Desktop icons problem.
I have windows xp after install hisis software desktop icons is not comming.
Plz right click desktop and arrangeicon by click show desktop icom then problem solve
Posted on Nov 15, 2008
Cc4 108 0000a420
Right click the install icon
Select properties
Select compatibility
Select to run the install program in Win XP compatible mode with admin rights
Thanks for the opportunity to help and please rate this post.
Kenneth Calhoun
Feb 18, 2014 | Dell DIMENSION 3000 CELERON 2.4GHZ...
I followed partricias solution but still my imaging studion will not load
Teifion Thomas:
If you did the complete install of the software, then the program is there, you just don't have a shortcut icon on your desktop. You'll have to click on "start" then find the folder that contains your imaging studio software executable file (when you double click on that icon, imaging studio comes up on the screen). resize the window so that you can see part of your desktop behind the current window, left click on the executable file icon and drag it to the desktop and release the mouse button. Click on create shortcut and you'll have an icon for your imaging studio on your desktop.
Sep 15, 2012 | Office Equipment & Supplies
I need to reinstall Safari for XP. I deleted (uninstalled Safari this morning and now need to reinstall it.
To Download Safari:
1) Go to http://www.apple.com/safari/
2) Click "Safari 5 Free Download"
3) Uncheck the checkbox labeled "Keep me up to date... etc."
4) Be sure the button labeled "Safari 5.0.4 for Windows XP, Vista or 7" is selected
5) Click the blue button labeled "Download Now"
6) On the popup window, click the button labeled "Save"
7) Navigate to your desktop in the new window and click "Save" once more
To Install Safari:
1) Double click the icon which reads "SafariSetup.exe" on your desktop
2) Windows XP MAY ask if you're sure you wish to run this program depending on your security settings. If you see this popup, click "Yes" or "Run".
3) Click "Next"
4) Click the button labeled "I accept the terms in the license agreement"
5) Click "Next"
6) Uncheck the checkbox labeled "Install Bonjour for Windows" unless you are absolutely sure you need this additional program.
7) Click "Install"
8) Click "Finish"
Safari is now installed on your machine. Keep in mind that deleting an icon from your desktop does not uninstall a program. If you accidentally delete your desktop icon, this can easily be replaced through the start menu.
Apr 07, 2011 | Computers & Internet
I have a desktop hp 3570c scanner but this software is for xp I need vista software + desktop icon
You can download the scanner drivers from the Compaq/HP WEBsupport/download page. Make
sure you select your model scanner and the XP orVista Windows version of the drivers you require
and install them. Click onthis link to download the drivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Feb 26, 2011 | HP ScanJet 3570C Flatbed Scanner
Unable to use desktop icon to access Vaio home entertainment
check that the software related to that is installed properly. if it cant solve ur problem then u can install a new window and then install all the softwares again ok. it will solve ur problem
May 21, 2009 | Sony VAIO VGC-RB34G PC Desktop
Don't have the software to install the printer
For Windows XP you can download drivers here.
If it different OS, let me know.
Apr 26, 2009 | Office Equipment & Supplies
It takes my PC a very long time to boot up, what can i do?
If you have installed any softwares recently it might slow down the pc as many softwares will install a startup file in order to start faster. You can shut these programs from starting up when the pc starts.
I put 2 steps to resolve this in order of simplicity.
Remove icons from the Startup folder
Some programs open with a shortcut icon in the startup folder (Startup icons). Use the following steps to show any startup icons that might be hidden and remove startup icons from the startup folder:
NOTE: Removing items from the Startup folder does not uninstall the software program.
1. Right-click the Start button, and click Explore . The Windows Explorer window displays with Start Menu already selected.
2. Click the plus sign ( + ) next to Programs .
3. Click Startup . The shortcut icons are listed in the right pane of the window.
4. To show any hidden icons, click Tools , click Folder Options , and click the View tab.
5. Click Show hidden files and folders (Windows XP/ME) or Show all files (Windows 98), and click OK .
6. Click an unwanted startup item in the right pane of the window and drag it to a blank area on the Windows desktop. Release the mouse button to drop the icon onto the desktop.
7. Continue dragging unwanted icons until all unwanted startup icons are on the desktop. Click Yes to any window that display asking to confirm the removal of a read-only file.
8. Close Windows Explorer and restart the computer for the changes to take effect. Delete the startup icons that were moved to the desktop after you are satisfied with the way the software programs are working.
If you find that a particular software program should not have been removed from the Startup folder, double-click the startup menu item to open the Startup window. Then drag the icon from the desktop back into the Startup window.
Jan 11, 2009 | Compaq Presario 5000 PC Desktop
My desktop icons are written clear but under colour
If you are running XP, click Start > Programs > Accessories > System Tools > System Restore.
Follow the prompts and select a bold date back to a time earlier than this problem occurred. It will require a reboot, but stands a good chance of resolving your issue.
It will not remove anything from your computer, but you may have to re-install any software recently installed.
If you get it fixed and then re-install some software, the problem may come back. That would let you know the software is causing the problem.
Honest1abe
Dec 29, 2008 | Microsoft Windows XP Professional for PC
Printing works but the scanner wont work with windows xp
Download & save the HP950 software to your PC. Run the program. After the install you should have your icons back on your desktop & down by the clock as well.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=60259&lang=en
Please download & install the (HP Imaging Software Critical Update) too.
Mar 14, 2008 | HP PSC 950 All-In-One InkJet Printer
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
