Question about Kenmore Dryers
Cord was removed and i lost booklet for re-attachment
Need schematic for cord re-attachment on Kenmore home dryer
Serial number M95265468
Model number 86980800
    President:
  • Kenmore Master
  • 2,651 Answers
Dont have a schematic, but the cord has 3 wires,of the three wires the middle one is the important one, it MUST be attatched to the middle post connector at the rear of unit. either end can then be attatched to either end, nthey can bbe switched, its only the middle one the will need to be mounted to middle
Posted on Nov 16, 2008
I HAVE AN OLDER MODEL KENMORE DRYER MODEL NUMBER 86872800 AND A NEWER HOME HOME WITH 4 CONNECTORS DRYER HAS ROOM FOR THREE HOW DO I CONNECT NEW CORD
You have to replace the dryer's 3-prong cord to 4-prong. Get yourself a 4-prong cord then on the terminal block at the rear of the dryer, connect the wires of the 4-prong cord to where the same wire colors (red, black, and white) of the 3-prong cord connects to. The only modification needs to be done is on the green/yellow stripe wire that connects from the white wire terminal to the dryer's cabinet. Remove this wire (green/yellow stripe) from the white wire terminal then connect it to the same wire color (green/yellow stripe) of the 4-prong cord and you are done. The new wire configuration would then be red, black, and white on the terminal block and green/yellow stripe wire on the cabinet.
Jun 16, 2011 | Dryers
Kenmore Elite HE3 Dryer PF on control panel,
HI, there may have been a slight power failure within the home breaker unit or the dryer may have lost power to the control for some sort of reason.
I recommend a thorough inspection of the terminal block on the back side of this unit. make sure the power cord is attached tightly and the wall outlet is secure and holding the power cord correctly. if everything looks great with the terminal block and the power cord is plugged in the outlet correctly, simply unplug this unit for 5 minutes to reset the control. after the 5 minutes are up, plug the unit in once more and the PF alert should reset.
Make sure the breaker box in your home is working properly. (the actual breaker switch for the dryer must be in the on position)
Apr 26, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Forgot how the wires go on the back of this timer
Kenmore usually glues a copy of the wiring diagram/schematic on the inside of the back service access panel, or folded up inside the control head.
If you can't find it, give me the full model number and let me see what I can find.
Jan 22, 2009 | Kenmore 63942 Dryer
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
I need a schematic for Kenmore dryer number 417.93052201
sears.com enter your model theyll have a wiring diagram there for you
Mar 06, 2008 | Kenmore 74602 Gas Dryer
Kenmore ele dryer
Remove the ground strap from the middle terminal block in the dryer. Attach the white wire to this terminal. Take the green wire and attach it to the frame of the dryer. Attach the red wire to the right hand terminal, and the black wire to the left side terminal.
Jun 07, 2007 | Kenmore 62722 Electric Dryer
Dryers Logo
108 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
