Question about Kitchen Ranges
When trying to replace my cooker hood lights the new bulbs blow as soon as i put them in. Is there a fuse I could try replacing?
  • 247 Answers
Wouldn't expect a fuse to be the problem with those symptoms.
You need to fish out the old bulbs (that is, the last ones you had that worked for any period of time) and read the ratings off them. You are particularly interested in a number followed by a capital V (so this might be 12V, 120V, 230V or any of a number of others). This is the supply voltage they are are compatible with.
You need to be sure you buy replacements which have the same voltage rating. If your replacements are rated for a lower voltage, they will expire in a blaze of glory the instant you apply power. If they're rated for a higher voltage, they'll glow very dim and yellow.
You have a little more leeway withthe wattage rating (a number followed by a W, eg 15W, 25W). It's safe to go lower (though less bright), and probably OK to go a tiny bit higher but if you go much further than the enclosure is designed for, you risk problems with overheating.
If you're certain you have the right bulbs but the problem hasn't gone away, you'll need to come back with more information. It might help to know: Brand & model of the hood in question, what rating (both V and W) the bulbs are, how long they last, what it looks like when they blow (bright white light, or brilliant blue flash), what it says on the rating plate of the hood, and what part of the world you live in (tells us what the power supply is like).
But my first guess would still be that the new bulbs are the wrong type.
A.
Posted on Nov 15, 2008
MY TAIL LIGHTS AND POWER WINDOWS BLOW A FUSE,AS AS SOON AS I TURN IGNITION ON.What could it be?
replace the tail lamps... one is dead shorting (filliment broken and grounding to the body of the bulb).
Mar 27, 2013 | Cars & Trucks
CTSY fuse keeps blowing
ok have your replaced any bulbs? i have found putting bulbs in wrong or just being a bad light bulb can blow fuses. try replacing all bulbs with new ones. its cheap and it could be the problem
Mar 18, 2013 | 2008 Chevrolet Silverado 2500HD
Passenger side headlight only works on high beam. Have replaced bulb, still no low beam
If you put it in; did you touch the bulb with your fingers? If so, I've seen bulbs pop as soon as they're put in. The oil from your skin leaves a residue, and the heat goes to it, and blows the bulb. wear jersey or latex gloves when you re-install new bulb. If it still doesn't work, replace headlight bulb socket
Aug 29, 2009 | 2004 Toyota Camry
Fuse blows when shift in reverse
Am I correct, the turn signal fuse is blowing when you put the manual shifter in reverse?
Let me know.
Regards
Mar 26, 2009 | 1999 Chevrolet Tracker
2002 Highlander headlight keeps blowing fuse
In the Fuse Relay Box under the Hood there is a Headlight Relay. Replace this Relay along with a New Fuse and it should work. Let me Know. Please Rate my Response, I need all the Help That I can Get! Thanks!
Jan 28, 2009 | 2002 Toyota Highlander
Brake Light Fuse
You have a short in the lighting system. Try removing both brake bulbs and with a new fuse installed.. does it still blow the fuse? If not, then install one bulb at a time and repeat the test.. You probably have a short in or around the bulb socket.. Hope this helps
Sep 18, 2008 | 1997 Honda Civic
Indesit cooker hood
indesit hi 591 cooker hood bulb blew replaced it hood not working at all now
Oct 17, 2007 | Kitchen Ranges
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Kitchen Ranges Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
