Question about Kenmore 15129 Built-in Dishwasher
Locked the control panel says its locked and won't allow any functions...how do i unlcock it
  • 734 Answers
A dishwasher lock includes a first component adapted to be secured to the underside of a counter top directly above the forward upper edge of a dishwasher and a second component slidably and detachably secured to the first component. The second component includes an L-shaped plate adapted to be disposed in overlying engagement with the front of a dishwasher to prevent opening of the dishwasher door when the second component is secured to the first component.
Posted on Dec 02, 2008
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
Status on control panel showing control locked light on not allowing machine to operate
The main panel control system is not functioning. Replace it.
Jan 20, 2013 | Dryers
Power windows 2007 Saab 9-7X not functioning
There is a recall on this issue....water can enter the switches and cause the switch to fry and or cause a fire.
Nov 24, 2011 | 2009 Saab 9-7X
My 2002 Buick Rendevous would not start three times, then on the 4th time it started. Now the security and SES light is flashing. The windows won't roll down, radio is locked, door locks won't...
Given the amount of electronic's ( computers ) on your vehicle ,it could be a lot of thing's . Hooking up a factory or professional grade scan tool that can communicate with all the control modules on the vehicle should be the first step in the diagnostic problem . Checking for DTC'S - diagnostic trouble codes , communication between module errors etc.....
Your best bet , take it to a qualified repair shop that has the proper diagnostic equipment to check it out .
The power door lock system consists of the following components:
• Body control module (BCM)
• Driver door lock switch
• Front passenger door lock switch
• Door lock actuators in each of the doors
• Door lock system fuse into the BCM (BCM D 25A fuse)
BCM Functions
The body control module (BCM) is capable of accomplishing multiple body control functions. Components directly connected to the BCM are controlled by the BCM outputs. The BCM can control its outputs based on input information it obtains from sensors and switches that are directly connected to the BCM, or by receiving information from other vehicle systems connected to the class 2 serial data link. The BCM evaluates this information and controls certain body systems by commanding an output on or off.
The BCM is also capable of commanding other vehicle systems to control functions that are not directly wired to and/or controlled by the BCM. The BCM accomplishes this task by sending specific messages on the class 2 serial data link. The vehicle system capable of performing such function will respond to the BCM message.
The BCM controls/monitors the following functions:
• Audible warnings
• Indicators control
• Interior lighting
• Exterior lighting
• Power/automatic door locks
• Keyless entry
• Content theft deterrent
• Personalization
• Serial Power Modes
• Electrical Power Management
Buick Class 2 Operation Diagnosis 1998
Oct 17, 2017 | 2002 Buick Rendezvous
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
A wrench symbol is up and the dishwasher will not start after putting in a small amount of dishwashing detergent.
HI,
If I understand correctly you have locked the drawer, push and hold the far right button on the control panel until you hear 1 beep, this will release the control lock and allow fun function tot eh control again.
Any more questions please ask, glad to help
Aug 15, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi. I do not have a remote control and manually put the child lock on by mistake and now I can not get it off. Please help!!
Do the reverse of what you did to put the Child lock on from the front television panel, if you can remember.
If you can't the television may still allow you to bring up the menu and settings functions, scroll through the on screen display menu until you find the settings for the child lock and deselect it.
If you cannot get any type of on screen display with menu functions present on screen you may need to purchase a cheap aftermarket learning remote control, these cost from less than a tenner up.
Apr 28, 2010 | Televison & Video
How do we get the control lock light off? We can not get the washing machine to turn on or any other functions to work because it's locked.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Nov 22, 2009 | Kenmore Elite 45986 Front Load Washer
Lock button is to unlock and unlock is to lock
The lock/unlock outputs from the main unit are reversed. There are two negative output wires from the unit that control the doorlocks, if you just switch them around, they will function correctly.
May 16, 2009 | Gmc Dodge Ford Reverse Back-up Sensor...
Kenmore 15129 Built-in Dishwasher Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
