Question about Refrigerators
Tricity Sovreign Frezzer faulty.it sarts up a few minutes after switching off. The frezzer has no model number and,dificult to find a new thermostat with appliance agents.
If you havent worked this out yet, I turned mine off for a while and the computer forgot. Its been fine since them
I presume its an oven not a freezer
Posted on Jan 17, 2009
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
My Kenmore refrigerator is not cooling properly. Freezer portion works fine but not refrigerator. Came on suddenly.
I had the same problem. The frezzer worked but the fridge was not getting cold. What I have learned is that the frezzer make the fridge cold, so if the frezzer is working then something is blocking the cold air to get into the fridge. Most likely ice. The air come in at the bottom of the inside of the fridge next to the frezzer. Pull everything out of the frezzer, then unscrew the plannel that runs along the back and you see if there is ice. If so turn frezzer off and dry out the frezzer. I used hot water.
Sep 28, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigerator doesn't get cold but frezzer works frezzer gets way to cold have to defrost every now and then and fridge is warm? dont know what's wrong it's a kemore model # 10675929400 frezzer is on...
Check to see if interior fan motor is running and blades are forcing cold air down to the lower section. New fan motors can be ordered from repairclinic.com or local parts house. Also look for blocked air ducts at back of cabinet.
Jun 09, 2009 | Refrigerators
Having temp problems
for a freezer would suggest a thermostat problem easily replaceable if you follow the removal of the old thermo.use temperature gauge to set to the required degree after instaling new thermo
May 21, 2009 | Freezers
FRIDGE STAYING AROUND 25 DEGREES
you have a gas leak , a refrigeration mechanic is required.
May 10, 2009 | Admiral 26 cu. ft. Side-By-Side...
Sounds like an alarm going off
Have you tried to unplug the unit...wait a few minutes and plug it back in?
Apr 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Keeps clicking on and off
Hello.
It sounds like your condenser fan might not be working, and causing your compressor to over heat. When you turn it down, the thermostat isn't demanding as much run time so the compressor isn't on as much, thus not overheating. Take off the back panel near the floor and see if it is turning or not. Also make sure the condenser coils underneath the frig are clean. If not them vacuum them out.
When it comes to the ice issue, you will need to be more specific. Where is the ice forming? And is it ice or frost?
Dec 05, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Frezzer not running, light still on
well if the frezzer needs a new compressor is still under the manufactures warranty for five years you can have it check out it might just be a timer or overload , thermostat if you are not handy with tools just call a tech to give a diagnosis
Oct 29, 2008 | Freezers
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
