Question about Hotpoint WMA54 Front Load Washer
Door closed indicator light
This has just started to malfunction, after several years of operation, by flashing even after the door is firmly closed.
I waited until the next day, and it worked. There was possibly condensation in the control circuitry.
Posted on Nov 16, 2008
Ge dish washer just installed. First run. All lights working but cycle will not start. Error beeps indicate door not closed but it is.
That is exactly what the problem is. There is a switch on the door latch, it is not showing the door is latched. Could be bad switch, loose hardware or not connected,
Jul 08, 2017 | GE GDF570SGFBB Fully Console Dishwasher...
The clean light is flashing on my unit
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
May 27, 2011 | Whirlpool Dishwashers
Display shows flashing 'door' warning,even though door is closed.....then when door is opened/closed a couple of times display will dissapear and re-appear every 3 seconds or so. Help!
The symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 09, 2011 | Washing Machines
The door lights of my windstar keep turning on even when the doors were closed. it killed my battery when I parked it overnite
switch in doorlatch going bad, most common drivers door. soak with penatrating oil (dont be skimpy) , open and close door several times firmly. sometimes this works otherwise doorswitch will have to be replaced
Feb 27, 2011 | 1998 Ford Windstar
We load our machine and start it. After about two minutes it sends an error message door and stops operating even though the door is firmly shut. What is wrong and what can we do?
Sounds like the door switch or motherboard is faulty. Try testing the door switch by disconnecting and splicing the wires from door together to read as door being closed. If it still errors then you have a malfunctioning motherboard. I have seen malfunctioning units that were operating near certain elctronics, and or overhead lights, same happened with ovens near airports. Try keeping all other devices and lights off and test unit, sounds weird, but I have seen many weird instances.
Jun 15, 2010 | Washing Machines
Start/stop light flashing Dryer will not start
the flashing light indicates that the door is not closing
it may be closed by the door switch is not operating properly telling the control it is closed
Oct 13, 2009 | Miele T8005 Tumble Dryer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ford taurus door ajar light stays on
have you had the door panel apart before for anything, the switch is on your latch inside your door. I hope this helps you. I am just trying to be helpful, and will help you all the way through your repair if you like, My compensation is my rating. please be generous..lol
Dec 19, 2008 | 1996 Ford Taurus
Door locked indicator light flashing
reposition the switch.. in the door
first try holding button at door with finger and press start..if same symptom appears...check tab that depresses that switch and if its good try to reposition or replace switch.
Feb 26, 2008 | Hotpoint WMA50 Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
65 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
