Question about Sony PlayStation® 3 (60 GB) Console
Ps and TV not connecting using av cable
I connected my TV to the ps3 , plugged the ps3 in and nothing happened. I'm at the right channel , it has always worked there , I tried the other TV in my house but still , nothing. The TV is on and the ps is on, in case you're wondering. O_o
  • 3 more comments
  • asdfghjk
    asdfghjk Nov 15, 2008
    ...wait..what? o.o.
    btw, i found a solution. ilu internets :D
    I used my ps3 with a hdtv. and I didn't change the settings ^^'
  • meganiruban Dec 10, 2008
    how do you change the setting back to normal again?
    i got same prob
  • Anonymous Dec 26, 2008
    I have the same problem after using it with a HDMI cable. When I tried to use it with a normal cable nothing will happen.
  • supaiku420 Jan 05, 2009
    I recently purchased a 60gb ps3 off of eBay and I'm having this same issue. I've tried the reset solution by holding the power button down for 10 seconds multiple times, tried combinations of different cables and monitors, but nothing works. Neither the video nor the audio appears. I've also tried all combinations with a game and without a game in the system. Please help!
  • tooky173 Apr 06, 2009
    i have been using my ps3 for a year with a hd cable but one day i moved ps3 down stairs but then moved back up. but when plugged it in up stairs with hd cable the ps3 starts up but i cant get it to connect to tv. ive also tryed using av cables.
When you turn on the ps3 hold the power button till the system beeps
Posted on Nov 17, 2008
    Problem Solver:
  • 13 Answers
Hi I'm ryan if you go to audio settings make sure that it is set on HDMI (if thats what your using), or AV also if thats what you are using. If you are using AV cables and it is set on HDMI it won't work. So I would start by checking and resetting you audio and video connections on the PS3 Home/setting.
Posted on Dec 31, 2008
At the moment my ps3 is doing same thing i may resort to using a big f*%$ing hammer hope this helps
Posted on Feb 18, 2010
    Problem Solver:
  • 10 Answers
Did you put you're tv on VIDEO ?
Posted on Nov 15, 2008
Doesnt show up on the television. It does turn on. turned playstation on and off, tried different connections, still nothing
It is likely that the problem is your AV cable. This cable has one plug that connects to your Playstation 3 and a red plug, a white plug, and a yellow plug that connects to your television. Follow these steps to get your PS3 up and running again
  1. Unplug your AV cable from your PS3 and T.V.
  2. Plug in your AV cable to your PS3 and T.V.
When plugging your AV cable back into the T.V. make sure that the red plug is in the red socket, the yellow plug is in the yellow socket and the white plug is in the white socket.
If problems persist try using a different AV cable.
Jun 13, 2011 | Sony Playstation 3 (PS3) Console
I started useing my hdmi cable now it wont work and now my other normal cable dose not work can any one help me
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Press 'reset system' option 1.
Be sure to have the av cables or component cables plugged in and your tv set to the right channel.
Jan 20, 2011 | Sony Playstation 3 (PS3) Console
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Trying to connect a PS3 to my hotel room tv. I have 3 color AV cords, and I´m putting each accordingly on yellow, white and red, but can´t seem to see or hear anything on AV source. What am I...
did you set to AV 1, 2, 3 or DVD input, it is depend to where it connected to..whether you connect to the AV input front panel, or rear. if not sure you can connect it to the front panel and sequentially sets the AV source, if still the same. you can connect the cable to the DVD input should be the type of cable TV .. PS 3 is like this:
Connect red, green blue Plug/jack accordingly to each colour on DVD INPUT the TV. set AV Source to DVD.. please Try and if the same result , you have to replace the AV cable of PS3.
Oct 20, 2010 | Protron PLTV-32 Television
We bought a hardly used ps3 for our son for x-mas. We have tried hooking it up but can't get it too play. The tv is not an HD tv, the older style tv, also have a cable box attached to the tv. Plugged the...
or the previous owner of the ps3 had the settings on the system on HD settings and now the Non-HD TV cannot recognize the signal. In order to change the settings you have to find someone with an HD TV and switch the output settings from HD to AVI
Dec 30, 2009 | Sony Playstation 3 (PS3) Console
PS 3 Hookup to Sony Grand Wega
this is a very simple fix leave cords in your sony with ps3 on standby hold the power button on ps3 itself down for 10sec your ps3 will switch back to av cables
Jan 05, 2009 | Sony Playstation 3 (PS3) Console
Philips E-Box FTR9965 DTV Receiver and PS3 connection problem
maybe your ps3 is set to hd output and not standard av so it's trying to send the signal through the hdmi port. if so, you need to hold the power button for a certain amount of time (it tells you in the manual) and it will switch to av output.
Dec 25, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 console not displaying on tv screen
Make sure all the video cable connections are plugged firmly into the back of the PS3
The sound you are hearing indicates that you are on the right track. To get the video to work you will need to select the correct channel on your TV set. Connect the video cables (yellow) to the video INPUT of the AV port of your TV and then change to the AV channel on your TV set to view the picture.
Please let me know if this did not fix your problem
Cheers
John
Dec 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 60gb setup problem.
I have the same problem, I was told to buy a HDMI CABLE I did
but it still wont work
Dec 27, 2007 | Sony Playstation 3 (PS3) Console
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Sony PlayStation® 3 (60 GB) Console Logo
636 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
