Question about Nokia 6630 Handheld
Isert sim card
My Nokia 6630 felt down and after goes to offline mode if I put any sim card it tells me insert sim card you think it is a hardware problem or software ? my phone doesn't have warranty thanks alot bye
  • 2 more comments
  • Snipper1 Dec 06, 2008
    but raising the pins didnt help at all... it just wenty dead from night to day, with no falls or anything like so...
  • altapo Feb 26, 2009
    My Sim Card is not woriking in 6630. I also check another Sim Cards on my Phone but they also not working. But on other phone sets they work properly it means the problem is in the phone. Please tell me about this porlblem.
    Muhammad Altaf
  • Anonymous Apr 17, 2009
    **** same problem with me DAMM
  • nacery May 05, 2009
    hi! i was using 6630 before.and now if i switch on the phn it goes to offline mode. plz help me if ther is some unlock codes......
    Scholar:
  • 29 Answers
Hi nay,
there's simple solution, first, take out the sim card and battery, then put it back again, switch the phone on, the phone will ask you "do you want to stay in offline mode?", click no. then you'll have your network again, if the message don't came out, then there's some probabilities.
1. sim card connector.. see those yellow (look like gold coloured mostly) pins that usually beneath your sim card if you insert it? probably when it's fall, it's bent, so your sim card mght not be well attached to your sim card connector. raise the feet (pins) of the sim card connector, so it became higher. so that you make sure your sim card is touched by all the pins. replace the battery and sim card, switch on again. mostly will help. but if not, try below steps
2. probably There's something cracked or broken from the body of your phone (inside), so your phone become loosened up - mainly at the screws(your sim card become not well-attached), so what you have to do, is take a screwdriver for nokia, and strengthened the screws. If it can't, try borrow 6630 of your friend, try your board (machine board) to your friend's 6630 body. If it doesn't work, then it means something on your machine board (component) is broken, not because it's just loose.
If you doesn't have friend that use 6630 too, or you feel it's hard to open your phone, look closely if there's any major crack on the body of your phone, if it does. go to any mobile phone sparepart or accesories shop, buy a new body and ask them to cahnge it (actually piece of cake, try it..) well if it doesnt work, there's nothing to lose, because anyway if you want your phone fixed, you're not gonna use it with a cracked body. (differ body and casing)
3. If you're sure none of above helpful, then it means , some component is broken. Usually it comes to SIM card connector feet (that is attached to your machine board) or the sim card IC, some small possibility is you UEM IC is broken, but in this case, i suppose not.
your sim card connector feet (attached to machine board) might be not well attached (lifted up) caused by the crash when you fell your phone down. so it just need to be reattached by solder. you need a technician for these. if it doesn't help, your sim card IC need to be replaced by a new one (this IC SIM CARD is make of glass, so it's so fragile), leave it to the technician, this shouldn't cost more than 10-20 usd i promise ^^
Good luck with raising the pin (the one that touch your sim card-don't be confused) of your sim card connector. Mostly will help ^^
Posted on Nov 17, 2008
My nokia e7 stays offline mode while sim inserted
After inserting the sim card it goes restart and ask for changing the profile from offline,when i try to change the profile from offline to others it hang and restarts showing the offline while sim inserted!tried with different sim but no use.
Jul 08, 2012 | Nokia E Series E7-00 Touch Smartphone-...
My nokia 5230 shows me am in offline mode, i need to come out of it
I think you are using the handset without sim if it is so try inserting a SIM Card and while trying to switch on phone it will opt you whether u want to continue with offline mode or not.......simply click on no and your handset will be out of offline mode
But if you have inserted the sim card and its still showing offline try going to profiles and select General mode from there....if it is changed then its superb and if not then visit your nearest service center to get the software updated for your device
Jun 19, 2011 | Nokia 5230 Cell Phone
MY NOKIA 6630 goes to offline line mode hw can i change it now
offline problem in my phone when changing another sim card
Sep 03, 2010 | Nokia 6630 Cellular Phone
When i start my nokia n97 up i get a msg asking 'use phone in offline mode?' than boots up offline. shortly after msg displays 'insert sim card' and than 'phone will restart?'what is the problem here? i...
actually there is a problem with either ur sim card or ur phones sim card slot
1. Try putting some other sim card and donot use ur phone in offline mode .
2.If u still have the same problem then there is a hardware problem go to nokia
Jan 20, 2010 | Nokia N97 Cell Phone
Unlockcode
standard code is 12345, if u dint chang ur code.try it
Jul 15, 2008 | Nokia 6630 Cellular Phone
Offline
try open ur handset and make the pcb warm with ur hairdryer and fix it again i think it is due 2 moisture and it should work as its not picking simcard.try it and reply me with results.
Jul 12, 2008 | Nokia 6630 Cellular Phone
Offline Mode
Press power button once, then select "General".
May 20, 2008 | Nokia 6630 Handheld
6630 troubleshooting
Hi! This may sound weird but have you tried checking if the sim holder is loose? Maybe the sim is not touching the terminals on the phone.
Feb 21, 2008 | Nokia 6630 Cellular Phone
Offline
may be any hardware or software problem man.....
go to u r nearest NOKIA CARE shop they will fix u r problem free of cost(if u have warrenty).
DONT FORGET TO VOTE FOR ME...
regards...
Nov 04, 2007 | Nokia 6630 Handheld
Nokia offline
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
Sep 23, 2007 | Nokia N70 Cellular Phone
Nokia 6630 Handheld Logo
390 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
