Does anyone know where I can get a replacement power adapter/cord for my Liquid Video A170E101 Monitor? I've tried several electronics and supplies stores, and even contacted the manufacturer, but to no avail. Lost my old one while moving, so I have no way of knowing the specific part number for the adapter. Please, help?
Hi inkedpandora, http://icm.computercci.com/pgi-productspec?PSO080 This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
I found the information listed below on another site after having the same problem myself.
As long as the adapter you get is rated at 12v and is capable of at least 3.5 amp you'll be OK. Do not get one smaller than 3.5 amp or it will probably burn out fairly quickly. Having a higher amp rating is OK, the LCD will only draw what it needs, not more.
Not so on the volts. If the monitor says 12v, you can only use a 12v adapter. Any voltage higher than 12 risks damaging the LCD.
To do the conversion on watts, divide the watt rating by 12 (for 12v) and you'll get the amperage. Ex: 60 watt = 60/12 = 5 amp.
There are plenty of adapters on eBay that fit this description. Just search '19V adapter' and make sure the amperage is at least 2.6A There are some Universal adapters that have a variety of heads so you can find the match for the monitor. I think it's a 2.5mm (interior dimension), but I haven't confirmed that yet. Good luck!
EBay.com,i found mine on eBay for 40 bucks!
Hi Paul, Is your adapter still available? I am also looking for one since I lost my adaptor? Is your email id correct? Send a mail but got bounced back. Jay.
Hello,I have an original power adapter from my A170E1 monitor if you still need one,I also have the monitor but it does not display properly if you are interested in it for spare parts. Let me know. I left this message before but it has been removed or deleted for some reason. Paul [email protected]
I need to find a power supply for the LiquidVideo Monitor A170E1-01 Please help!
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Please repost the link to this product? Original link is dead... Thanks!
I need to find a power supply for this monitor. Please help!
Mi video es Modelo A170E1 01
DC INPU 19V==2.6 A y no tengo el Adaptador de Corriente, como puedo conseguir uno?
Also need the power supply for A170E1 Liquodvideo monitor
Alberto Thanks
moved without my cable help needed aswell.
I need a new ac/dc adapter for my monitor the old one is missing in a move
