Short operating range of wireless router
A Siemens Gigaset SE587 WLAN dsl, has been provided by my ISP.
This works fine when my laptop is approx. 20metres away, in one part of the house (One brick wall in between), but I cannot get a connection at the same distance, with three brick walls in between.
Is the router not powerful enough?
I believe that the router is made specifically for my ISP, Tiscali, so information is not readily available.
Peter Norris
  • 104 Answers
Hello Peter. I think you may have pinned down the problem within your post. British brick walls can be very solid - and thick - which may well be enough to degrade or block your wireless signal.
The first thing I would try is to move the router to as open and central a position as you can, and see if that helps. Adding a wireless LAN antenna to your router can also help boost a weak signal a little (these just replace an existing antenna on the router).
However, other options you may want to investigate include:
1) using a wireless repeater to boost the signal from your router;
2) a powerline networking system, such as Homeplug ;
3) installing a new router with a more powerful range
..or indeed, abandoning wireless altogether and using a wired connection!
I hope this helps you explore some options, and find a solution.
Posted on Nov 16, 2008
I have just bought a wireless enabled Laptop and already have two desktops in network using Tiscali through siemens gigaset se587 wlan dsl. Is this a wireless router and will I be able to connect my laptop...
yeas you should be able to as long as you know the passkey to connect to the router. windows should detect the wireless netowork automaticlty and you just select to connect
Feb 02, 2010 | Computers & Internet
Configure gigaset SE587 for BSNL broadband
If this is router is gifted to you by a friend of yours who is from UK, Please check if this is locked. Most of the times these would be locked by the ISP. This is a router provide by tiscali UK. Please select the dialing number to 0,38 this is the dialing code for india.
If you use this should work and use as default DNS.
Oct 30, 2008 | Siemens SpeedStream 2624 (SS2624) Wireless...
Siemens Gigaset SE587 WLAN dsl - Firewall
It does have a firewall but I have no idea how effective it is.
Sep 21, 2008 | Computers & Internet
Siemens gigaset se587 wlan dsl
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
I just recieved my Siemens Gigaset SE587 WLAN dsl router and i set it up but the only light coming on is the power light,is the router faulty or damaged?
Are all the cables connected correctly?
Are the DSL settings in?
If it's only the power light, and no WLAN, LAN, DSL or Internet lights on, it sounds like it may be faulty. Is it brand new or second hand?
Aug 22, 2008 | Siemens Computers & Internet
Tiscali Siemens SE587 router
I have solved my problem, after researching various messageboards yesterday to try and discover why my Siemens Tiscali router didn't work. I'm going to send it back and go with another company!
It seems there has been a lot of debate on these messageboards about Tiscali and/or Siemens products and it now seems also that no one would recommend them. I hereby add my name to that list.
Aug 19, 2008 | Computers & Internet
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Wireless internet
The other unit needs a wireless adapter to talk to the router wirelessly
make sure that the wireless function is turned on in the router software ,
you need to enter an IP address in the internet explorer to get into the router, (this should be in the manual or printed on the base of the unit).
you will need to enter a user name and password, (read the manual for these), sometimes, admin admin ,or admin password)
if you used a security key, make sure it is in the wireless software, of the wireless pc/laptop
good luck
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
228 people viewed this question
David Payne
David Payne
