Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The gas jets are blocked on my zanussi gas hob
    Genius:
  • 1,447 Answers
A burner that plugs into a receptacle is easy to test. After turning off the range's power at the main electrical panel, just unplug the non-heating burner, plug it into another working receptacle, restore the power to the range, and test it. If the burner works, you know its original receptacle is probably faulty. If it doesn't work in the good receptacle, the burner is bad and should be replaced. Buy a replacement, and simply plug it into the receptacle.
When you remove the burner, look for burned wires or a charred receptacle. Check the receptacle or terminal block to see if it's cracked, loose, or looks burned. If you notice any of the above signs, replace the faulty component, too. If the male burner prongs are corroded, always change the female receptacle it was plugged into.
Hope this helps
Posted on Nov 15, 2008
  • 101 Answers
You can find the user manual from this page
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/ZGF682X-_E
It has some solutions to problems.
  • GE Master
  • 19,396 Answers
Remove the burners and clean them.
Dry them well and ensure that they are being installed properly.
This should fix the problem.
  • Ginko
    Ginko Nov 15, 2008
    I also quote the more extensive explanation given by Repair clinic:
    "The most
    common problem for gas surface burners is that they get gas but don't
    light. This is generally caused by dirt or grease splatters on the
    burner itself. Residential-grade range/stove burners are round and have
    small holes around their perimeter to allow gas to flow out and create
    a round flame. The gas coming from these holes is often ignited by a
    small vertical row of holes on the side of the burner. If these
    vertical holes are clogged or obstructed, the gas can't ignite.
    The
    solution is to clean the burners thoroughly. Use a toothpick to clear
    the small vertical holes, then allow the burner to dry completely and
    try lighting it again. If it doesn't light immediately, either repeat
    the procedure or call a qualified appliance repair technician."
Oven wont light keeps making the clicking sound smell of burning and smoke appears grill working normally?
Sounds like the jets at the base where the gas ignites are blocked. Try cleaning those out with a metal skewer or similar
Sep 12, 2014 | Ovens
Hi ive purchased a zanussi gas hob & electric grill and oven my installer wanted to knw what amp and wire to use to connect the oven nothing is stated in the manual model no ZOF35511XK
The necessary data for your installer is on
the rating plate. The rating plate is on the back side on oven and on the bottom side on hob. Never remove
the rating plate from the appliance cavity.
Make sure that the electrical information on
the rating plate agrees with the power
supply. If not, contact an electrician
All electrical connections should be made by
a qualified electrician.
The appliance must be earthed.
Dado
Sep 10, 2014 | Zanussi Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
GAS JETS BLOCKED IN OVEN
If there is only enough gas for the pilot, it is very likely the main gas ciontrol valve is either in need of replacement or the "hot wire" sensor is in the wrong place or broken.
Basically the hot wire determines if the pilot is lit before turning on the main gas supply valve. It is a safety feature to dissapoint the suicidal.
I suggest this is fitted by a gas engineer as a leak at the valve can be very dangerous.
Feb 09, 2010 | Kitchen Ranges
Zanussi Oven Fan ''Ringing''
Your fan blade is probably touching the metal shroud around it or the blade is loose. You can check this by gaining access to the fan and visually looking at it. Please do not do this with the unit plugged in, electricity kills. I hope this helps.
Nov 23, 2008 | Zanussi ZCM900X Dual Fuel (Electric and...
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Jun 06, 2007 | Zanussi 23 in. ZKT641H Electric Cooktop
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
73 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
