Question about RCA Scenium D40W20 40" Rear Projection HDTV
While watching tv, the tv all sudden goes snowy, no sound, and have to turn it off and back on to make it work again
When watching the tv, it randomly goes snowy and have to turn it off and back on to get the picture back and the sound. Some times it does it right after you turn it on, and then times it will go all day and no problems, then it other day it did it 3 times in 30 minutes. I will be watching it and then it will kinda pop and the screen goes snowy, and the sound goes, and I have to turn it off and back on to get the picture and sound back. Please help, I can't seem to find no one to tell me what the problem is, it is like it loses the signal, I got cable tv. Thanks
  • 65 Answers
Dittos to the previous poster this ctc chassis has integral tuners on the pcb which i have never attempted to repair altho have many of the older ones this board is expensive to replace if you have a cable box use the composite video ouputs or use a vcr for tuner use the tv in the video mode as a monitor and call it a day the rca boxes have pictures of dogs on them
Posted on Dec 09, 2006
    President:
  • 3,130 Answers
Connect up another set right next to that set thats going out to make sure the cable or that line is not bad. It soukds as though you may have an intermittant tuner assembly inside the TV set. Its also a possablity that there could be a bad solder connectiuon in or around the tuner assembley. Not really a job for the user, as this set has hot and cold chassis, and can give a mean shock if you do not have the know how to work on these monsters. good Luck PS Please do not forget to rate this thread.
Posted on Dec 08, 2006
Sound goes out during programs on our Westinghouse t.v then comes back on at random
ln audio Settings, make sure Main Audio is selected and SAP is turned off.
Sep 29, 2018 | Westinghouse Televison & Video
When watching tv picture is perfect then goes snowy, if you turn it off and back on clear again, but doesn't last long, the longer its off the longer it stays clear when turned back on, how do I fix
Sounds like AGC [Automatic Gain Control] circuit section fault. The fault is related with its main board. It will be best to contact any service technician or the authorized service center in this case; as this is not an easy work can be done be a user. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 05, 2015 | Televison & Video
Dish Duo 625 TV 2 goes to a snowy screen randomly
Karin,
I am sorry to hear of your issue. I may be redundant but bear with me. In order to assure that the receiver is performing correctly. Change the cables on the back of the receiver. Move the cable on the in home distibution to the 3-4 out and vice versa. At TV1 change the TV itself to the channel TV2 was modulated to and see if you can watch tv error free for awahile.Do likewise on the TV2 location by going to CH3-4. Let them stay like this for an hour or so to replicate the issue. If the problem does not appear it would seem as though the receiver is fine. It also would appear that the cabling is fine also. If you are not having to reset the modulator than I would expect that the receiver is good once again. I would send a tech to your home and have him break the system down to the most basic configuration and progress from there. I personally suspect that there is a piece of hardware that is heating up and shorrting out such as a barrel, wallplate, or even an improperly prepared connector. Let me know what I can do to help you resolve the issue. If need be I will contact you local service provider to see that they assist you.
Mar 06, 2009 | DISH Network DVR-625 DTV Receiver /...
Samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 15, 2008 | Samsung PPM42S3 42 in. Plasma Television
Picture loses all normal color & changes to snowy blues & greens
Not sure what causes it but it can be fixxed by your local repair guy, I just had mine fixxed for under a hundred bucks, he takes the back off and with a tiny screw driver adjust a few screws to near brand new perfect picture.. and it has been good ever since
Dec 01, 2008 | LG RU-52SZ30 52" Rear Projection...
yes it could ba the cable itself even, but i suspect more the tuner circuit or tuner itself may have bad solder connections. Here is another test for you to try, plug another dvd or vcr, or xbox etc. into the back, using one odf the inputs. See if this works like the built in dvd. if so it will be more likely bad connections in the tuner or surrounding circuit. good luck.
Dec 17, 2006 | RCA HD52W56 52" Rear Projection HDTV
TV intermittently goes snowy.
time for a new tuner probably about 150-200 bucks to fix
Jun 13, 2006 | Mitsubishi PD-4001 40" TV
RCA Scenium D40W20 40" Rear Projection HDTV Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
