Question about Samsung Digimax S700 Digital Camera
Samsung s700 camera lens won't retract
The lens will not retract, we have tried new fully charged batteries. The lcd display comes on but no buttons will work and it switches off after a few seconds and beeps
  • Anonymous Mar 03, 2009
    I have the same problem and I was told it was probably dropped. I was told it would be fifty dollars to send it in. Is the camera worth that now?
    Sergeant:
    Champion:
  • 248 Answers
You must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Posted on Nov 15, 2008
Samsung es27
The manual says you can use alkaline batteries,
a SNB-2512B KIT, or 2xAA Ni-MH Batteries.
If you did use NiCD batteries, it could be they would not work, because they have another output voltage (lower).
Try a set of alkaline batteries or fresh Ni-MH batteries, before you ask Samsung. If new batteries give the same result. contact your dealer or Samsung.
Nov 04, 2013 | Cameras
Hi I slipped in the garage and dropped the camera when it was on==batteries came out and lens of course didn't fully retract. Put batteries back in and the green light comes on and beeps but won't...
Sorry about your moms camera Terry... but it sounds like it needs the lens replaced. If the lens is stuck out at an angle you can *SNAP* the inner lens section back into place if you're lucky, and it will work again like normal.
I don't know your model, but a refurb lens can usually be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Samsung Cameras
Camera will not turn ON. I changed the batteries but still no change.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 24, 2011 | Kodak EasyShare M530 Digital Camera
Lens wont go in power button wont lite or come on and screen display nothing what is happen to my fe 210 olympus camera
I have the same camera! But my display is broken. :( But it still works. Try plugging in the external video cable to see if you can see the display on your TV.
Make sure the battery is fully charged. If the battery is no longer holding a charge, replace it or use the appropriate AC adapter to power the camera.
Also, remove the memory card if you are using one in you camera.
After you put a freshly charged battery in or plug in the AC adapter, press and hold the power button for at least 3 full seconds. The lens should extend fully. If it doesn't, press the playback [>] button on the back (this should make the lens retract). Then press the power button to shut the camera off. Press the power button again to power it back up and the lens should extend out as normal. You should be OK.
If not, let me know and I'll see what else I can dig up.
The last thing you can try is updating the Firmware. Below is a link to the Firmware update for this camera. Since I don't know what OS you're using, just pick your Operating System and follow the instructions on the pages that follow the link you chose.
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1300
Dec 04, 2010 | Olympus FE-210 Digital Camera
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
My sony cyber shot dsc-s700 does not want to turn on and the batteries are new, what can i do?
I'm sorry that the camera is not turning ON. Please make sure that the battery is fully charged and there are no dust particles near the lens which stops retracting. Check if you are able to access the Menu. If yes, then, please Initialize the camera under settings 1 Menu. If you are not able to access the menu, you may have to power reset the camera by removing the battery and press n hold the power button for 1 minute continuously. After that leave the button and insert the battery and check if it helps. If the issue still persists, your camera will require service.
Sep 27, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
New camera with fully charged battery won't turn on
It may be something more serious, or your new batteries may be too low for the camera to work properly, but the problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the camera contacts firmly with a clean cloth (heavy corrosion buildups may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment, clean the contacts at both ends of the batteries, and reinstall them in the camera. Assuming that the batteries are fresh/fully charged, this takes care of about 90% of the startup problems. I hope it works for you.
Sep 06, 2009 | Samsung SL202 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Mar 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Samsung Digimax S700 Digital Camera Logo
231 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
