Question about Okilan 8100e Print Server
How do I reset access password?
The guy who set this machine up left the company years before I got here, I am trying to rearrange the network and cannot login to the printserver's settings page, I don't know the username or password for it. How do I give it a factory reset, and what are the default factory access codes for it?
Thanks. I actually found out that it had never been configured - here is the standard factory access info: All Oki network printing devices support configuration changes via a standard web browser such as Internet Explorer or Netscape Navigator. When applying a configuration change to a device the user is prompted for a user name and password. The following details should be entered: User Name: root Password: last six digits of the MAC address* *You can find the MAC address on the network summary web page or by printing off a menu from the printer.
Posted on Dec 30, 2006
    Problem Solver:
  • 16 Answers
Ah HA! I was at my wits end trying to figure out how to reset the admin password on this 6200e I had. I tried guessing, I tried the defaults of "admin" & "OkiLAN", and/or "root" & "6AD067" (the last six digits of NIC's MAC address, use yours), I tried resetting the TCP/IP stack by using OkiView32 and HP Web Jetadmin software and none of that worked! Finally I read above how "the duck" tried this...
  • "Factory Reset on the 8100e card power off the printerHow do I reset access password? - 1.gif hold the test button down on the internet card (above the leds) and power up the interface is reset when the printer is initialised this did not work for me !"
I decided to give his recommendation a whirl even though he said it didn't work. I did it and it worked perfectly, however the trick to this procedure is to actually pull the power cord out, hold the NIC reset button in, then plug in power and turn on...I held the NIC reset button for a solid 60 seconds, however I am not sure how long it really takes, perhaps just until the printer is done initializing.
I hope you find this post before spending three nights trying to solve this issue. Enjoy =)
BobDeath
Posted on Mar 26, 2008
If the card has never been set up before then the word root is the username and the last 6 of the MAC address is the password. All letters in the MAC address must be CAPS. If you have trouble accessing the printer or forgot your username or password then turn the printer off. Press and hold the reset/test button below the RJ45 IP cable plug. Keep the button pressed in and flip the power switch on. Keep the button pressed for at least 60 full seconds, either use a watch or clock or count slowly. Release the button. This should reset it to the factory defaults. Again press the reset button until you here the printer start to work. It will print a settings page and show you the IP address which is auto config by default. These 2 methods work for the C3400N which is what I have but should work on any OKI 9100 Network Card. Enjoy.
Posted on Apr 24, 2010
    New Friend:
9100e network card on OKI c3300 reset, Perfect answer above - after a lot of different attempts to revert back to factory defaults finally read this. The process based on several different threads that finally worked for me was
1. Turn off printer
2. Unplug the power for 15 seconds
3. Plug back in
4. Hold down the reset button on the back next to the network port
5. Turn on the printer while holding reset button down.
6. After 60 seconds release reset button.
7. Press reset button to get status page and it was reset.
Just need to configure it now
Posted on Oct 11, 2014
It also worked for a case where the OKI Printer lost its mind and would not accept a DHCP reservation. Working now!
Posted on Feb 18, 2009
Factory Reset on the 8100e card power off the printer hold the test button down on the internet card (above the leds) and power up the interface is reset when the printer is initialised this did not work for me !
Posted on Dec 29, 2006
SOURCE:
Reset brother mfc8880dn
If you wish to reset the print server back to its default factory settings (resetting all information such as the password and IP address information), please follow these steps. Before you factory reset the print server, we recommend that you print a configuration page before resetting the print server.
<For BRAdmin Professional ver.2.xx Users>
Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  1. From the main BRAdmin screen double click the appropriate printer.
  2. Enter the print server password (The default password is "access").
  3. Click the Control tab
  4. Click the Restore Factory Defaults button
  5. Click the OK button when you have read the warning message.
  6. The print server will then reset back to its default values.
<For BRAdmin Professional ver.3.xx Users>
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  3. Enter the print server password (The default password is "access").
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete.
Jun 19, 2014 | Brother Office Equipment & Supplies
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
Reset password to the router and get a new one
Are you trying to reset the router password or wireless network password?
Wireless network password is different than router access password.
