Question about Power Acoustik Efm 01 Pll Fm Modulator
Efm 01 pll fm modulator gives me lots of engine noise how can i f
How can I stop engine noise with the efm 01 pll fm modulator?
When a audio device is powered by the same (car battery) power supply then
use a ground loop isolator.
Posted on Jun 13, 2009
    Problem Solver:
  • 16 Answers
You can try running a new ground wire from the ground of the car it self. but hook it up to the ground of the RCA plug and that thould stop the noise
Posted on Nov 15, 2008
Red light constantly on, can not get player to do ANYTHING @ ALL, only RED LIGHT ON
If you wish to get some details about audio equipment and its repair ; check the site linked here. Pull up older posts.
Apr 21, 2016 | Coby CXCD380BLK Micro CD Player Stereo...
Fix car radio static
old post, and my first radio noise post.
im an old radio guy USN, and ex ham.
Q1: AM or FM? (even on cassette or CD?)
1: bad antenna, and for sure, there are upgrades !
2: too far from station, AM is worst for static, but FM has shorter distance for same station power. (I heard XERB in VietNam! AM)
3: bad radio. (rare for both am and fm bad)
4: bad alternator can sing, play with throttle and it sings higher for higher RPM bingo. stop engine, singing gone?, bingo. Alternator.
5: and last ignition noise, so stop engine still have ignition popping sounds. no more? , then Ignition noise, clicks or pops. (spark)
6: noise has 2 sources , radiated or conducted.
if conducted on power line, 12v to radio , we can buy a filter to stop that.
older cars do this. what year is yours. a honda what a 73 civic?
Aug 22, 2013 | Honda Cars & Trucks
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod .
Dec 28, 2010 | Jensen VM9510 Car DVD Player
2000 Dodge Durango 4.7 ABS, BRAKE, ENGINE light on
check fuses and relay for ur abs- possible bad relay or abs unit -have vehicle scanned some auto stores such as auto zone /advanced auto do scan for free ur trouble code(s)will give u a place to start
Oct 27, 2009 | Dodge Durango Cars & Trucks
What is a digital pll fm modulator
Hello towturtle,
An FM modulator is a little box that plugs into your receiver antenna connection. It sends a low-level signal directly to the radio which you then tune in on the FM band just like a radio station. They're handy for older receivers that do not have AUX, USB, or iPod inputs. You plug your device into the modulator and it plays through the receiver. The "PLL" just means that the tuning uses a technology called "phased lock loop" which keeps the frequency from drifting.
Hope this helps.
Oct 14, 2009 | Car Audio & Video
No brake lights, turn signals, or 4-ways.
Did you actually check the bulbs? I believe your brake lights, signal lights, hazards all use the same bulb for each side.
Your brake lights may be your brake switch just above your brake pedal.
The signals could be your electronic flasher module (EFM) located under the dash near the steering column.
Your hazards may be affected by the EFM, but not likely and the switch for your hazards may be faulty
Sep 10, 2009 | 1998 Chevrolet Blazer
01 jetta with 1.8t, the abs, check engine, check brakes, and another light that i don;t know are all on, any ideas on what causes it?
the abs control module is bad the engine light came on because of cummunication issues with the abs module
Aug 20, 2009 | 2001 Volkswagen Jetta TDI
Yinka Denis,
Start by checking the Hydraulic lifters inside the tappet cover below the cam rockers they may be the cause for the noise as this lifters need a lot of oil to work properly
Jul 28, 2008 | 1998 Mazda 626
Garmin Nuvi 660 - how do I get FM Transmitter firmware
I believe in your location it comes as an option. transmitter is an optional module. You can browse the user manual at following link (PDF file)
You can see at 35th page, simple instructions have been given for FM transmitter settings.
If it doesn't work please contact to the Manufacturer. I couldn't find Garmin's Ireland number. However you may call UK number +44-870-8501242. Or simple you call your reseller.
Good Luck
Jan 23, 2008 | Garmin Nuvi 660 GPS Receiver
Power Acoustik Efm 01 Pll Fm Modulator Logo
201 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
