers
Try again the old toner cartridge if you still have it. Even though the print quality might be bad, see if there is a printout. If the page is not blank like the others, that is an indication that the new cartridge is defective and has to be replaced.
Sep 05, 2007 | HP LaserJet 2420 Printer
Printer wont print
On some of these inkjets, if the color cartridge is out or dried up from little use, they will not print using just the black cartridge.
Mar 30, 2007 | Epson Stylus Color 740 InkJet Printer
HP LaserJet 4 plus Printer Logo
179 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
