Front panel audio connection to the asus motherboard
I want to connect my front panel audio to the motherboard but problem is that there is five wire and nine points in motherboard. Which wire is connected to which point and which wire is looped to make all nine points.
  • rameshkumar5 Nov 17, 2008
    I want to connect my i-ball cabinet, front panel audio to the motherboard having model no ASUS - P5GCMX-1333. Mouse have cutdown my wire and now I have only five wire coming from cabinet side front panel audio and nine points existing in motherboard. Which wire is connected to which point of motherboard and which wire is looped to make complete all nine points to start my audio and Microphone connection. Is it make any changes in BIOS also.
  • 3 Answers
you seem to have found what i seek. im looking for a schematic for my dell latitude d600 to determine which pins of the 9 or so pin battery connection on the mother board require which voltages and or resistances to both supply the 11.1v battery voltage to run the computer, and the other signals voltages resistances etc from the two circuit borads inside the battery case that tell the computer to use the perfectly good fully charged li battery cells or not depending on number of charge cycles. my batttery stopped putting the 11.1 v, it still has alive and well inside, out to the computer mobo, and has stopped charging, or so the computer says, eventhough its fully charged, and yet will not run the computer. i ordered another battery and know why dell in thier infinite though misguided wisdom decided to prematurely kill the good batteries to avoid possible overheating and exploding. but i want for my own knowledge to determine how they are killing the output and possibly design my own circuit that does what they actually needed and meant to do, rather than have the number of charge cycles rule. id just detect battery temperature and ability to charge, and eliminate any counting of charge cycles which is useless, and results in killing perfectly good batteries for no reason. do you know what numberds i actually need to find a schematic. each time i attempt to search with the computer model number, i find schematics of other mfgrs completely different equipment with d600 in the model number, or rar files i cant open, and usually with added notes that downloading this file can harm my computer.
i have always built my own desk tops and fear no electronic circuit but software and file suffixes and wanings of damage to my computer and various types of files apparantly engineered only to confound and confuse give me a little trouble. i started in electronics at a time when each simple circuit stage was built around a single huge glass tube the size of a body builders forearm. and now im working on entire computers with less surface area than one of those tubes. but back when those tubes ruled, manufacturers were trying to build the best longest lasting curcuits they could and drew schematics that actually were intended to be capable of being read by any good tech, and were easy to find with model number, of the equipment. given a schematic i can repair most anything but i cannot find the schematic. but current circuits are desigend to purposely fail for no reason that makes sense so the manufacturer can sell more to replace them, and schematic are well disguised not only in the way thier drawn and marked but even where they are located. ive learned to read nearly all schematics and interpret any schematic symbol, but locating schematics online and getting them to my computer, is difficult for me, eventhough i have desigened and built my own electronic circuits my self all my life.
Posted on Nov 18, 2008
  • 306 Answers
We cannot draw here so look on the motherboard to see the model number and you will have no trouble downloading a schematic and wiring diagram from the manufacturer.
Posted on Nov 15, 2008
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
Plugigng of wire in board
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
Aug 19, 2011 | ASUS P5KPL-AM SE Motherboard
How to activate front panel audio for P5KPL-AM SE?
you connect your front panel cables to to the motherboards front panel connectors to activate the front panel audio.
for more reference you can download your motherboard manual in Asus website below
Feb 02, 2011 | ASUS P5KPL-AM SE Motherboard
How to connect front audio panel in a asus p5p800-mx mobo
Hello there.
I understand that you need to connect the front audio panel to the motherboard.
The user manual which came with your Computer will have the steps and illustrations to connect the front audio panel to the motherboard. If you have the manual that came with your Computer please refer to that.
If you could not find the manual you can download that from ASUS website. The below link will direct you to the download manual page.
Click here to download
Copy-paste the below link in the address bar of a web browser.
Thank you
Good bye and Take care
Feb 21, 2009 | ASUS P5P800-MX (90MBL0T0G0UAYGZ)...
ASUS p5kc front panel connector
all motherboard front side audio connector is equal so if you compair with onther motherboard
Feb 02, 2009 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Oct 03, 2008 | Computers & Internet
Problem with microphone
most of the old motherboards dont support the audio and mic port to work both in back side(back panel header) and front side (front panel header)simultaneously...
most of the old motherboards dont support multi streaming so you cant make both the back panel header and front panel header to work at a time ie i mean you cant connect both panel header at a time ...
you can just refer to your motherboard manual for the detailed information about it ..
in your motherboard if there is any option to connect the front panel header to the motherboard other than the back panel header you can connect it to that the detailed pin information will be given in the motherboard manual ..
if you dont have the option in the motherboard to connect the front panel header seperately then you must remove the pins connected from the back panel header and you must insert the front panel header pins .
this will disable your back panel audio ,mic,linein functionalities but you will be able to connect in front panel header , this front panel header will work ..
if the motherboard is not compatible then the system assembler will leave the front panel wires not connecting to motherboard ..
like this only one panel can work at a time ,
but in the latest motherboards the multi streaming technology has been introduced so both the panels can work at a time and can play different audio on 2 different panels ...
thank you
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Aug 10, 2008 | ASUS P5VD2-MX SE Motherboard
Audio problem
here is a copy of the manual
here is the section on front audio output/input
a98e426.jpg I hope this information helps
Nov 15, 2007 | ASUS M2N-MX Motherboard
Computers & Internet Logo
1,575 people viewed this question
David Payne
David Payne
