Xerox wc 220 mfd
Black copy
    Novelist:
  • 158 Answers
In FAX mode, try printing a FAX ACTIVITY REPORT from the FAX OPTIONS MENU. IF the print is OK, your scanner light may be defective, and must be replaced by a technician. If the print is black, the DRUM or something in the DRUM CARTRIDGE has no ground or shorted ground. Remove the DRUM CARTRIDGE and CAREFULLY brush or vacuum any loose toner you can see, and reinstall. DO NOT TOUCH THE DRUM ITSELF! IT WILL BE PERMANENTLY DAMAGED BY EVEN A FINGERPRINT! Otherwise, you may have to replace the DRUM CARTRIDGE. It can be purchased as a supply item.
Posted on Nov 18, 2008
Worrng fully supply 220 volt in xerox 7345 110v now this machine is showing error like 009-383,380,382 and after NVM reset one or two copy diagonal bar type print come out and then code is come -
The last time I looked at one of these power supplies I'm sure you had to move over a small sheet metal cover but putting 110volt onto a 220 volt power supply shouldn't cause a problem the other way probably would. However as you seam to get prints out of the machine I don't think you have a power supply problem.
Further investigation needed.
Good Luck.
May 03, 2015 | Xerox Office Equipment & Supplies
I HAVE A XEROX WC 226 THAT THE COPIES ARE LIGHT
If you don't have it, here is a link to the quick start guide.
http://www.manualslib.com/manual/339328/Xerox-Workcentre-C226.html
look on page 7 for the image quality button and adjust as needed.
Feb 24, 2015 | Xerox Office Equipment & Supplies
Meaning of u3-3 in 428
http://www.omkarmin.com/pdf/workcentre-pro-423-428-printertec-23924.pdf
U3-3
(4133)
ROS failure
Abnormal power adjustment
value to the laser diode
when the diode is forced to
go on
POWER
OFF/ON
Jun 07, 2014 | Xerox WorkCentre Pro 428 Copier
Xerox 3050 service manual
sir,
i want get solution for my 3050 xerox machine. while taking the copy the background coming black, idon't know the reason, i changed explosure lamp, primary corona end block, tonner, but till the problem is background black, if one copy comes clear another copy will be black. if know the solution kindly pass the message to my cell no.7760191629.
thankyou,
regards,
prabhu
Sep 11, 2010 | Xerox Office Equipment & Supplies
I have xerox wc 7228, when i try to copy it is showing ''A fault has occurred press C botton to cancel '' error 009-936
hello
here is the link Xerox offical site about error codes and things that you can do . i hope it useless.
Feb 10, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Copies of xerox copier model 5201 almost black
USUALLY Black copies are a Drum grounding problem. I have not seen "black" copies due to old, bad, or otherwise inferior toner... Although, It is a Xerox, LOL
Apr 03, 2009 | Office Equipment & Supplies
Lsu error
LSU indicates a laser problem.
What is the model number? I can give you more information with the proper model number.
Thanks.
Dec 27, 2007 | Xerox Phaser 8500/DN Printer
107 people viewed this question
k24674
jasbo
jasbo
