Question about Honeywell Warm Mist HWM-2030 Humidifier
Refill light is on, but the water tank is full
Even though the tank is full, I push down the Start switch and the refill light comes on 5 seconds later. Now, the only time the Refill light does not come on is if I hold down the start switch. I've already tried taking it apart and cleaning all of the components with no luck. I'm not sure what else could be the problem...
  • 4 more comments
  • ringmastr1 Nov 26, 2007
    I have the same problem with the refill light coming on seconds after refilling the unit and pressing the button. Anybody have a solution to this problem? I really like this humidifier and would hate to have to throw it out.
  • cuagain30 Nov 22, 2008
    Can anybody find a fix for this problem?
  • Anonymous Feb 03, 2009
    Sandpapered heating element, but it wont restart.
  • Carly Fincher
    Carly Fincher Jan 06, 2014
    Yeah it's strange, mine has a mind of iys own. I find if I push the power button & the warm/cool button at the same time it may start working. Not sure if it's a sensor problem based on digital or corusion of amineral buildup. I always use distilled water.
  • Carly Fincher
    Sounds like a recall problem. Not a cheap unit
  • Carly Fincher
    Add a Comment, that's for sure! My brother has 3 of the same as well and has had many problems with this unit
In the manual it says that you should clean the heating element. Unplug the machine, lift off the water tank, pull the lever under the tank and lift off the power unit side. If there is too much build up on the element from mineral deposits, the refill light may remain on.
Unfortunately, I have cleaned mine, soaked it in vinegar, made it look nice and new...and it still doesn't work. I am really annoyed as I have not had this humidifier long and have taken really good care of it. I do not want to throw it out. I am going to call customer support and find out if there are any other solutions. (I got a new one for Christmas and do not want to open it until I am sure that it is not fixable!)
Posted on Dec 26, 2007
    New Friend:
Looks like it's a know problem with the brand. I contacted customer service and they refused to sell replacement parts and asked me to ship the unit back for repair. I live in Canada and the cost just with shipping and custom will be higher than buying a new one. Recommend to be away from the brand.
Posted on Jan 19, 2015
    New Friend:
The water level indicator is controlled by a float which contains a magnet and a magnetic reed switch. The magnet and the reed switch are very similar to the alarm system sensors to detect doors and windows opening. In the humidifier, the reed switch electric leads are made of a material that is getting corroded too easily into the humid environment of the this machine. After a while, the leads are so corroded that the electricity can not pass any more. This make the empty tank light to glow and at the same time it prevents the system to work the same way as if there would be no water water. Since the warm mist is produced by an electric water heater, it is important to stop it when there is no more water because it may cause an overheat and start a fire. The fix the problem you have to replace the reed switch, underneath the humidifier. Try to get the exact replacement part from the manufacturer. Never bypass the reed switch because the heater will not stop when it will run out of water. DO NOT BYPASS THE REED SWITCH. If you choose to replace the read switch only, you have to use the same model and locate it a the same height as the defective one. Don't mess up with a different reed switch without knowing what you have because some reed switch are normally open and other are normally close. Choosing the wrong type is equivalent to bypassing the reed switch with the same catastrophic consequences.
Posted on Nov 04, 2014
Idylis #0484756 unit shuts off tank emply but take is full
Just purchased a Idylis model 0484756 and it has no
operators manuel. Is there one available?
Where?
Thanks
Jan 20, 2014 | Humidifiers
My air-o-swiss 7142 humidifier keeps giving me the empty indicator light to signify no water in the unit even though the base and the tank are full. If I try to reset it comes on for seconds and then shuts...
The water sensor is a float in the mister area of the base. The float is off in one corner with a little plastic barrier around it and translucent cap over it. Make sure the float can more freely. If the float can move up and down but the light stays on, the reed switch (a switch controlled by a magnet built into the float) inside the unit might have been knocked loose, damaged or disconnected. The switch is actually inside the post that the float slides on, but it can only be accessed from the underside - inside the unit.
Sep 20, 2008 | Air-O-Swiss U7142 Humidifier
Water refill light prevents unit from working. Tank is filled . Unit has been cleaned
Your problem is most likely a damaged Ultrasonic Disk (sensor).
If your product has not been used for a while, this piece was most likely damaged if it wasn't properly cleaned before storing. Cleaning well sometimes isn't even enough for this sensitive unit.
Unfortunately, there is no way to get this part, even though it is easily removed and could be easily replaced. Bad PR on the manufacturer's part. Your only solution is to send it for repair (if under warranty, you just pay shipping, if not, you pay shipping and $30) or to buy a different brand. You would think for as expensive as these machines are, the manufacturer would have a better solution to this extremely common problem.
Jan 13, 2014 | Germ Guardian H-3000 Ultra-Sonic...
Filled Watertank; water will not go open valve and go into mister area
It may be clogged with mineral scale. Empty the water that you now have in the tank and refill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Let it soak for several hours and then turn the unit ON. If it starts working as it should. let it run another 5 minutes, turn it OF and empty the tank. Refill the tank with Bottled Distilled Water and allow it to run at least 45 minutes to flush the system. After that, if you do not detect any vinegar odor, you can continue to use the remaining Distilled water.
If the unit didn't work as it should have after several hours of soaking. Turn the unit OFF and let it soak overnight. If this solved the problem, I would recommend that you continue to use Bottled Distilled Water for normal operation, rather than tap water.
Hope this helped solve the problem
Mar 22, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
Have a warm air Honeywell humidifier. The "refill/restart" button is permanently on even if I refill the humidifier and the humidifier does not want to work now. How do I fix this? It seems a sensor is...
This may be due to one of two things.
1. If you turn the unit off or unplug it when you refill the resevoir, then plugging back in or turning it back on will not automatically reset the refill sensor. You must depress the restart slide switch on the bottom front controls to reset and restart the unit, or.....
2. It the refill light won't clear after refilling the resevoir or following the above step, the most likely cause of the problem is a scaled up heating element, which must then be cleaned.
I just uploaded a copy of the user manual to this site, but if you would like to download it directly, follow this link: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000006709.pdf
Hope this helps!
kcomp1863
Dec 03, 2009 | Honeywell Warm Mist HWM-2030 Humidifier
Humdifier wont work
I'm having the same issue
Jan 18, 2009 | Honeywell HWM-260 Humidifier
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Honeywell Warm Mist HWM-2030 Humidifier Logo
1,640 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
Christian Samuelsen
Christian Samuelsen
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
