Question about Dishwashers
Buttons not responding
The buttons on my Hotpoint SDW80 dishwasher are only occassionally working. They will work for a time every now and again but generally they do not respond when pressed. Could this be some sort of loose wiring issue?
    Problem Solver:
  • 19 Answers
On my hotpoint with the lcd screen I took the lcd section out and apart and the pad was sitting slightly out from the contact points so I cleaned it up and fixed back together and could not believe that it was that simple! it worked perfectly and has done since. Its not hard to do I promise. P.s I used to have to bang it to get the buttons to work!!
Posted on Jun 04, 2010
  • 833 Answers
Sounds like the button pad has worn out and needs replacement.  Generally the wires are spade lug units which don't come loose.
Posted on Nov 16, 2008
The setting push panel does not respond - can't turn it on
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Dishwashers
Regency problems
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
Main Control Board
Jun 14, 2013 | Maytag Dishwashers
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Control panel inoperable - 2nd time this has happened. First time repairman said "it was fried" because the panel is just under the countertop - of course this is how it is designed to be. Now it has...
Is it operable when the door is close? I'm having a similar problem. The console panel on the top of the door appears to be not working. No lights. No buttons will respond. However when the door is shut, I can squeeze a finger to the start button and actually start the dishwasher. Light also come on when the dishwasher door is closed.
Aug 11, 2010 | GE 24 in. Profile PDW9280JSS Built-in...
Function buttons do not work on off button does
I have expreienced the same problem and carried out a hard re-set by holding down the on/off switch whilst pressing the program button. It's now working - but not sure for how long!
Jan 06, 2009 | Hotpoint 23 in. BFI68 Built-in Dishwasher
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
BF162 DISHWASHER HOTPOINT
I think if you push the heated wash and heated dry button several times until all the buttoms light up this will fix your problem.
 A clean light that flashed repeatedly 7 times then off. Reset as above with the heated wash and heated dry buttons. You may then noticed a reduced flow from the pump so dissasemble the lower arm and water inlet assy.You may find it mostly plugged with foregin matter and some othe junk. Upon removal of that stuff and reassembly,It may work as new!
Feb 09, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
At times some buttons dont work
This may sound crazy but I had one do the same years ago. I cleaned the touch board with glass cleaner and would work fine until got dirty again. Won't hurt to try!
Aug 10, 2007 | Hotpoint RVM1435 Microwave Oven
FDW85 Dishwasher
turn on your dishwasher and press and hold the start/reset and on/off buttons simulaneously until the display shows d.of this turns off the demonstration mode.
May 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
195 people viewed this question
Top Dishwashers Experts
