Question about Lexmark X7170 All-In-One InkJet Printer
Error 2200 lexmark 6250.
My printer has this error and nothing seems to work. i have unplugged several times, installed the software, etc. any ideas?
  • 10,515 Answers
Hey ,
Follow the steps :-
Step Action
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Posted on Nov 15, 2008
When i try to print something a window pops up that says "communication not available" ive tried restarting, unpluging the power cord and the usb cord...nothing seems to work
This problem could be caused by several factors - incorrect USB port selection, your printer is not set as your default printer, firewall, etc. This article in the Lexmark website: Communication Not Available' Error Message and Print Job Stalls in Print Queue will help you determine the cause and resolve your printing issue.
May 11, 2011 | Lexmark X2600 InkJet Printer
Error 2200 on 7170 lexmark
The error indicates that the scanner has stalled or jammed. Here's an article on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link: http://bit.ly/aBUoJK. Just follow the troubleshooting steps on the page. If all else fails, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 27, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
LXBBDR5C needed for lexmark x75 with windows XP
Most probably the software got corrupted. Uninstall the software from the computer by going to Start Menu > All Programs > Lexmark Series folder > Uninstall. Restart the pc. I recommend you use an updated version of the software which is available for download in the Lexmark website. Just click on this link: Driver for Microsoft Windows XP . Download and install the software.
Apr 08, 2010 | Lexmark X75 All-In-One InkJet Printer
Lexmark T520 wont work!
To start do the following:
Unplug printer USB, unplug power from pc and also remove the battery if it is a laptop, and restart printer and PC.
With printer still unplugged go to control panel>>printers and empty the printer cue.
Test a replacement USB cable and try plugging the printer on a different USB port.
If the above did not work , then reinstall the printer software using the printer CD. Unplug the printer and start software installation with printer USB unplugged.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Mar 06, 2009 | IBM Infoprint 1120 Laser Printer
When trying to install software for Lexmark x2580 it seems to hang part way through. Heve tried several times from disc, and downloaded software from Lexmark. Message in bottom right states 'a problem...
Hi ,
Definitely u install printer through connecting printer to pc .that's why the problem is occure........
please uninstall of drivers& software of printer restart pc with disconnecting printer from computer...
then install software for printer ..follow the instruction ..then when pc notify u to connect printer/harware detection then connect printer to pc & get printe on ....i am sure u r printer will be detected & install scessfully done
if this information is useful for u please Rate me.........
Jun 14, 2008 | Lexmark Office Equipment & Supplies
Lexmark x4720 ink cartridge installation
Stop buying lexMark products, They are not worth the plastic they are made from.
Jan 08, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark z600 will not print documant
Sounds like the install was corrupt.. Try uninstalling and re-installing your software. Make sure your drivers are up to date also. You can download them from the lexmark website.
Jan 06, 2008 | Lexmark Z600 InkJet Printer
What is error 2200?
i had error 2200 on my X7170 lexmark....i turned it off.uninstalled the lexmark software in uninstall/add programs in the control panel.restarted my computer.installed the software again....then worked like a charm....hope it works...peace.
Nov 19, 2007 | Lexmark P6250 All-In-One InkJet Photo...
What is error 2200?
I used this link and it has instructions... it worked for me...I unplugged the Lexmark from the back, waited, turned back on and it worked. Good Luck! B.
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:537:0:0&framed=&docid=ENUS24402&relevance=0
Nov 05, 2007 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
202 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
