Televison & Video Logo
Anonymous Posted on Apr 20, 2012
LG LED TV SMPS & Panel cost
Hi, My LG 32LE7500 LED TV SMPS is under repair and I was advised replace it. I would like to know the cost of SMPS and PANEL for this LED TV in India. Can anyone help on this please? Thanks
Anonymous
Level 3:
Top Expert:
  • Master 14,553 Answers
  • Posted on Apr 20, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2714592
Points
48227
If you are talking about the Display Panel and a board---the cost of the panel (entire front screen unit) will easily exceed the cost of a new set. If it is being repaired and they are authorized LG they should be able to get part number for both the smps and the panel and a price.
5 Related Answers
Anonymous
  • 335 Answers
  • Posted on Jan 26, 2009
SOURCE: CRACKED LCD PANEL Vizio GV42L 42 in. LCD
We have 42 inch Vizio LCD's in refurbished condition at the repair shop. The glass LCD's are around $230.00 for 42 inches. This is only for the glass panel and doesn't include the CCFL assembly which you probably don't need as its just the glass that's cracked.
Have a professional service technician install it as the LCD is very thin and extremely fragile and can easily crack under it own weight if handled wrong. Plus there are ribbon cables that require skill to attach and detach successfully on the control driver board.
We have all parts for Vizio, Samsung, Sharp, Toshiba, Panasonic, Philips, Akai, Sony, Maxent, Proscan, LCD and Plasma tv's.
E-mail me for more info...
Robert Johnson
  • 395 Answers
  • Posted on May 11, 2008
SOURCE: replace protective platic panel in an lcd tv
unfortunatly the protective screen is not available as a seperate part, it is the whole LCD panel that needs to be replaced. if the TV is the LC-42d62U then the part number is R1LK420D3LF21 and can be found at www.vancebaldwin.com for $2362.80.
Anonymous
  • Posted on May 11, 2009
SOURCE: lcd screen panel replacement for 37 LG hdtv
Go to shopjimmy.com They sell replacment panel for a resonable price.
lloydainey
  • 9 Answers
  • Posted on May 23, 2009
SOURCE: Looking for replacement circuit board for HP TV
On ebay for less than $100
Anonymous
  • Posted on Dec 14, 2009
SOURCE: Philips 42PF7220A/37 42'' TV (LED flashes red 7 times)
Five buck solution; If you have any tek skills at all and are feeling adventurous; UNPLUG THE POWER, remove the back panel; You will be faced with the mainboard. In the lower right quadrant you will see two small capacitors, like tiny yellowish coke cans. If these are bulging, there lies your problem. These must be replaced. If you have no soldering skills, take only the mainboard to a fixit shop and have them solder in the two capacitors easily found on line. No guarantee's but worth a try
2answers
My lg tv model 47ln5200 has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Tv was on and the picture went out. no picture but i have audio. tv is only 5 months and lg refuse to fix it
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
If the TV is under warranty period, LG is responsible to make it right. It is not a defect caused by you.
Backlight inverter board for LG TV What is correct part to restore illumination to TV
LED TV Repair Tutorial - Common Symptoms & Solutions ...
? 6:43
https://www.youtube.com/watch?v=8HG7efTMj78
Jan 3, 2014 - Uploaded by ShopJimmy.com
LED TV Repair Review & Overview-Common Problems - Symptoms, Solutions Click Here to BUY TV REPAIR PARTS: ...TVs inputs and outputs, this main board is connected to thebacklight inverter/LED driver via this ribbon cable. ... ofillumination for the screen and the board that drives thatillumination.
LCD TV Repair Tutorial - How to Replace the Backlight ...
? 2:30
https://www.youtube.com/watch?v=s3r1GZCA0K4
Dec 31, 2012 - Uploaded by ShopJimmy.com
Philips TV Repair Flickering Image On TV Screen Tutorial Guide How to ... Inverter on LCD TV Easy Fix Help Click Here to BUYTV REPAIR PARTS: h... ... How to Replace the Backlight Inverter Board in LG & Philips LCD TVs.Missing: restore ‎illumination
Sanyo 42 led lcd tv - Engine cork
2answers
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
1helpful
SINGLE VERTICAL LINE IN MY LG LED TV
A single line indicates a failure in one of the hundreds of connections on the back of the LED display panel. It normally cannot be repaired, but can be replaced. It may be more cost-effective to replace the unit.
Recently purchased led lg 47" hdtv after two weeks the screen is cracked. I don't know if it was there before but we have two small children. Purchased through e-bay. What is the best way to g
If the screen is cracked, there is no other way to repair it, rather than replacing it. Replacing the screen will cost around 2/3rd of the total cost of the TV. Screen cracking will not come under warranty, as it is not the fault with the company which manufactured it.
2answers
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
I am having problem with my lg tv 21 inches.problem is "no audio & video when i power on the tv.signal is there in tv,but no display.please help me
this is a problem with the controlling module on your main board and can only be fixed by replaceing the board i would advise having it sent back on warranty if it is under it but otherwise it will cost around 130 pounds sorry i hate giving bad news i run a repair service so i can garuntee this is the problem please make sure and make payment as soon as possible thank you
LG LCD TV there no display on screen. Service person says it SNP(power supply) card has to be replaced as its supplying more current to PCB & cost is Rs. 6000. I would like to know whether the...
No power LED light indication to the tv screen panel at all or LED light power indication flashes?Yes,it is the power supply board have problems.Tries websites like Shopjimmy.com,Ebay.om to buy a refurbish power supply board for the replacement.Refurbish power supply board cost about usally $100-$110 plus shipping.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
