Repair of Power PC ''DELL'' MODEL NO.: PS-5161-1D1
What elements are and what their values RV121 and RV122 elements of computer power computer ''DELL'' model NO.: PS-5161-1D1? 1? Please send email me if you have a scheme.
5 Suggested Answers
  • 231 Answers
SOURCE: Dell power Supply has won't work
Hi, all power supply's have a fuse in them, remove the power supply, open it up and study the printed circut board, you will see either a white ceramic or glass fuse attached to it. Replace this and reasemble it then re-install it into your computer and then test it. If you still have no power then you will have to replace the unit as the costs of repair are far greater than a new one. Goodluck, mistyman
Posted on Aug 30, 2007
pravinbhavsa
  • 348 Answers
SOURCE: PC smps power supply problem
ok you open the pcb check the fuse first then replace it if faulty if it burns again then check 4 diodes then see if 200v big capacitor is expanded or not if so then replace it if not then check diodes after transformer if short then replace it
Posted on Nov 21, 2008
  • 11 Answers
SOURCE: I'm looking scheme for power, Model: PS-5161 1D1
what operating system and type of computer are you trying to find a scheme for? if the operating system is windows there are some pre-made schemes you can use or modify to fit your needs under screen saver: monitor power: then click the "power" button then in power schemes select the power scheme that best suits your needs or modify one of the existing scemes.
Posted on Nov 23, 2008
SOURCE: color coding of R18 resistor of the compaq ps-7231-6cf
red black red - 2Kohm
Posted on Mar 24, 2009
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
Posted on Mar 14, 2012
How do I remove/replace powersupply for dellinspiron one 19 computer
the service manual for this computer (download
Product Support Dell US )
has a section titled Power Supply (link from menu on first page) which sections titled "Removing PS" and "Replacing PS"
21.February.2015
Feb 22, 2015 | Dell Inspiron One 19 All-in-One Desktop PC...
Dell Power Supply Model #TFX0250D5W
First, check that your power cable is not faulty; believe it or not, it is a common problem.
Second, check that your power switch has not shorted out; that is another common problem.
Third, the only way to check your PS is to swap it out with another. If you don't have one, you can also order a power supply tester (which is what I have). Try Newegg.com and type "power supply tester" in their search box. Also check the user reviews for dependability.
Apr 22, 2014 | Dell Computers & Internet
Pc wont power on
A power surge may have blown the PS. If you value your electronics, I suggest using a UPS with battery back up.
For about $25 Tiger direct . Com can provide you with a PS replacement.
Feb 09, 2014 | ASUS 04g185015190dp Power Supply Ps 235w...
Power Doesn't Turn The Computer On
Well if isn't the power supply or the motherboard, it's a boat anchor. You can still use the TX certified sound card in a new one.
Feb 10, 2013 | Dell Dimension 8200 PC Desktop
The ps-5161-1d1 in my Dell GX280 is not working,
LOL, What do you mean still does not work? Does the computer try to come on? If not, the refurbished Power Supply is bad or the Motherboard is completely dead.
Apr 06, 2012 | Dell OptiPlex GX280 PC Desktop
Want to replace a power edge sc1420 power supply with a regular atx power supply has anybody done that. Think the ATX connector is the same but on the other connectors there are many blue wires and I don't...
1) Dell power supply is unique , you can never replace with another regular ATX power supply
2) Please get 2nd handed Dell power supply from the same model. try ebay
Mar 22, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
Problem with a dell computer..
You may try connecting a different usb keyboard to your system. Mostly, some keyboard converted from serial connection to a usb could cause this kind of problem. In some cases also, wireless keyboard and mouse won't work when u turned on your system if the driver is not properly install.
You may also try disconnecting any other usb devices from your computer. Disconnect also your power supply then push and hold the power button for 5 seconds. Plug back in the power cord then connect your keyboard. Turn on your computer. if it doesn't work, i suggest to call your computer manufacturer and check your warranty. This could be an issue with the motherboard of your computer.
Keep me posted.
Thanks.
Jeff
Oct 12, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
I have a flickering amber light on the power button; replaced power supply and motherboard with no luck
FIRST IF YOU REPLACED THE POWER SUPPLY OF YOUR DELL PC,
MAKE SURE IS A RECOMMEND POWER SUPPLY FOR DELL COMPUTERS ONLY
BECAUSE DELL USE A DIFFERENT (NONSTARD) PS
AN PLEASE DON'T TURN YOUR PC ON, TILE YOU ARE SURE I'TS A DELL COMPATIBLE POWER SUPPLY
YOU CAN FRY YOUR COMPUTER
ON THE MOTHERBOARD I'T MAY BE THE BIOS (BIOS STANDS FOR INPUT /OUTPUT SYSTEM) I'T A CHIP ON YOUR MOTHERBOARD THAT CONTROLS THE SYSTEM HARDWARE AND ACTS AS AN INTERFACE BETWEEN THE OPERATING SYSTEM AND THE HARDWARE
I'T MAY BE FLASH
IF IS FLASH ,
YOU PROBABLY NEED TO REPLACE THE MOTHERBOARD
OR CALL DELL TO SEE IF THEY CAN FIX IT
Aug 20, 2008 | Dell OptiPlex GX520 PC Desktop
Aug 30, 2007 | Dell POWER SUPPLY PS-5201-5D (PS52015D)...
Computers & Internet Logo
834 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
