Philips DVP3010 dvd player. Turns on, opens and takes in dvd's OK. Can hear dvd spinning but won't progress beyond 'load' message.
  • mayerla Dec 22, 2008
    It began that I could not play CD's. Now my DVP3010 dvd player is not able to play DVD's too. When I load a disc I heard it spinning, but I can hear a clicking and crackling noise too. Different displays can be seen on the front panel like 'unkown' , 'root' , 'no disc' etc.
silly girl
  • 513 Answers
SOURCE: dvd not loading
The general amateur fix, and one with surprisingly high success rates is to brush dust accumulated on the laser lens. This is assuming you get this with all disks, otherwise better not risk opening it. Plug it out, open the screws, open it up, if necessary remove another board covering the lens, and gently brush the dust off. Assemble back and hopefully you're solved. Anything else is for the lab(motor, lens assembly, focusing problems etc) Good luck
Posted on May 31, 2006
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
  • 4 Answers
SOURCE: philips DVP642 DVD Player "No disc" problem
if its still under warranty, do that.
if it's not, try taking it back to the store and asking for a replacement. don't let the floor salesman tell you no. insist on speaking to the manager. my strategy is to: "be polite, appear slightly stupid, and dont take no for an answer" it works 80-90% of the time.
if you cant get anywhere (or dont want to try that route), then you have nothing to lose. open the case and try to clean the mechanism and lens
two screws on either side of the unit, and i think another 4 screws on the back side. this will allow you to pull the top cover off the unit.
clean the mechanism, and clean the lens. you can buy cleaner if you want, but i just use a soft cloth and some "no-streak" type window/glass cleaner (windex)
clean your disks as well. this DVD player seems to be sensitive to scuffs and dust more than some other players. you just have to be persistent.
or you could buy another DVD player. at $60, its really a pretty good deal anyhow.
good luck
Posted on Mar 09, 2008
SOURCE: PET702 Portable DVD player 'No Disk'
try this:
Press setup on the remote
Use the arrows to navigate to Prefreneces (pref)
type 9 6 5 3
Select Region code (press down arrow to set to 0, open for all codes)
Press setup again to exit
is working :D
Posted on Mar 28, 2008
  • 6 Answers
SOURCE: DVD PLAYER DISC TRAY DOES NOT OPEN
tap it gently from the side while pressing the button......or with a knife try to open it gently...while pressing the button....after it,s open..clean the side n the belt..
Posted on Jun 26, 2009
My philps Dvd player won't work correctly
From the description the pladder motor is bad, " disc spins on" or it is missing the 5 volts that drives the motor. The laser pickup that pops up and down appears to be working fine.
Apr 13, 2012 | Philips PET741 Portable DVD Player
Tip
Stuck in Progressive Scan? Can hear movie but Can't see Video?
Here's the scenario:
All cables hooked up correctly.
System is stuck in Progressive scan (P-SCAN on display viewer)
SITUATION:  You can hear the movie playing, and you are certain all connections are correct.  Your Television may not support Progressive Scan Video so all you hear is the Audio Track.  Here's what to do.
SOLUTION:
Step 1: Remove DVD from player.
Step 2: Unplug from power source for 20-30 seconds, plug back into outlet.
Step 3: You need to press two buttons at the exact same time.
Step 3a: Prepare to press #1 on your HTS remote
Step 3b: Prepare to press OPEN/CLOSE button on your HTS.
Step 4: Press both OPEN/CLOSE button and #1 on your remote at the same time and HOLD until P-SCAN on your HTS display turns off. Should take no more then 20 seconds max.
Step 5: Repeat all if human error occured and no improvement. Or call 1-888-PHILIPS for HTS tech support
Enjoy!
NOTE: This solution was given to me by Philips Tech Support Division when I encountered same issue.
on Sep 11, 2007 | Philips HTS3400/37 System
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
Dec 22, 2008 22 joulukuu 2008 - It began that I could not play CD's. - Se alkoi siitä, että en voinut soittaa CD. Now my DVP3010 dvd player is not able to play DVD's too. Nyt minun...
Please replace your DVD drive. There is a problem on the motor and reader of the DVD Drive. If your continue using this drive it will damage your disk. Have it replace so that it won't create errors upon using it.
Aug 12, 2010 | Televison & Video
Was working earlier today, now won't. Turns on
hello,
i will suggest you check the lens if it is still working properly. then you can tell why it seems to be giving such fault.
clean the lens and try it again.
the disc you are trying could also be a problem so you make sure the disc is ok before trying to play it on your dvd.
goodluck
Feb 04, 2010 | Insignia NS-BRDVD Blu-Ray Player
New DVD player. It spins then says No Disc
Dear who ever, I did not fix the problem nor will I now bother,
I am taking it back and will get my money back.
I tried the calling the number twice. I was in the queue as caller 11 twice!
It hung up on me when I got to caller 2. The second time it said they were
only open 8 am to 5 pm or something and it was 1 pm on a weekday !!!
The web site was not clear and all I have gotten now was 2 emails from you all with nothing to say!
Dec 30, 2008 | Memorex Progressive Scan DVD Player...
DVD Player Error Message
I have this problem.. I put in a DVD that I know it has read ok before. But, now it takes a long time trying to load and then it just stops trying and returns 'NO DISK" So, I opened it up and watched it try to load. The motor on the DVD drive was struggling and couldnt keep the disk spinning a the correct speeds. Now, I am looking for a drive replacement. I hope this helps.
Oct 20, 2008 | Philips HTS3400/37 System
Turns on but won't play DVD
I have one of these players from philips,and it is just out of waranty,and it was only used about six times and now it won't read the dvd's anymore.PURE JUNK DON'T BUY.
Aug 25, 2008 | Philips DCP855/37 Portable DVD Player
Cant turn off progressive scan
Press OPEN/CLOSE on the DVD player
to open the disc tray.
Press numeric keypad ‘1’ on the
remote control for few seconds.
➜ The DVD blue background screen
will appear on the TV.
Aug 24, 2008 | Philips DVD 622 DVD Player
Televison & Video Logo
349 people viewed this question
Top Televison & Video Experts
