Question about HeatSafe ML250TPA Heater
Fluttering on 4th panel
When I turn my heater on, it seems to work fine. Then when it goes off automatically and comes back on, the 4th panel sputters and poofs, then all panels glow like it should. I took the noozle off and checked it out. It looked ok. No blockage. I took a small compressor on blew gently on the panels and the orfices. Tried again and still acts the same, when turning back on automaticlly. Bought last Spring, when the weather was getting warm. It acted the same, back then, but forgot about it. I did call either, ProComm or Habour Freight, but they didn't do me justice. Need help, Jim
  • 188 Answers
It sounds like either the heater needs to be cleaned, but it sounds like you did that already. It also could be a crack in the panel. If it is a crack you will need to replace all the plaques because you cannot buy them separately. Sometime it can be expensive. I hope this helps!
Posted on Jul 08, 2009
Hot water heater lokced out with error codutfor ignition failure.
get some professional help, you are messing with disaster.
Apr 19, 2016 | Water Water Heaters
Why is my 5 brick propanes sputtering on setting 2 also the brick that the fluttering is coming from does not burn as bright as the others.
Hello George, I would suggest you check the gas supply tubes after the gas control for any obstructions such as a spider web that might restrict the gas flow to the bricks.
Oct 12, 2015 | Heating & Cooling
I have an 02 dodge grand caravan where the heater blower does not come on. the infrared three-zone automatic temperature control panel does not light up as well.
if NO heat comes out,have you checked to see if the flapper(door that opens to let heat out)opens or any obstructions????. Alberto
Feb 12, 2014 | Dodge Grand Caravan Cars & Trucks
2001 chevy s10 automatic 150,000 miles suddenly lost 3rd and 4th gears
USE A SCANNER TO CONFIRM WHETHER HAS ANY SOLENOIDS HAD TO DO WITH.
Aug 29, 2012 | 2001 Chevrolet S-10
Car hesitates and sputters
It seems like you have a vacuum leak in a hose some where. Check under the hood for any rubber hoses that are dry-rotted, cracks, or sharp bends in any of them.
Aug 21, 2009 | 2004 Dodge Neon
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
Dec 17, 2008 | Kenmore 16322
Heating & Cooling Logo
87 people viewed this question
Top HeatSafe Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a HeatSafe Heating and Cooling Expert? Answer questions, earn points and help others
