Question about Lands Phones
My BT Freestyle 2200 became de-registered from base.
I re-registered all 3 handsets ok for a short while. But now the icon is again flashing when tried to register again the PIN will not show. They will not even allow to reset factory default because cannot enter PIN. Can anyone help please. Thanks very much.
My solution, bought a new phone.
Posted on Nov 15, 2008
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
Have acquired an additional handset with charger. The screen flahes a 'Please register' message. How do I do this?
Assuming you do not have 5 handsets already, make sure that the new handset is fully charged. Carry it over to the base and press Find on the base unit. (This sends out a signal to the handset.) On the handset, press Menu and use the Up arrow to go to the line marked Settings. Press Menu to access this sub-menu. The line H/Settings should be highlighted. If it isn't highlighted, use the Up/Down arrows to navigate to this line. Press Menu to access this menu. Use the Up/Down arrows to navigate to the line Register. Press Menu again. Use the Up/Down arrows to select the base to which you want the handset to be registered. Press Menu again to confirm that base registration. Enter the system PIN for this base; the initial PIN is mentioned in the manual on page 35 and on page 54. Wait for the handset to indicate that it has been registered; it will say Registering until the process is finished. If you take too long to do the steps at the handset, the signal will stop and you will need to start over.
If you already have 5 handsets, you will need to de-register one of them. If the registration process does not properly occur and the issue wasn't taking too long, either the base or the handset is not communicating properly. If other handsets work, I'd suspect that the new handset is faulty.
BT Systems has the manual on the Freestyle 750 product site: http://btbusiness.custhelp.com/app/answers/detail/a_id/12103/~/bt-freestyle-750-user-guide . The direct link to the manual is http://btbusiness.custhelp.com/ci/fattach/get/223683/1232386209/redirect/1/filename/BT_Freestyle_750_user_guide.pdf . The procedure to register the handset is on pages 53-54 of the manual.
I hope this helps.
Nov 02, 2015 | BT Freestyle 750 Digital Cordless Handsets
How do I rescue my BT Freestyle 750 from being stuck "Searching" and remedies that are "Not Possible"?
Have you tried removing the batteries and letting the internal power decay for an hour or so - in other words try to get them to forget what they were. Then replace batteries and try again. I guess you've consulted the user manual, is there a reset button hole anywhere on the base unit? The sort you stick a pin into.
May 19, 2015 | BT FREESTYLE 750 TWIN DIG CORDLESS PHONE
Freestyle 2200 won't work simply beep 3 times
Hi - I checked all the handsets and found I had two registered as no 2, 1 as 3 and 1 as 4 - NO No 1! I don't know how this happened but anyway I changed the duplicate no 2 to be no 1 and then re-registered the offending handset no 4. All is now fine. The duplicate number may have had nothing to do with the problem of course as unfortunately I didn't try re-registering the offending handset beforehand.
Jun 05, 2009 | British Telecom Freestyle 2200 Trio...
BT2200 how do i pair a phone with the base station? I lost the manual that says how to do this
Here are the instructions for registering a new handset for the BT Freestyle 2200.
Nov 08, 2008 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 do dial tone
I have this model of handset but as a triple. I get three beeps from the handsets if the batteries are low or flat.
Are your phones getting charged?
However,
Try putting the base station into a different phone line/ socket if you have one.
if not - Try putting a corded phone on your phone line. Maybe there is something faulty with the socket, maybe there is no dial tone due to faulty wires?
Mar 07, 2008 | British Telecom Freestyle 2200 Trio...
No Caller display
I have had Several problems with the Freestyle 2200 phones.
The best solution I have found is to remove the rechargeable batereis for 30 seconds and then replace them. This seems to work every time.
Jan 21, 2008 | British Telecom Freestyle 2200 Trio...
Phone beeping!
on some phones the beep refers to a voice mail message that has been left on your answerphone which will be left at the BT server, you can dial 1571 to retrieve the message. Other than that if you have re registered the phone correctly following the instructions on page 22 of the below manual, return the set as faulty. http://media.venda.com/btshop/ebiz/btshop/invt/cay222/freestyle2200.pdf
Jul 08, 2007 | British Telecom Freestyle 2200 Trio...
BT Freestyle 2200 I am having problems obtaining a dialing tone on both of my handsets. When I press the green button for a line out it just beeps 3 times and cuts off. There is charge in both the...
hi just want to help others as desciption aint complete above
Registering a BT Freestyle 2200 handset
1. If there is a handset in the base remove it whilst you are registering the new handset.
2. Press and hold the PAGE button on the base for about 10 seconds until you hear a beep and the In Use light starts flashing.
3. On the handset to be registered, press and hold redial & CALLSd buttons together until display shows 65-.
4. Enter the base number. If this is a new handset then the base number is 1, the display shows 65-1 then PIN. which is normally 0000
5. Enter and registration starts. When the handset beeps and returns to standby registration is complete.
Nov 08, 2006 | British Telecom Freestyle 2200 Trio...
Lands Phones Logo
289 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
