Question about Panasonic KX-TG2248S Phone (KXTG2248S24GHZTELEPHONE)
E3 Error on Cordless Phone
In my work, I recently came across a couple of cordless phones packed away in a cupboard. I have been asked to see if they can be fixed (as my father is an electrician with experience in telephones). I have not yet had a chance to look at all, but one that we're looking at right now is a Panasonic KX-TG2248 and when we plugged it in (to see if perhaps the only problem was that the batteries needed charging), the screen had an E3 on it and the charger light, the answer / on light and the play message / slow talk light are all blinking. I'm searching now for possible solutions, so if anyone has any ideas, please feel free to let me know. *Also I have not found the manual for the phone, so that makes it even more critical that I find another source for problem solving*
  • saginzburg Oct 23, 2008
    The same here...
The cordless handset is not working
I suppose you put the handset back on the base unit so that they synchronise first.
Nov 29, 2013 | Sony SPP AQ600 Cordless Phone
I have a CTP8600 Cordless phone made by Coby in 2003. The battery pack for the handset is apparently no longer charging. Coby has stopped making (or supporting) this product. I would like to replace the...
Try taking the battery pack to your local radio shack store. They can usually match the original battery pack with a new, compatible one even if they no longer make the EXACT one that came with the phone. This recently happened to me with a panasonic phone bought around 2002. phone stopped charging, no longer make the phone, etc. I went down to radio shack and they fixed me up with a new battery (not exact brand/part number as original) and it worked. Hope this helps you.
May 20, 2011 | Coby CT-P8600 Cordless Phone (CTP8600)
We bought a Panasonic KX-TG 8321 AL cordless phone last christmas and it was working well until recently. It suddenly started picking up interference from the adsl wi-fi transmitter to the point we need to...
Unfortunately the EMI/RF interferances are a conflicting part of our day to day life.
Now you have this conflict of the wifi with your cordless to interfere.
So one option is to keep the base phone off to another location away from the wifi.
Move the antennae away from the strong signal pick up to lessen the interference. If porblem started recently it can be fault in the base unit changing. frequency
Sep 28, 2010 | Panasonic Cell Phones
Static on Cordless Phone after Power Outage
First try plugging the unit in and out a couple of times. If that doesn't fix the problem then check the battery packs on the phone units. BTW I meant to plug and unplug power to the base unit. If these solutions don't work then most probable cause is an audio component failure due to the voltage surge on power up. This is normally when most electronics will fail. Hope this helps.
Mar 27, 2009 | AT&T 2230 Cordless Phone
When the cordless phone is in use the internet on the laptop cuts out can anyone help
Assuming you have DSL - Verify that you have a DSL filter in the phone line that leads to the base unit of the cordless phone.
Assuming your laptop connection is wireless - See if there is a frequency conflict with your wireless internet and the cordless phone.
If neither of these suggestions help, please reply with specific details regarding your internet connection (Cable/DSL) and the connection of the laptop
Dec 01, 2008 | Lands Phones
GE cordless phones
If the cordless phones are old 2.4GhZ phones, and you have wireless internet (which is probably also 2.4GhZ), the wi-fi could be messing with the phone signal/channel. Some cordless phones have a switch that allows you to switch channels. If so on your phone, try that.
This was happening to me, along with my internet connection dropping off every time the phone rang. So I went out and got a set of Dect 6.0 cordless phones, and the problem went away.
Good luck.
Jan 13, 2018 | GE 27851FC1 2.4 GHz Cordless Phone
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
E3 message
Unplug it. Let it stay unplugged for a couple of minutes. Plug it back in. That should reset the phone.
Dec 17, 2007 | Panasonic KX TG2258S Cordless Phone
PANASONIC KX-TG2258 E3 ERROR CODE
This method worked for me!! you guys should try this.
i've copy this review from amazon.
by Kane Doerfler
"After a brief power outage from a thunder storm, I also experienced an e3/lights blinking error. I unplugged the phone and plugged it back in several times to no avail. After doing this a couple of times unsuccessfully, I hit the "STOP" button on the base immediately after plugging it in (before it completed booting up to show the "e3 message")and it reset itself and now works fine (or as well as it did prior to the e3). Try it before tossing yours in the garbage"
thanks to Kane. I saved my phone~!!
Nov 17, 2007 | Panasonic KX TG2258S Cordless Phone
Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Oct 09, 2006 | Sony SPP-S2730 Cordless Phone
Panasonic KX-TG2248S Phone (KXTG2248S24GHZTELEPHONE) Logo
122 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
