Question about Kenmore 53642 / 53644 Side by Side Refrigerator
No water from dispenser
My Kenmore Mod # 106.54382300 has no water coming from the dispenser, the ice maker is still working fine, but the accelerator switch keeps beeping on and off when we open the door (might be related).
  • 1 more comment
  • calman1 Dec 31, 2007
    I have a Kenmore side by side and the water dispensor is not working. Water flows fine to the last union on the bottom of the refrig. Tried to fish a small wire through the remainder of the line but it stopped about a foot from the dispensor. Should I blow compressed air through the line? How do I go about taking the front panel off?
  • cammattangel May 20, 2008
    I have had my side-by-side for at least 10 years, just in the past couple months water stopped coming out of the water dispenser, but ice works fine. And now I have water flowing down into the bottom of my frezzer. I do not knkow what could be causing this, can you please help?
  • aaron725 Mar 26, 2009
    I had the same problem with a madly beeping acceller-ice button. I
    took apart the control panel and then used a soldering iron to remove
    the acceller-ice switch. It solved the beeping problem, although I can
    never.
    I never had any issues with the dispenser, but I did have a problem with my ice-maker not working. I figured out that the incoming water had frozen inside the black rubber tube near the top of the fridge. I jammed a screwdriver up the tube to loosen the ice and then the water started to flow again. It has happened to me three times in the 6 years I've owned this fridge.
  • 237 Answers
If the ice maker is still working then water of course isn't an issue. The water dispensor has a solenoid valve that opens to let water flow... do you hear a "click" from the back of the frige when the water lever is pushed? If not, the valve is likely bad. Another possibility is the switch behind the water lever itself is not being pressed hard enough or even broken, see if you can press the switch with your finger up inside behind the lever area (flashlight needed to see up there). If that lever isn't hitting the switch it won't work of course but it could be a bad switch too. Sometimes the little plastic pins that hold the switch in place get broken by slamming a glass into the lever over time. In other words the switch is fine but just hanging inside the door area never to be hit by the lever again. I would be good to check it by pulling the cover off that are and visually inspecting the whole back side of the lever area/switch are for broken parts. The link below may help you with parts and diagrams to see the unit better. http://www.partselect.com/KenmoreModels.aspx?ModelNum=106.54382300&searchTerm=
Posted on Nov 24, 2006
Water is leaking from our water dispenser. A large amount. An 8 oz cup fills up within an hour. It is coming from the water dispenser on the outside of the fridge. The ice maker is working fine but the...
Your water valve on the back of the refrigerator is plugged up, there are two sides to it, one side is for ice maker the other is for chilled water dispenser.You may be able to clean it out, if not then you will have to buy a new valve.Hope this helped.
May 29, 2011 | Kenmore Refrigerators
Ice maker not working on Kenmore Model # 106.54563300 Water comes through water dispenser fine Water came pouring out through ice dispenser door so I flipped bar up to turn it off Removed front box held in...
First the arm has to be in the down position. It sounds like you said theres water in the ice maker. If thats the case then it should have frozed. The ice cannot drop unless the ice maker heater comes on. Then the ice maker scoops the ice and drops into the resoviour thingy. If you have ice in the ice maker tray but no ice in the bucket then the ice maker is defective.
Mar 25, 2010 | Kenmore Freezers
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
I have Kenmore frostless 25 with an ice and water dispenser in the door. It does not makes ice, but the water dispenser works fine. I could hear the ice maker switch bar moves up and down in the ice...
Most times it's the water control valve on the rear of refrigerator and near the floor. And you can test the ice maker by filling with water. Let it freeze and if it dumps the ice and does not refill then the water control valve. If the water freezes and nothing happens the the ice maker is the problem. If you had your model number I could tell you part numbers. Anyway try that and let me know your findings. Kenmore uses a model number like 312.54689 for example found on front near floor and behind the fresh food section door. Let me know, Thanks Sea Breeze
Aug 20, 2009 | Kenmore Refrigerators
Kenmore side by side makes no ice
the water line coming into the freezer may be iced up. or the motor that spins the ice "ejector" arm may be stuck. try spinning it manually (just dont force it).
May 29, 2009 | Kenmore 44103 Side by Side Refrigerator
Kenmore model #106 55522400
YOUR PROBLEM COULD BE WITH YOUR INTERNAL ICE MAKER HEATER ELEMENT OR THE INTERNAL MOTOR OF THE ICE MAKER NOT OPERATING WELL.BEST YOU GET A EXPERT TO ATTEND TO THAT AS IT IS A COMPLICATED COMPONENT TO WORK WITH.GOOD LUCK
Aug 20, 2008 | Kenmore 50522 / 50524 Side by Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
chances are dispenser board is bad check power going in the board should be 120 volts and power out if no power out replace board
Dec 17, 2007 | Kenmore 25.1 cu. ft. Side-By-Side...
Accelerator switch
Yes, that would be a good guess as it controls how the "buttons" work.
Dec 04, 2006 | Kenmore 53642 / 53644 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
544 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
