Vaillant thermocompact 628E gas boiler - not working. Seems as though no power getting through. I had a to replace a switch where some drops of water had leaked into that supplies the power to the boiler, but having doen that it still seems that there is no power as the digital display is blank and none of the lights are on ? any suggestions or must I get a spark out/ cheers
  • janev50 Jan 14, 2009
    The same problem has occurred on my thermocompact boiler. No display, nothing.
    Jane
  • 108 Answers
Dear Prockie..
First, find the wiring diagram and a voltmeter. Attach one lead of the meter to a good ground. Then trace the voltage as laid out on the diagram. For example, if you have voltage to a switch or device, but no voltage out, then that device may be defective. Check all connections. Your boiler has "self diagnostics" but with no display a simple power problem is indicated. If you have no wiring diagram check with the manufacturer online.
Ray
Posted on Nov 16, 2008
Vaillant Gas boiler/furnace not firing up
There is a thermocouple heat detecter in the pilot flame clean it 240 sand paper is ok. replace if not working.
Oct 22, 2014 | Water Heaters
I have a Vaillant Thermocompact VU182 E boiler. Functioning ok except that when room stat. or cylinder stat.shuts of gas the demand light continues to glow and pump keeps on running. Main switchboard has...
Pump should keep running long after gas shuts off, because of residual heat. It is most efficient to shut gas off as quickly as possible, and run off retained heat.
Oct 13, 2013 | KDS Valiant 6380iPTD-01 Notebook
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
Our vaillant atmo TEC pro seems to have a faulty
Sounds like your thermalcouple may be failing, replace that
Nov 23, 2009 | Home
Lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
I have a Vaillant boiler Turbo Max VUW 242/1E, central heating is working but no hot water
You have a faulty diverter valve, this is a fiddly job, you need to call in a 'Gas Safe' engineer to diagnose and replace this
I hope this helps
Steve
Jun 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant boiler that supports a time switch 110
Vaillant time switch 110 have always been problematic. Dry joints on circuit board and faulty clocks.
They seem to last from 2 months to 3 years but can be bought for £33.70 inc VAT from https://supreme1.sslpowered.com/cgi-bin/DMdatabase.cgi?action=/mnt/w0502/d01/s11/b009fa92/cgi-bin/home/Shop/Boiler_Accessories/Vaillant.txt&item=00038
Hope this helps
Jan 26, 2009 | KDS Valiant 6380iPTD-01 Notebook
Thermo Compact Vaillant Boiler
the thermocompact is a non-condensing model, and should be o.k to fix, you do not need a cylinder as is a combi model and would provide hot water on demand!
Dec 02, 2008 | Heating & Cooling
Vaillant Boiler time switch no user manual
http://www.vaillant.co.uk/stepone2/data/downloads/9a/42/00/timeSWITCH_120.pdf
Nov 04, 2007 | KDS Valiant 6380iPTD-01 Notebook
Heating & Cooling Logo
472 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
