Question about ASUS P5RD1-VM Motherboard
How to install SATA HDD for asus motherboard P5RD1-VM?
  • Anonymous Jan 04, 2009
    how to install the sata hdd for asus motherboard m2npv-mx
  • 90 Answers
Do you have previous Seegate Harddisk or SATA one?
If the SATA is installed previoulsy then it is not to much difficult to install a new SATA HDD. But if you are trying to install Sata on Seegate HDD or in combination then it can not be done.
Let me know in either case, with more detail as you can provide here (For OS, Hardware Specification etc)
Thanks
Posted on Nov 15, 2008
When trying to install xp in asus p5rd1-vm show no hdd is there.but already have an xp is in it.then i tried to down load sata raid driver for this board.but there is no driver.please help
You need the original cd from this product to install... i have it when i buy this pc (not new/second)
I have been there too...
But i heard from Indonesian people, they use cloning (clone OS) using Norton Ghost...
Have a nice day ;)
Aug 03, 2011 | ASUS P5RD1-VM Motherboard
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I want to install xp sp2 on Sata HDD The motherboard is P5RD1-VM but there is error set up did not find any hard drive plz tell me settings of bios to sata compataibale
It's likely a problem with your connection cable from the HDD to the motherboard. The bios shouldn't have to be set up for the HDD to be recognized through a sata port.
Jul 17, 2011 | ASUS P5RD1-VM Motherboard
P5rd1-vm rev 1.0 motherboard 500gb sata harddisk installtion not winxp installtion problem
The Windows XP installation CD does not include a SATA driver.
For instructions on installing XP on a SATA hard drive, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Oct 04, 2010 | ASUS P5RD1-VM Motherboard
I have an asus p5rd1-vm motherboard. I found problems on installing windows xp using sata hdd. Please help me to install windows xp2 as i am not using floppy drive.
The Windows installation CD does not have a SATA driver. You need a SATA driver of a floppy disk or turn off SATA native driver in the BIOS.
Please click on this link and follow my instructions on how to Install Windows on a SATA hard drive :-
I suggest you install SP3 (service pack 3) rather than SP2, it contains the latest bug fixes. The SP3 cannot be installed from a floppy, it can be downloaded from Microsoft, it is a large file approx 300Mb, I suggest you install it from a CD if you can borrow one.
Aug 09, 2010 | ASUS P5RD1-VM Motherboard
Sata HDD NOT DETECTING IN XP SETUP
If you're using a scsi card and connecting the hard drive to the card you need to have the scsi set-up floppy disk. When the blue screen starts during windows installation watch the bottom of the screen. It will tell you to press F6 key then to insert the floppy disk.
If you're using a sata drive connected directly to the motherboard (not in a raid configuration) you shouldn't need anything but the windows disk. The motherboard drivers and utilities disk should have the files to create the scsi install disk.
Sep 11, 2009 | ASUS P5RD1-VM Motherboard
Install SATA HDD for asus p5rd1-vm
The motherboard will support this drive.
I will assume you simple need it as additional storage set up as an additional drive?
If you do not see it in My Computer after connecting power and SATA cables, you will need Activate the Drive and Format it
To do this go to Control Panel - Adminstrative Tools - Computer management - Storage - Disk Manangement
You will see the harddrive here, right-cick it, Activate as a simple Partition and then format it.
You will now see it in My Computer and will be able to store on it.
Jan 05, 2009 | ASUS P5RD1-VM Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Raid controller disabled to P5RD1-VM
The manual is here: http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5RD1-VM/e2440_p5rd1-vm.pdf (very slow download). Look under Advanced/Southbridge/SATA
Sep 29, 2007 | ASUS P5RD1-VM Motherboard
ASUS P5RD1-VM Motherboard Logo
628 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
