Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
TV goes off as soon as it is turned on
The television shuts off after being on for 30-60 seconds. Thank God it is happening while still under warranty. Is this something simple that I'm missing? When it goes off, the red (on) light actually blinks twice every few seconds. I'd appreciate any help anyone can provide
  • kb3amd Jun 05, 2008
    Singer TV Model 20 LNC. When I turn it on (remote or on the set) the red (Standby) light goes off, I hear as if it is about to come on, then I hear a couple of thumps and the red light comes on again.
  • Gavel1 Jun 10, 2008
    I am experiencing same problem TV shuts off within 60 seconds of being turned on . Red power light on TV gives two rapid flashes about every 15 seconds after set has shut off on it's own. Unplugging the TV and plugging back in stops the flashing power light but does not solve the problem, I once solved the problem by going to menu, arrowing over to the sleep timer and power on settings and playing with those settings seemed to solve the problem (this must bew down within 60 seconds of turning on), but I can not get it to work this time.
Hey did anyone help on this? I have the same problem.
Posted on Aug 12, 2007
Screan shuts off after 30 seconds and 3 lights flash on botton near power button.
Contact Samsung tech support, Tell them this info, they should be able to tell you the type of problem you have
Feb 12, 2014 | Samsung HLP5085W 50" Rear Projection...
Pioneer SD-P62A3 62" shuts off - won't stay on
If this TV turns back only when it is cooled down than it has cold solder joints tha have to be resolderd.
Jul 07, 2009 | Mitsubishi VS-6055 60" Rear Projection...
PLEASE HELP!!
In all likelihood, the TV's Main Power ON/OFF switch is faulty. Get it replaced.
Feb 23, 2008 | Televison & Video
RCA Television D52W14
The first thing in this unit is to check the ribbon cable that goes from the front control panel to the back ssb board, I would unplug and replug to make sure seated properly. Then try it again. There are alot of screws to take out but worth it if this solves the problem.
Jan 08, 2008 | RCA HD52W58 52" TV
AV 50D501 JVC projection T.V.
sounds like a bad connection in the deflection circuit. you need a repair tech
Dec 16, 2007 | JVC AV-56WP30 56" Rear Projection...
Television shuts off after being on for 30-60 seconds.
I just had the same problem with mine (Toshiba 42HP85) The TV was fine and shutoff red light blinked twice, and you can turn it on agin right away then it shuts off again. The problem was there are 2 cooling fans you can here at the top rear of the unit, when they get dusty the bearings wear out and shut off. See if you can here 1 or both fans working. If only one is on, you can get a replacement from coolguys.com for 7.95 ea. model # is on the back of the fan. Replace both while you have the cover off, if that's the problem. The unit shutting off is the computer sensing there is a problem the red light is an error warning. Good Luck!
Aug 12, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Tv won't stay on
My tv is a Toshiba. It comes on for a second and then goes off by itself. I use the remote and the power button on tv and the same thing happens. Is there a solution to this?
Jan 24, 2006 | RCA F27450 27" TV
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
254 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
