Question about Zanussi FJS1225W Front Load Washer
Washing Machine does not fill up with water
Just come back off holiday and our washing mashine is not filling up with water anymore. The tap is open. The water is coming through the pipe but is not filling up the machine. You can't hear any noise either.
    Scholar:
  • 132 Answers
THERE IS AN ELECTRONIC VALVE OR PUMP WHICH DECIDES WHEN AND HOW MUCH WATER IS ALLOWED TO ENTER THE MACHINE UNFORTUNATELY SOMETIMES IT HAS TO BE REPLACED I AM NOT 100% SURE BUT THIS MIGHT BE YOUR PROBLEM GLENN.....
Posted on Nov 15, 2008
Samsung front load washing machine model wf42h5000a. During rinse cycle machine stops and displays error code e4 and Cannot be reset.explain error code. What are possible solutions ?
hi Judi.
this is what i found.
If your Samsung washing machine is displaying a E4/error code on the control panel after completing the spin cycle and the clothes are still wet, we've got the solution for you. This fault is most commonly caused by an unbalanced washing machine load.
Samsung Washing Machine E4/UE Error Code ' eSpares
https://www.espares.co.uk/advice/symptom/samsung-washing-machine-e4ue-error-code
What does 4e mean on my Samsung washing machine?This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed or pressure switch problem check pipes as well. Water fill time out: The washing machine has failed to fill with water in a reasonable time.24 Nov 2015Samsung washing machine error code 4E and E1 Fault Not filling in ...https://www.youtube.com/watch?v=cFlnxeB0P0gSearch for: What does 4e mean on my Samsung washing machine?
or try this link.
Samsung front load washing machine error code e4 Google Search
Nov 27, 2017 | Samsung Washing Machines
Mashine fills with water
check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
Mar 24, 2015 | Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
Bad odor in my washing mashine,I need more instruciones on how to perform a "tub cleaning " Please share the nessesary information with me related to this problem. Thank you
  1. Empty your washing machine.Add 1 cup of white vinegar into your washing machine as it fills using hot water.
  2. Let machine go through an entire wash and rinse cycle.Add 1 cup of Borax into your washer as it fills with water. Wait for the agitator to start turning so the borax dissolves, then add the soured laundry.
Jun 02, 2011 | Washing Machines
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water is no fill in mashine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine cold water not filling
Typically this indicates that you have a water inlet valve that is not opening. Replacement of this part would be ideal, and should fix the problem.
Regards
Brian
Sep 10, 2008 | Washing Machines
Zanussi FJS1225W Front Load Washer Logo
150 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
