Question about Microwave Ovens
H7881 Neff Microwave Light Bulb type
What is the correct type of bulb to replace the broken bulb with?
Go to the NEFF spares area here: http://bshappliancecare.com/Neff/neffspares.html at BSHAppliancecare - if you an locate the FD or E-Nr inside the appliance door then you are laughing. The site's a doddle to use. It should have exploded diagrams and part numbers to look up - and order. The prices seem to be fantastic for the replacements I've made (oven and fridge seals)
Posted on Jan 18, 2009
Is the light cover screwed or a push fit NEFF oven
are you sure its not a
Neff H5642N0GB why you wanting off? has the bulb gone? you can take the hole top off to get to the bulb, make sue you unplug it...not just switch it off ! i mean unplug it from the wall !
Oct 06, 2014 | Neff H5642 Convection / Microwave Oven
How do I replace the light bulb in a NEFF H7860B1GB/01 ?
Unplug power first. You need to remve the screwa that hold the bulb cover, access the bulb and replace it, I will wee if I can find a diagram.
Oct 06, 2008 | Neff Microwave Ovens
Microwave heats, but the turntable and lights don't work
see the chart for light 1)
  • Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  • Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction
  • 2) the carousel inside your microwave won't turn when you run it, the small motor that operates it may be broken.
    God bless you
    Sep 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
    Light bulb
    follow this steps and fix it. God bless you
  • Jul 29, 2013 | GE JES1384SF Microwave Oven
    Whirlpool oven g2p 62f ss
    see the diagram attached, and fix it. God bless you
    1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
    2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
    Jul 08, 2013 | Neff Microwave Ovens
    The lamp of won't work
    follow the steps and fix it. God bless you
    ight Bulb
    If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
    Main Control Board
    If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
    Light Bulb Socket
    If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
    Jun 11, 2013 | Neff H5642 Convection / Microwave Oven
    Replace light bulb on the Neff H7871 combined oven and microwave.
    The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
    Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
    Neff Combined oven and microwave
    If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
    Always unplug a microwave before removing or installing any bulbs.
    If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
    If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
    Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
    On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
    The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
    Be sure to put all the screws back in the right holes, since some may be special grounding screws.
    Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
    Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
    Nov 03, 2008 | Neff H5470 Microwave Oven
    Changing the light bulb
    The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
    Aug 20, 2008 | Neff H7871 Convection/Microwave Oven
    Lamp broken
    Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to line level (mains) voltage, and that posed a real liability threat, so they stopped using them.
    You now must generally remove the outer cover to replace the bulb.
    In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
    Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
    You should be able to find replacements lamps by taking the old one to a local home improvemeant center or department store or an applaince parts store.
    Nov 21, 2007 | Neff H7871N2GB Convection / Microwave Oven
    Microwave Ovens Logo
    256 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