To change the wireless password, you will need to access the router page and change the settings.
See how to find wireless network password
To change the router access password, you can log in to router page and go to administration tab. There you will find the place to change the router password.
Jan 09, 2012 | Linksys WRT120N Wireless Router
I'm trying to sign into my Netgear Router to reset my password, because I do not remember it and to set-up a secure connection. However whenever I type in http://routerlogin.net, All I get is information...
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If you have changed the default password and have forgotten the password, you may need to reset the NETGEAR device to factory default settings.
When a NETGEAR device resets, it goes back to the state when it was new - all information that was entered by hand is lost! Examples include critical things you need to get online, such as ISP username, ISP password, IP addresses, wireless security keys, and ports and services that were opened. It all needs to be re-entered.
So, have your ISP information before resetting the router.
Naturally, if you moved to a new city, or if you bought a used router, the old information in the router may not be of use to you. Contact your ISP if you can't connect any computer directly to the Internet. Then, if there is a connection problem when the router is added, see No Internet Access Through the Router
Reset for most routers with a reset button on the rear panel
Write down configuration information such as IP addresses, security keys, opened ports and services, etc., that you modified. (The default username is admin and the password is either password or 1234. Try these before resetting the router.)
  1. Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
  2. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the router configuration was not cleared, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
For DGN2000 / DG834Gv5 Routers
To restore the factory default configuration settings when you do not know the login password or IP address, press both the Wireless button and WPS button on the side of the modem router for 5 seconds.
For FR314, FR318, and FV318
These routers require reloading the firmware in order to recover from a lost password. Download the most recent firmware from NETGEAR's Web site before proceeding. Follow the instructions in the manual.
For routers with a 9-pin manager port on the rear panel: RT314, RT311, RM356, RT328, RT338, RH340, and RH348
See Updating Router Firmware That Uses a Manager Port.
This applies to:
  • All NETGEAR devices
Related articles:
Mar 26, 2011 | NetGear WGR614 Wireless Router
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  • You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | Westell Wirespeed VersaLink...
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
I'm trying to connect a new iPad to our home wireless network. The network key for the Linksys WRT5-4G router that always works on every other computer does not work with the iPad. What steps do I need to...
  1. From the iPad's Homescreen, tap Settings. (This assumes you didn't rearrange your apps. If you did, find the Settings icon wherever you put it.)
  2. In the Settings screen, tap Network.
  3. To start the iPad scanning for available wireless networks, tap the WiFi button and then slide the slider to "on". In a few seconds, you'll see a list of all the networks near you, whether they're public or private (if you don't see the list, there may not be any within range).
  4. The list of WiFi networks you'll see will include two kinds: public and private. Private networks have a lock icon next to them; Public don't. The bars next to each network indicate the strength of the connection - more bars means a faster connection.
    To connect to a public network, just tap the network name and you'll be online.
  5. If you want to access a private network, you'll need a password. Assuming you've got the password, tap the network name and enter it the password. Then tap the "join" button at the bottom right of the screen. If your password is correct, you'll connect to the network and be surfing the web. If not, try entering it again (assuming you've got the right one, of course).
  6. Advanced users can click the arrow to the right of the network to access more technical configuration settings. Everyday users probably won't need to look at these options.
Jan 11, 2011 | Linksys Wireless-G WRT54G Router
Westel 327W no longer accessing VPN
It sounds like your company has changed some settings for access into thier local intranet. Your IT guy will have to figure out what's wrong, becuase he would be the one with the knowledge of your companies settings. Perhaps they changed the shared-key, or something in the security settings.
Another note: If you have recently changed/upgraded any installations of firewalls or internet security software, check to make sure it's not blocking any of the IP address or ports you need open to access your company network.
Mar 28, 2008 | Westell Wirespeed VersaLink...
Reset password on Samsung SGH-E250
*2767*3855# resets all locks xx hope it helps
Sep 06, 2007 | Lands Phones
Okilan 8100e Print Server Logo
19,928 people viewed this question
Top OKI Computers & Internet Experts
Alun Cox
k24674
Are you an OKI Computer and Internet Expert? Answer questions, earn points and help others
